Страница 29 из 68 ПерваяПервая ... 1922232425262728293031323334353639 ... ПоследняяПоследняя
Показано с 421 по 435 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #421
    Low Power
    02.05.2021
    6
    Hello everyone,
    Who can explain this setup ? I don't understand it
    73s Christian F8GHE
  2. #422
    03.02.2006
    20,627
    10150
    5453
    If you want get spots from WW DX cluster, you can self sets parsing for this ww-page or use two ww dx cluster (OH2AQ or DXSCAPE), parsing of which is already in the log:
    For select OH2AQ or DXScape - double-click on red line.
  3. #423
    Low Power
    02.05.2021
    6
    Hi Alexei,
    "parsing of which is already in the log:" : You mean that the parsing is applied on all new spots and also those that are already in the LogHX log ?
    73s Christian F8GHE
    - - - Updated - - -
    Alexei,
    Here are just 2 small syntax errors in the LocalHost configuration window of the spotmachine
    - Log in promt => Login prompt
    - Replay => Login prompt answer
    Вложение 324033
    73s Christian F8GHE
    Hi Alexei, now it's ok in LogHX V3.0 build 688. Thanks very much !
    73s Christian F8GHE
    - - - Updated - - -
    Hello,
    Here are 3 questions about Spot-Machine setup and 2 minor syntax errors :
    1. What is the use of the Login suffix for the Telnet setup ?
    2. How is the assignment of automatic login scripts 1 or 2 to each telnet sessions done ?
    3. It seems that only adress IP 127.0.0.1 is recognized in the Localhost setup ? Not possible to set IP 192.168.xx.yy !
Название:	login suffix.JPG
  4. #424
    03.02.2006
    20,627
    10150
    5453
    To connect to the same telnet-server from several logs use suffix. You will be connecting as F8GHE-1, F8GHE-2, etc.
    You can't do that now. But this is the right remark. Will do.
    It is possible to use IP 192.168.xx.yy. Is here problem?
  5. #425
    14.03.2022
    Oud-Turnhout
    59
    13
    4
    Hello,
    Is it possible to open a log screen for Radio 2 also.
    73 Pat
  6. #426
    Low Power
    02.05.2021
    6
    Yes it seems not working with the local IP
  7. #427
    03.02.2006
    20,627
    10150
    5453
    Please explain the question. What screen do you need?
    Ok, I'll check this!
  8. #428
    Low Power
    02.05.2021
    6
    Ask for a confirmation about Spot-Machine connection.
    Do you want to mean Disconnect/Reconnect instead Connect/Reconnect ?
  9. #429
    03.02.2006
    20,627
    10150
    5453
    Connect - if there was no connection
    Reconnect = Disconnect and again Connect.
    Here is right: Connect/Reconnect
  10. #430
    14.03.2022
    Oud-Turnhout
    59
    13
    4
    I would like to have these screens for radio 1 & 2 that you shouldn't switch.
    73 Pat
  11. #431
    Low Power
    02.05.2021
    6
    Sorry, in fact, it was a confusion with the top 4 'Connect to' buttons with an individual connection. Now it's clear for me !
    73s Christian F8GHE
  12. #432
    03.02.2006
    20,627
    10150
    5453
    Ok, I'm understand. No, only one QSOEntry window - use hot keys for switch between radio.
  13. #433
    14.03.2022
    Oud-Turnhout
    59
    13
    4
    Hi Alexei, we'll test that thanks for the info.
  14. #434
    03.01.2021
    196
    18
    Hi Alexey,
    after two years and 120000 qso, I still have some observations to make.
    Of course, only for the purpose of improving this beautiful software for all users.
    Only you can tell us if these improvements can be made and for that we thank you in advance.
    UTILITIES -> STATISTICS -> BAND/MODE STATISTIC
    In this statistic it would be nice to add the ability to analyze the complete log
    or filter it by date (FULL LOG or From date -> To date)
    I would like to see the same possibility in the award statistics, such as DXCC etc ....
    Complete management of HRDlog field <HRDLOGS> and <HRDLOGR> fields currently not managed.
    Some automatisms would be convenient in the manual entry window of the QSOs.
    For example when I type the QSO start date, it should automatically change the end QSO date as well,
    and the same thing for the QSO start and end time.
    The same thing when I enter the RX frequency,
    it should automatically propose the same TX frequency.
    However, always leaving the possibility to modify them .... obviously
    Last question, if I start the program with this command:
    LOGHX3.EXE / D = IK2XDE
    can I open a second instance of the software
    LOGHX3.EXE / D = IK2XDF
    And use two logs at the same time .... Multi Operators station.... ??
    Of course with different radio....different CAT and CW COM PORT setup....MULTI TX??
    As you know, we are two brothers.
    In order not to be pointed out as the one who always asks and does nothing,
    I remind you of my availability to help you manage, maintain and update the local file manager
    and the cty.dat file, making them always available to all users.
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  15. #435
    Low Power
    16.04.2020
    89
    3
    Question on EQSL uploads, for this month I operate as MQ0CGF. I have set up EQSL and created a new log in LogHX. I cannot seem to get the MQ0 log to sync with EQSL. Anything I have missed in the set up?
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
