06.02.2023, 22:38 #616Координатор темы
- 03.02.2006
- 53
- 20,422
- 10028
- 5395
Ant.: UW4HW, Pwr.: ~500 Wtts
07.02.2023, 15:15 #617Координатор темы
- 03.02.2006
- 53
- 20,422
- 10028
- 5395
Hello Josef!
What to do:
- run only LogHX and select as CAT - CatHX. Setup CAT for you Trx. Set "PTT via CAT"
- Menu Setup->Test CAT window.
- CW window -> press RX/TX button for TX, wait 3 sec and press RX/TX button for RX.
- close Test CAT window. When window coluses, will be created txt-file with command from TRX.
Save this file and sen to me. Tnx!73 de RX4HX, Alexei, http://rx4hx.qrz.ru
07.02.2023, 15:41 #618QRP
- 15.04.2021
- 80
- 12
All are arranged by you, but the TX switch on CW windows works for a very short time only. I tried the TUNE switch ON / 3 sec / OFF, file is here: IC-7100.txt
07.02.2023, 16:11 #619Low Power
- 02.05.2021
- 53
- 6
Hi Alexei, Do you plan to add this Hotkey Ctrl+ESC (or Ctrl+Alt+ESC) in your next build720 ?
(I would like to validate it with the EA4TX ARS-USB of my old friend because for his simplification I prefer not to installed PstRotator for him. With one less software, it will be easier for him
73s Christian F8GHE
07.02.2023, 19:52 #620Координатор темы
- 03.02.2006
- 53
- 20,422
- 10028
- 5395
07.02.2023, 23:06 #621QRP
- 15.04.2021
- 80
- 12
New file here with RX/TX working ((renamed to .txt):TotalTestCATFile.txt
Frequency indicator is OK if TX (all digits).
73 Josef
09.02.2023, 14:44 #622Координатор темы
- 03.02.2006
- 53
- 20,422
- 10028
- 5395
I found problem - please, test this version:
http://rx4hx.qrz.ru/files/loghx/test..._build_720.exe73 de RX4HX, Alexei, http://rx4hx.qrz.ru
10.02.2023, 16:56 #623QRP
- 15.04.2021
- 80
- 12
The build tested - CW via hamlib works OK. There are some limitations (IC-7100 specific):
- it can send up to 29 chars only (incl. spaces)
- speed and CW chars settings must be controlled in radio
AutoCQ in LogHX works OK.
Anyway, the best solution for IC-7100 CW is to use the additional USB port with USB/RS232 convertor.
Thank you Alex for your perfect work. 73 GL Josef
20.02.2023, 23:09 #624Low Power
- 02.05.2021
- 53
- 6
Howto to setup LogHX with a rotor controler EA4TX ARS-USB w and wo PstRotatorAZ
Hi,
Here is a small Howto to setup LogHX with a rotor controler ARS-USB from EA4TX with and without PstRotatorAz. It wrote in French but if you think that coukd be usefull for community, I can translate it in English.
73s Christian F8GHE
25.02.2023, 00:58 #625Low Power
- 02.05.2021
- 53
- 6
Howto change the font size of the "setup menu", the icons and clock size ?
Hello,
I just installed LogHX 7.19 on a new PC with Win11 and I'm not able to modify the font size of the "setup menu", the icons and the clock size. My font size is so small, that I can't read menu
After multiples tests, I don't know if it is a Window11 or a LogHX parameter.
Who can help me ?
73s Christian F8GHE
26.02.2023, 00:09 #626Координатор темы
- 03.02.2006
- 53
- 20,422
- 10028
- 5395
For change clock size - replace files in folder Skins\Default\0.jpg...9.jpg and R.jpg to another. You can find these files on the internet.
The rest cannot be changed yet.73 de RX4HX, Alexei, http://rx4hx.qrz.ru
26.02.2023, 17:08 #627Low Power
- 02.05.2021
- 53
- 6
Thanks very much Alexei.
Ok for the clock size and about the unchangeable font size of the "General Setup" menu but here are some remarks about it:
- I never met this type of tiny font size with Win7 or Win10 and my friend F1DJY who use Win11 doesn't meet this type of problem.
- When I try to change the default font size of Win11, the font size of the "Genral Setup" menu always stays the same.
Questions:
- Is it the default font size of Win11 that used for this menu of LogHX or is it a setting in an .ini file?
- May be, I have to reset and create new .ini files ?
73s Christian F8GHE
28.02.2023, 20:02 #628Координатор темы
- 03.02.2006
- 53
- 20,422
- 10028
- 5395
03.03.2023, 21:41 #629Standart Power
- 03.01.2021
- 196
- 18
IK2XDE Andrea - WWLoc. JN45MQ
https://www.xdenews.net/ik2xde/logonline/
RADIO Setup (update 30/08/2025)
ICOM IC-7600 - (HF - 50MHz.)
SunSDR2DX - (HF - 50MHz. - 144 MHz.)
OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
OB11-3 (11 element - 3 band - 10m-15m-20m)
OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
SkyWire Loop (40-60-80-160 m.)
LogHX Managers Database (update for free)
https://www.xdenews.net/managers/
06.03.2023, 15:47 #630Координатор темы
- 03.02.2006
- 53
- 20,422
- 10028
- 5395
167Спасибо
