21.03.2021, 18:33 #271Пользователь Linux
- 07.04.2002
- г.Москва, г.Троицк
- 49
- 9,497
- 2569
- 7700
22.03.2021, 01:05 #272Координатор темы
- 03.02.2006
- 53
- 20,620
- 10149
- 5452
Ant.: UW4HW, Pwr.: ~500 Wtts
23.03.2021, 00:52 #273Standart Power
- 03.01.2021
- 196
- 18
In these years I have tried several logs, I think that an interesting function when we synchronize the log with eqsl,
is to download the images of the qsl and save them linked to the qso.
It would be useful to download the eqsl images and save them in the photo field of each qso.
Thanks for attention
73 de IK2XDE Andrea.
23.03.2021, 22:19 #274Координатор темы
- 03.02.2006
- 53
- 20,620
- 10149
- 5452
24.03.2021, 02:00 #275Координатор темы
- 03.02.2006
- 53
- 20,620
- 10149
- 5452
Yes! I'm fix this problem!
Prerelease 629:
https://forum.qrz.ru/355-loghx-appar...ml#post178791773 de RX4HX, Alexei, http://rx4hx.qrz.ru
24.03.2021, 21:42 #276Standart Power
- 03.01.2021
- 196
- 18
Sorry, but nothing change for me.
Running buil 629 - (Windows 10pro - I7 9700k - 32GbRam)
Starting log /D=IK2XDE
When I try to synchronize LOTW download log, windows freeze.
I just send you my log and adif file, try LOTW and also EQSL same problem.
If I run log in normal mode (NO /D=IK2XDE) all work fine....!!!
- OTHER QUESTION
Using "QSO MANUAL ENTRY" it does not take data from qrz.com
Using "QSO MANUAL ENTRY" the "Printqueue" field is missing (please add it)
Thanks for your continued efforts to improve the software
73 de IK2XDE Andrea
25.03.2021, 01:23 #277Standart Power
- 03.01.2021
- 196
- 18
To be more precise, the search on qrz.com does not work correctly,
it is the third possibility, even if in the setup I have activated only one choice.
I have only configured the search on QRZ.COM
But first look on QRZ.RU ........ and get error.
then it looks for HAM.QTH and gets an error
Only as a last resort (3) search on QRZ.COM and enter the data correctly.
73 de IK2XDE Andrea
26.03.2021, 22:46 #278Координатор темы
- 03.02.2006
- 53
- 20,620
- 10149
- 5452
QRZ.RU window open or checked this menu:
Same for HamQTH.
Done - prerelease 630
https://forum.qrz.ru/355-loghx-appar...ml#post1399067
And check again
Now is ok or not?73 de RX4HX, Alexei, http://rx4hx.qrz.ru
26.03.2021, 23:41 #279Standart Power
- 03.01.2021
- 196
- 18
OK.......Printqueue in the "QSO MANUAL ENTRY" windows work well......thanks...!!
Problem with search info on qrz.com....in "QSO MANUAL ENTRY" was that if i press button
on the right of the call, search start in all of three callbook QRZ.RU -> HAMQTH -> and finaly QRZ.COM
with error result....of course....because was not configured....
But If I select only QRZ.COM......should only search on qrz.com
Unfortunately synchronize with lotw and eqsl still doesn't work.
As soon as I press GO windows freezes.
Please note that only if I start /D=IK2XDE
If I start in normal mode, all work whit no problem.
Thanks.
73 de IK2XDE Andrea
Another observation, although having entered the fields in setup, RTX, ANTENNA and POWER
are not copied in the QSO entry window.
Последний раз редактировалось IK2XDE; 26.03.2021 в 23:45.
26.03.2021, 23:46 #280Координатор темы
- 03.02.2006
- 53
- 20,620
- 10149
- 5452
27.03.2021, 00:26 #281Standart Power
- 03.01.2021
- 196
- 18
28.03.2021, 22:41 #282Координатор темы
- 03.02.2006
- 53
- 20,620
- 10149
- 5452
29.03.2021, 09:22 #283Standart Power
- 03.01.2021
- 196
- 18
Yes....I run as administrator......!!
30.03.2021, 23:14 #284Координатор темы
- 03.02.2006
- 53
- 20,620
- 10149
- 5452
Hm... It's mystery for me
I'm check with you log/setup - not problem. Something block work of log.73 de RX4HX, Alexei, http://rx4hx.qrz.ru
02.04.2021, 23:43 #285Standart Power
- 03.01.2021
- 196
- 18
Well, after countless tests looking for the solution, I found what is blocking windows.
"SHOW NEW COUNTRY"
if I select this function everything stops as soon as I press "GO",
if I don't select this function, everything works correctly.
I have successfully syncronized over 100,000 qsos on lotw and eqsl with no problems.
So the problem is "SHOW NEW COUNTRY" in the syncronize windows.
This function in my opinion i very important,
very often we have problems with the internet line, with the server busy,
especially during the weekends and after the contests.
It is therefore very useful to be able to create the log to be sent,
and then send it later, via the web and not automatically.
Oppure per esempio io preferisco usare per LOTW il software TQSL separatamente.
Grazie per l'attenzione.
73 de IK2XDE Andrea.Последний раз редактировалось IK2XDE; 02.04.2021 в 23:48.
167Спасибо
