14.05.2024, 00:13 #841QRP
- 26.10.2019
- 46
- 17
- 9
Prerelease build_759, Win10, Sleep Screen.
Hello Alexei.
In Windows 10, up to Test version 759 of 2024-April-24 the Sleep Screen function worked properly, but now with Prerelease build_759 of 2024-May-13 it no longer works.
Is there any configuration to be done?
Thanks for any guidance,
73 from py5ej.
Pavanatti.
14.05.2024, 09:43 #842Координатор темы
- 03.02.2006
- 53
- 20,621
- 10150
- 5452
Ant.: UW4HW, Pwr.: ~500 Wtts
14.05.2024, 13:55 #843QRP
- 26.10.2019
- 46
- 17
- 9
Hello Alexei;
Thank you for your attention.
The on/off functionality would be great, thanks for implementing it.
Sleep mode is useful for monitoring reception on the VHF bands (e.g. 2m, 6m), or on HF (e.g. 60m, 80m or 160m).
Thank you for your dedication to the fine work of developing LogHX.
73 from py5ej,
Pavanatti.
14.05.2024, 16:33 #844Координатор темы
- 03.02.2006
- 53
- 20,621
- 10150
- 5452
Done - Setup->Default->add "Disable computer sleep mode" checkbox
Reload -
http://rx4hx.qrz.ru/files/loghx/prer..._build_759.exe73 de RX4HX, Alexei, http://rx4hx.qrz.ru
24.05.2024, 13:21 #845QRPP
- 20.01.2024
- 7
Hello,
I still have a very long process of synchronisation with eqsl, clublog... ending with an error in "reading adif" And sometimes it's very quick without error. QSO numbers is not important. It can freeze at the first as at the 600th
73, Thierry.
24.05.2024, 14:04 #846Координатор темы
- 03.02.2006
- 53
- 20,621
- 10150
- 5452
27.05.2024, 16:27 #847QRPP
- 20.01.2024
- 7
27.05.2024, 17:37 #848QRPP
- 17.05.2023
- 7
Dear Alexi,
I have noticed a strange behavior with my micro KEYER III. At startup, I receive the following errors regarding the internal CW Keyer WinKey2 (see attached files). I have to press OK twice, and then the WinKey2 is recognized.
I suspect that some routines are checking for the presence of the WinKey2.
Just an FYI, and I hope you can provide a fix in the near future.
73,
HB9DHG Fulvio
27.05.2024, 20:23 #849Координатор темы
- 03.02.2006
- 53
- 20,621
- 10150
- 5452
27.05.2024, 20:34 #850QRPP
- 17.05.2023
- 7
That's a good tip, Alexei.
I'm using two radios. How I can disable the winKey on one radio and use it only on the second one?
Thanks, Fulvio
UPDATED: never mind Alexei,
You pointed out to the right direction. I had to select RADIO 1 first, then disable WinKey.
Everything is fine now and I do appreciate your help with my issue.
Much appreciated!!!
HB9DHG Fulvio
02.06.2024, 11:01 #851QRPP
- 13.04.2024
- 8
- 13
- 5
Is the problem fixed in the latest 761 as I don't see it written in the "Change log"? I only ask enough to inform the DXSpider sysop community. Alex keep up the good work.
Dan S50U sys S50CLX
https://s50clx.infrax.si
02.06.2024, 16:34 #852Координатор темы
- 03.02.2006
- 53
- 20,621
- 10150
- 5452
In the new version of the log (build 762), this setting will be "hidden" so that it cannot be accidentally enabled.
07.06.2024, 14:53 #853QRP
- 21.07.2022
- 80
- 20
LogHX build 761 issue?
Hello,
in the last version of LogHX I am noticed the problem:
QSO from MSHV is written to log with ?????? as callsign, sometimes. Previous versions were OK, no ??????...
73 de Josef, OK2WO
09.06.2024, 23:02 #854Координатор темы
- 03.02.2006
- 53
- 20,621
- 10150
- 5452
25.06.2024, 01:48 #855Standart Power
- 03.01.2021
- 196
- 18
SunSDR2DX with ESDR 1.0.8 with LogHX build 762
CW Macros from LOGHX work great with TCI
Problem with SSB Macros from LOGHX - do NOT send audio via TCI
How we can config it.....??
NO TCI in the Output option.
(Work correct with IC-7600+COM PTT and Audio from PC)
Normally I keep only one band map open, the one relating to the radio I am using.
Normally
Radio 1 - ICOM IC-7600 - Band Maps 1
Radio 2 - SunSDR2DX - Band Maps 2
It would be nice if when I change the radio, the band maps would also change automatically,
so if I am with radio 1 and switch to radio 2, it should automatically close band maps 1 and open band maps 2
I don't know if it's possible and easy to implement, but it would be a nice utility
Thanks for attention.
73 de IK2XDE Andrea.IK2XDE Andrea - WWLoc. JN45MQ
https://www.xdenews.net/ik2xde/logonline/
RADIO Setup (update 30/08/2025)
ICOM IC-7600 - (HF - 50MHz.)
SunSDR2DX - (HF - 50MHz. - 144 MHz.)
OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
OB11-3 (11 element - 3 band - 10m-15m-20m)
OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
SkyWire Loop (40-60-80-160 m.)
LogHX Managers Database (update for free)
https://www.xdenews.net/managers/
167Спасибо
