Страница 6 из 68 ПерваяПервая 123456789101112131656 ... ПоследняяПоследняя
Показано с 76 по 90 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #76
    25.03.2020
    30
    3
    20
    Thanks for info!
    Correct - try this version:
    http://rx4hx.qrz.ru/files/loghx/prer..._build_576.exe
    Still no success. Comparing the data, I see two differences, where N1MM has comma-separated double digit frequency entry, and loghx has single digit with period-separation.
    73 de LB2EG Richard
  2. #77
    03.02.2006
    20,618
    10148
    5452
    Цитата Сообщение от lb2eg Посмотреть сообщение
    double digit
    Here only one digit:
    https://n1mmwp.hamdocs.com/appendice...dp-broadcasts/
    comma-separated
    May be problem here. Try this version with comma-separated (local delimiter):
  3. #78
    25.03.2020
    30
    3
    20
    Now, it is working!
    Thank you!
    Maybe later on it will be possible to filter and colour the spots according to log status, like in ExpertSDR?
    73 de LB2EG Richard
  4. #79
    03.02.2006
    20,618
    10148
    5452
    Not problem!
    From https://n1mmwp.hamdocs.com/appendice...dp-broadcasts/
    color set here:
    <status>single mult</status>
    My variants compliance of colors:
    double mult = new country
    single mult = new country on band
    dupe = also dupe.
    Now colored:
  5. #80
    25.03.2020
    30
    3
    20
    Not problem!
    color set here:
    dupe = also dupe.
    Now colored:
    Works nicely!
    Would it be possible with not too much programming effort to add a function in setup excluding spots that otherwise would be marked as dupe beeing sent with UDP at all? This way one can choose only to show spots for needed entities in the waterfall.
    A yes/no choice in setup, e.g. in the Broadcast data pane would be nice.
    73 de LB2EG Richard
  6. #81
    03.02.2006
    20,618
    10148
    5452
    Hide dupe spots here:
  7. #82
    25.03.2020
    30
    3
    20
    Noted!
    But unfortunately, it does not work on SmartSDR waterfall....
    73 de LB2EG Richard
  8. #83
    03.02.2006
    20,618
    10148
    5452
    It must be work at all spots. Please check - dupe spost showing on cluster window?
  9. #84
    25.03.2020
    30
    3
    20
    As shown in my earlier screenshot, the spots window in loghx shows filtered spots, but no filtering in SmartSDR waterfall. (LogHX only spot source for SmartSDR)
    I will be out of home shack for some days, operating from my 2d. home shack with no Flex-radio. Only IC-7610 and Elad FDM-DUO.
    73 de LB2EG Richard
  10. #85
    03.02.2006
    20,618
    10148
    5452
    Ok Richard, i'm understand! "Hide Dupe QSO" - it's for other: if you wkd with call, it will be not showed.
    You have a different problem - same spots. I'm use trx SunDSR2 with program ExpertSDR, and ExpertSDR show only one spot for one call, it make this self. New spot delete old spot for call.
    How it's done in N1MM? Or not done?
    I can make so: if spot is in log spots base - it will be not send to UPD.
    By the way: is spots on SmartSDR use "time life spots"? Or can manually delete spot?
  11. #86
    25.03.2020
    30
    3
    20
    Excluding spots from the UDP stream is the way to go, I guess.
    As far as I can tell there is an age function in the N1MM UDP function that can define the spot "age" in smartSDR, but I am not sure how it works.
    Most other apps that send spots to SmartSDR use the Flex-API. https://www.flexradio.com/api.
    The N1MM option is the only straight forward UDP method.
    The Flex radio spot function is described here: https://edge.flexradio.com/www/uploa...escription.pdf
    73 de LB2EG Richard
  12. #87
    03.02.2006
    20,618
    10148
    5452
    Now via UDP sends only new spots:
    http://rx4hx.qrz.ru/files/loghx/LogH..._build_577.exe
  13. #88
    Low Power
    16.04.2020
    89
    3
    I am trying to export an ADIF file just containing 1 stations callsign for an OQRS request. I follow the export and type the callsign in I want, press enter and the callsign goes into the box above, but each export has zero entries. Am I missing something?
    Also is the new QRZ function load straight into QRZ.com? I added my API key to LogHXbut it doesn't seen to go up automatically.
  14. #89
    03.02.2006
    20,618
    10148
    5452
    Do you buy QRZ.COM account? It's work only when you buy account.
    zero entries
    Do you select QSO by space button? I think - no
  15. #90
    Low Power
    16.04.2020
    89
    3
    I have this paid membership version "QRZ XML Logbook Data".
    Ah select via "space" excellent I learnt something today
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
