Страница 27 из 68 ПерваяПервая ... 1720212223242526272829303132333437 ... ПоследняяПоследняя
Показано с 391 по 405 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #391
    03.01.2021
    196
    18
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    In the clublog when we upload our log ..... immediatily, (not manualy)
    please add the choice MERGE into EXISTING LOG.....or......CLEAR LOG before UPDATE (CLEAR OPTION)
    Normaly when we send ALL QSO - will be CLEAR OPTION
    Normaly when we send NOT SEND QSO - will be MERGED
    You can find info about CLEAR option here:
    https://clublog.freshdesk.com/suppor...-into-club-log
    I find also that actualy, adif file that we send to clublog,
    not contain field QSL_RCVD and LOTW_RCVD
    This false the clublog DXCC statistic, because not contain, if qso was confirmed or not.
    So please add QSL_RCVD and LOTW_RCVD field to adif to send.
    you can find other info about this here:
    https://clublog.freshdesk.com/suppor...tch-my-logger-
    Thanks in advance.
    73 de IK2XDE Andrea.
    Hello Alexey,
    Any news about my message #387.......??
    Thanks in advance.
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  2. #392
    Low Power
    16.04.2020
    89
    3
    Are these fields in the SW as I don't see where they are but they are in the adif from my tablet log
    for example
    <QSO_DATE:8:d>20211029<TIME_ON:4>1435<TIME_OFF:4>1436<CALL:6>YO6FNF<NA ME:5>David<RST_RCVD:2>59<RST_SENT:2>59<BAND:3>20m<FREQ:6>14.272<MODE:3 >SSB<SUBMODE:3>USB<MY_GRIDSQUARE:6>JO00dr<COMMENT:0><OPERATOR:7>M0CG F/M<STATION_CALLSIGN:7>M0CGF/M<MY_SIG:4>WWFF<MY_SIG_INFO:8>GFF-0018<SIG_INFO:9>yoff-0125<STX:2>15<eor>
  3. #393
    03.02.2006
    20,632
    10151
    5453
    Цитата Сообщение от M0CGF Посмотреть сообщение
    adif
    For import from you tablet log WFF field, use this settings:
    Pse QRX new version!
  4. #394
    03.01.2021
    196
    18
    Thanks in advance.
    Well, with V 678 this is ok.....clublog show correct DXCC statistic......Thanks.
    We are wait for this solution....hope in the next version.
    Thanks for your good job.
  5. #395
    04.01.2021
    59
    11
    3
    Hello,
    I can't get it to work I have this message ORZ.COM.
    My subscription for QRZ.COM is still ok until 03/04/2022.
    73 Pat – ON3CQ
Название:	Schermafbeelding 2021-11-17 142110.png
  6. #396
    25.03.2020
    30
    3
    20
    Two instances of LogHX with common log base - ESDR spot interaction RX1 RX2
    Hi,
    I am using two instances of LogHX (678) to achieve independent operation of ESDR RX1 and RX2, enabling me to use JTDX on RX2 while chasing CW DX on RX1.
    This setup works well, but with one annoyance. When klicking on spots in the ESDR panorama on RX1, it also changes the QRG on RX2 (et vice versa). This only happens when klicking on a spot in panorama. Changing from ESDR2 to ESDR3 does not matter.
    I use the Net Setup in LogHX.
Название:	loghx net setup.PNG
    Anyone?
    73 de LB2EG Richard
  7. #397
    03.02.2006
    20,632
    10151
    5453
    Need prinscreen setup of TCI in log. Here:
    Do you use Radio 1 for ESDR RX1 and Radio 2 for ESDR RX2? I think problem is here.
  8. #398
    25.03.2020
    30
    3
    20
    LogHX (678) and ESDR3 0.11.0 v281221 - Erratic spot behavior
    Hi Alexei,
    Yesterday i put the latest ESDR3 0.11.0 (v.28.12.21) in use with LogHX. Using the spot function LogHX populates ESDR3 panorama with spots as usual, but clicking on spots did not result in change of QRG or an entry in LogHX QSO window.
    The same problem with SDC even in Linux.
    Reporting this on EESDR Github bugtracker, the EE programmer closed the report as no EESDR bug, stating this was a LogHX or SDC problem. https://github.com/ExpertSDR3/Expert...KER/issues/189
    Testing again today, clicking on the FIRST spot from either SDC or LOGHX changes the QRG, but not when clikcing on the subsequent spots.
    73 de LB2EG Richard
    - - - Updated - - -
    EE programmer has reconsidered and accepted this as a ESDR3 bug...
    73 de LB2EG Richard
  9. #399
    03.02.2006
    20,632
    10151
    5453
    Now EE fixed this bug. Now will be Ok!
  10. #400
    Low Power
    16.04.2020
    89
    3
    anyone having issues uploading logs to EQSL and LOTW in 2022? I am getting No Match on eqsl_user/eqsl_pswd for date 20220102 00:01.
    i checked my eqsl and the call is valid from march 2020 to 2035.
    Ian
  11. #401
    03.02.2006
    20,632
    10151
    5453
    Today I load QSO to LoTW and eQSL - no problem. Is the problem still there now?
  12. #402
    03.01.2021
    196
    18
    BANDMAP dont show all spot receiving from telnet.
    Show only not worked call.
    I forgot where is function to set/unset this.
    Thanks
  13. #403
    03.02.2006
    20,632
    10151
    5453
    It's here:
    P.S. I'm very sorry for not answer of you e-mail. Please wait - i'm work of manager base!
  14. #404
    14.03.2022
    Oud-Turnhout
    59
    13
    4
    Alexei,
    I recently started using LogHX together with the SunSDR2 DX and V3 0.12.1 via TCI.
    He always takes my RX 1 TCI for my Log entry can I open a 2nd log entry for RX 2.
    How can I have my RX2 tracked via TCI to also be able to log via RX2.
    Is there is a way tu use double RX and double log entry.
    73 Pat
  15. #405
    03.02.2006
    20,632
    10151
    5453
    Yes - it's here:
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
