Страница 36 из 68 ПерваяПервая ... 2629303132333435363738394041424346 ... ПоследняяПоследняя
Показано с 526 по 540 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #526
    Low Power
    02.05.2021
    6
    Hi Alexei,
    As you are working on CW, I hope you remember my request
    It was about a way (Macro or button, ..?) to set the CW speed identical as our contact .
    73s and have a nice day
    Christian F8GHE
  2. #527
    Low Power
    16.04.2020
    89
    3
    I have just installed the ERC rotator control in my yaesu 450DC. All works using the Easy rotor control software. Com 6, Yaesu GS232A 9600,. I have tried using the Yaesu option and the universalcom port in Loghx and tick auto rotation to spot, but nothing turn when using HX. It certainly opens COM6 as when I try to open ERC while I have HX openwith a rotor connected it says COM6 in use. So I am not sure what is missing?
  3. #528
    03.02.2006
    20,625
    10150
    5452
    Цитата Сообщение от M0CGF Посмотреть сообщение
    ERC rotator
    Can you show print screen of rotor-setup with another logs (N1MM or else), where rotator work fine?
  4. #529
    Low Power
    16.04.2020
    89
    3
    Doesn't work either way if I click the auto to spot
  5. #530
  6. #531
    Low Power
    16.04.2020
    89
    3
    Logger32 it works with these settings
    ; Created at 22/09/2022 19:10:30
    [RotorSetup]
    AutoRotation=True
    BaudRate=5
    ByteSize=3
    COMPort=COM6
    COMPort_Command=
    Correction=0
    DTRControl=False
    Parity=0
    RTSControl=False
    RotorType=1
    StopBits=0
  7. #532
    03.02.2006
    20,625
    10150
    5452
    To M0CGF:
    I remember about you problem, pse QRX! I will deal with your problem in the very near future.
  8. #533
    03.02.2006
    20,625
    10150
    5452
    Try this version:
    http://rx4hx.qrz.ru/files/loghx/prer..._build_705.exe
    Check "Auto rotation to spot" or click here:
  9. #534
    Low Power
    16.04.2020
    89
    3
    Try this version:
    Hi thanks, sorry this didn't work, still no response.
  10. #535
    Low Power
    16.04.2020
    89
    3
    deleted
  11. #536
    03.02.2006
    20,625
    10150
    5452
    Strange! I checked codes from Logger32 and LogHX to rotor - same codes.
  12. #537
    Low Power
    16.04.2020
    89
    3
    Hi Alexei
    I had the ERC guy remote into my set up today to check a few things, he found the following, I made the change to 14400 and it works OK.
    "I tested the rotor function in LogHX.
    The command-syntax for GS232 is correct but I found the bug in LogHX: The Baudrate chosen in SETUP – ROTOR SETUP is wrong.
    If you choose 9600 Baud the real Baudrate is 4800
    If you choose 14400 Baud the real Baudrate is 9600
    If you choose 19200 Baud the real Baudrate is 14400"
  13. #538
    Low Power
    02.05.2021
    6
    Hi Alexei,
    Do you think that it could be possible to add MULTIPSK from F6CTE (index) as an LogHX external program ?
    73s Christian F8GHE
  14. #539
    03.02.2006
    20,625
    10150
    5452
    Thank you for help! Yes, problem is here - fixed. Try now:
    http://rx4hx.qrz.ru/files/loghx/prer..._build_706.exe
    Цитата Сообщение от F8GHE Посмотреть сообщение
    MULTIPSK
    I can't promise that it will be fast. But I will try to do it.
  15. #540
    Low Power
    02.05.2021
    6
    Hi,
    Who can explain to me how FLDIGI communicates with LogHX?
    Here is the diagram of my system
    73s Christian F8GHE
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
