Страница 30 из 68 ПерваяПервая ... 2023242526272829303132333435363740 ... ПоследняяПоследняя
Показано с 436 по 450 из 1009
Like Tree166Спасибо
Тема: LogHX: English version
  1. #436
    07.04.2002
    г.Москва, г.Троицк
    48
    9,432
    2536
    7613
    Arrow
    Цитата Сообщение от M0CGF Посмотреть сообщение
    Question on EQSL uploads, for this month I operate as MQ0CGF. I have set up EQSL and created a new log in LogHX. I cannot seem to get the MQ0 log to sync with EQSL. Anything I have missed in the set up?
    Have you changed eQSL data in LOG settings - callsign/QTH/password ?
    each time you wanna get data from eQSL for certain of your callsigns, you have to change settings, then take data from service.
    • Telegram Blog & FT8DigiClubDXClusterAPRS • CW 1200МГц
  2. #437
    Low Power
    16.04.2020
    84
    3
    OK got it, does this information save between different logs, as I a ton of /p locations at EQSL and each has its own location and profile?
  3. #438
    07.04.2002
    г.Москва, г.Троицк
    48
    9,432
    2536
    7613
    yes, try to look over there.
    The LOG settings must be equal to the profile settings into eQSL service.
  4. #439
    Low Power
    02.05.2021
    6
    Hello,
    I have a questions about the CreateBackup utility :
    1. Is there a way to memorize the default destination folder. It's always C:/ and I would like to set D:/LogHX-backup/ ?
    2. Is it possible to specify the destination folder from CLI ? I would like to schedule an automatic "Backup-Task" with the Windows Task scheduler ?
    73 Christian F8GHE
  5. #440
    03.02.2006
    20,118
    9903
    5301
    About this utility:
    it's utility for manually create backup file. You don't need to use it normally. For automatically creating buckup use: Setup->Buckup. It's best way to create backup.
    But if you want use this utility, I can refine it, it's not problem.
  6. #441
    Low Power
    02.05.2021
    6
    About this utility:
    yes indeed, I had not seen this SETUP TAB but it is the good method for the backup. Everything is planned from it
    Why not if it's not too complicated for you
    73s Christian F8GHE
  7. #442
    Low Power
    02.05.2021
    6
    Hello,
    I would like to know if someone has already noticed a loss of synchronization of the frequency
    between equipment and softwares of a setup like describe on the picture ?
    This observation is only true when using FLDIGI by making rapid frequency changes.
    I never observe this issue when using :
    - WSJT-X
    - FLDIGI with a slow variation of frequency (On IC-7300 or LogHX or Win4Icom or FLDIGI)
    Note : The 7300.xml file for FLDIGI is the up2date version.Нажмите на изображение для увеличения.
Название:	freq synchro.JPG
    73s Christian F8GHE
  8. #443
    03.02.2006
    20,118
    9903
    5301
    How get freq LogHX?
    Pse print screen of Radio setup in log.
  9. #444
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Hello Alexei,
    Thank you for supporting us with new features!
    I had a strange issue with LoTW download a long time ago. The "QSL QSO after"'s date is constant since 09.20.2021, I have to modify it at every LoTW downloding. See picture.
    Вложение 324972
    Build 689 :
    I have problems with the new telnet section. b688 handle it perfectly but I realized malfunctions with the same setup in b689:
    - Telnet1: I use dx.hu for Telnet1, it is not asking from me any password, just a login name. In b688 it is OK but b689 is inserting my password from the "Script for Telnet" window and it is causes an error, dx.hu says "Invalid command". It is not a big problem, just I noticed it for you.
    - Telnet2: I use HamAlert. In b688 it is handle login/password from "Scripts for Telnet" window but b689 can not handle it just asking login and password again and again. I tried it with and without auto login but no success.
    - Telnet3: I inserted in "Telnet server setup" window the "Localhost 127.0.0.1" but it does not work because it is using the Telnet2's HamAlert telnet setup (!!!) which is NOT checked in the list of "Telnet server setup" window at all.
    I missing Localhost because I intesively using SDC.
    What could be wrong in my setup? HELP PSE!
    Thank you in advance, Egon / HA3MN
    PS: Really enjoyed to meet you "personaly" for the first time on 10m/FT8!
  10. #445
    03.02.2006
    20,118
    9903
    5301
    Yes, it's mistake! Autologin is not turn off! Will be fixed!
    Is here port set right? Did I understand correctly that telnet 1 and telnet 2 use localhost?
    I was wrong! Autologin turn off correctly:
    Вложение 324972
    Please, reload picture.
  11. #446
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Alexei,
    Autologin turn off is working for Telnet1, your picture is clearly shows the solution.
    Investigating my other problems, I will write again.
    73 Egon / HA3MN
  12. #447
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Alexei,
    I sent an email to your qrz.com address.
    73 Egon
  13. #448
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Any idea, please?
    73 Egon / HA3MN
  14. #449
    03.02.2006
    20,118
    9903
    5301
    I know what the problem is. Is here checked?
    I think - yes, here is checked!
    And you use "View" - therefore, the date is not saved.
    Uncheck here or not use "View" when upload QSO.
  15. #450
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Thank you Alexei!
    It was checked!
    I unchecked and now it is remember the downloading date!
    I wouldn't have thought of that...
    73 Egon
    - - - Updated - - -
    Hello Alexei,
    I can't tell you more clearly, sorry.
    Build 689 :
    - Telnet1: NOW OK!
    *** I tried it with and without auto login but no success. ***
    - Telnet3:
    - I inserted in "Telnet server setup" window the "Localhost 127.0.0.1 port 7373" for SDC but it does not work.
ID:	325028 Название: Cluster-Telnet3.PNG
    *** It is using the Telnet2's HamAlert telnet setup! ***
    HamAlert's setup is NOT exist in the list of "Telnet server setup" window at all when I setup for Telnet3.
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 967
    Последнее сообщение: 28.10.2025, 11:00
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
