Страница 41 из 68 ПерваяПервая ... 3134353637383940414243444546474851 ... ПоследняяПоследняя
Показано с 601 по 615 из 1015
Like Tree167Спасибо
Тема: LogHX: English version
  1. #601
    Low Power
    04.01.2019
    59
    98
    37
    32
    Hi Christian
    The only problem was in what format Band was written. If you wrote it as in the menu, it did not work correctly (40M, 20M...with a space). If you wrote Band without space (40M,20M...) everything worked correctly. Alexei already fixed it in 718.
    Название: Snímka obrazovky_20230119_203348.png
    Stopping the rotator would be a very nice feature.
    Vlado OM3BY
  2. #602
    Low Power
    02.05.2021
    6
    Цитата Сообщение от Vlado Посмотреть сообщение
    Hi Christian
    Vlado OM3BY
    Hi Vlado, Thanks for this precision. I didn't saw this detail. Luck seems to have been with me
    73s Christian F8GHE
  3. #603
    03.01.2021
    196
    18
    Again about award section.
    After updating some awards, including the WFF,
    I found this small problem, the references are sorted only on the first field (country)
    and cannot be sorted by reference number. (see pictures)
Размер: 39.6 Кб Название: oz.jpg
Размер: 36.2 Кб Название: oh.jpg
    I think it's more convenient to be able to choose the order,
    if sorted by country or by reference, personally I prefer by reference.
    Thanks for the attention
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  4. #604
    Low Power
    02.05.2021
    6
    and cannot be sorted by reference number. (see pictures) ..........
    73 de IK2XDE Andrea
    Hi Andrea, Do you speak about the last test version 7.19 ?
    73s Christian F8GHE
  5. #605
    03.01.2021
    196
    18
    73s Christian F8GHE
    Hello,
    the problem occurs with all versions.
    The awards are simply sorted only with the first field (country) and it is not possible to sort them with the second field (reference).
    I've personally updated and added several new awards, and they all have the same problem.
    It's a small problem, which I hope Alexey will be able to solve in the next version.
    Thank you.
  6. #606
    03.02.2006
    20,333
    9985
    5361
    Yes, this is wrong. I'll fix it.
  7. #607
    15.04.2021
    80
    12
    3
    LogHX, IC-7100, CW keying
    Hello,
    I am testing my new IC-7100 with my logs. The tcvr has a USB connection but only for CAT, no RTS or DTR is supported on the virtual COM port. It seems the only other USB / COM port could be used for CW keying.
    But - I am testing it with my contest SW Tucnak (Czech made) where Hamlib (last version) is used. Voala - CW keying works via CAT perfectly. There is of course the option "CW via CAT".
    Could be the same option added to LogHX radio setting?
    Thanks and 73 de Josef OK2WO
  8. #608
    03.02.2006
    20,333
    9985
    5361
    CW via CAT - it's CW via CAT-command. Write macros -
  9. #609
    15.04.2021
    80
    12
    3
    Sri, it is not what I mean. Excuse for my bad description of the problem. There is no option "CW via CAT" - I was playing with FLDigi where it is. Tucnak has the option "Hamlib" for CW keying:
    I read on Hamlib documentation: rigctl has the command b which is "send_morse" character. A little problem is that speed cannot be controlled from a log but must be controlled by radio (no problem with IC-7100). ESC function for breaking preprogrammed macros works well. The rig poll interval should be short, 100 ms is OK.
    Josef OK2WO
  10. #610
    03.02.2006
    20,333
    9985
    5361
    I understood very well what you wrote. But Hamlib send CW through CAT command.
    ... But macros CATCMD work only for CatHX and OmniRig CAT's.
    Ok! I can do CW via CAT transmission separately for Hamlib.
  11. #611
    03.02.2006
    20,333
    9985
    5361
    Please, test this version:
    http://rx4hx.qrz.ru/files/loghx/test..._build_719.exe
    Set CW here -
  12. #612
    03.01.2021
    196
    18
    Hello,
    sort by second criteria work fine in the award section.
    Thanks Alexey.
    Now I wait you about managers offline.
    Thank you for your continued support and software updates
    73 de IK2XDE Andrea
  13. #613
    03.02.2006
    20,333
    9985
    5361
    Hello Andrea!
    Yes, here is new function - sort by second criteria.
    I'm waiting of test Hamlib CW and release new version!
  14. #614
    15.04.2021
    80
    12
    3
    Tested - CW works OK, but after keying up MHz are missing:
    73 Josef OK2WO
  15. #615
    03.01.2021
    196
    18
    Hello Andrea!
    With the latest build file version 719,
    at the start he asks me to insert the call. (....\LogHX\LogHX3.exe" /D=IK2XDE )
    clicking on ok, presents general setup, where my call is already inserted.
    then click ok, everything works fine.
    73 de IK2XDE Andrea
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
