Страница 24 из 68 ПерваяПервая ... 1417181920212223242526272829303134 ... ПоследняяПоследняя
Показано с 346 по 360 из 1015
Like Tree167Спасибо
Тема: LogHX: English version
  1. #346
    03.01.2021
    196
    18
    Hello,
    any news about msg #335 (EQSL image)
    will it be possible to implement this function .. ??
    Thanks.
    73 de IK2XDE Andrea.
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  2. #347
    03.02.2006
    20,323
    9983
    5359
    This function is of little interest. I don't plan to do it yet. In the near future, I plan to automatically call in FT8/FT4.
  3. #348
    07.04.2002
    г.Москва, г.Троицк
    48
    9,469
    2557
    7668
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    I just download from eqsl all my 65000 qsl image,
    all image are stored in a directory, C:\Users\LOG\Pictures\IK2XDE-EQSL
    Which name of software has possibilities to do that?
  4. #349
    03.01.2021
    196
    18
    I use eQSL Show by IZ0ROQ
    You can find it here: https://www.iz0roq.com/i-miei-programmi/
  5. #350
    03.02.2006
    20,323
    9983
    5359
    I try to import a single file image in the PHOTO field of the log, and all work fine,
    but, import manualy 65000 file take a long time.
    I have an idea: importing a photo into a log is a bad idea. The Log base will grow very much.
    I can make a separate utility that, when scrolling log database, will show a photo from the directory, if there is one.
  6. #351
    03.01.2021
    196
    18
    Infact I suggest to import only the link of the photo, in the photo field of the log.
    importing images would burden the log unnecessarily.
    73 de IK2XDE Andrea
  7. #352
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Hello,
    Can somebody help me, how to recreate RDA Award statistic in LogHX3, please?
    It is showing false and/or missing datas.
    TU 73 Egon
    - - - Updated - - -
  8. #353
    03.02.2006
    20,323
    9983
    5359
    Is fields "State" and "County" correct for Russian stations?
    Example:
    State - SR
    County - 06
  9. #354
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Example:
    State - SR
    County - 06
    Hello Alexei,
    RDA KI-15 just one of the missing RDA on the statistic.
    When I made a new one, it is written in but sometimes not. I don't know why.
    Thank you for your help!
    73 Egon
ID:	309613   Нажмите на изображение для увеличения.
    Изображения Изображения
  10. #355
    03.02.2006
    20,323
    9983
    5359
    Yes, something is wrong!
    Check state and county fields for KI-15: may be "space" after KI or 15?
    If you don't find the problem - send to me you log base (rx4hx@mail.ru)
    I found problem with R8WB/M and KI-15: R8WB defined as Asiatic Russia (UA9), and KI is Europen Russia (UA).
    For solve this problem change country for R8WB/M in log (Ctrl+С or menu Change country for current station)
  11. #356
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Hello Alexei,
    I’ll investigate further what’s wrong with the others.
    Thank you very much for your help!
    I received this error message but could not interpret it.
    The KI-15 problem is solved!
  12. #357
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Thank you Alexei....
    KI-15 solved...
    I have same problem witk PM-14, KO-08.
    I downloaded the official russian regions list.
    I know the "direction" now, I hope I will find all!
    Thank you again!
    73 Egon
  13. #358
    03.02.2006
    20,323
    9983
    5359
    It's not error, it's "warning". For disable this message - QSOEntry window - uncheck menu "Check State/County".
  14. #359
    03.01.2021
    196
    18
    I read in the Russian section of the forum that you are planning some changes to the log.
    Please remember the HRDLOGS (send) field
    73 de IK2XDE Andrea
  15. #360
    03.02.2006
    20,323
    9983
    5359
    HRDLOGS (send)
    ... and HRDLogR (Received)?
    About EQSL image.
    I'm ready to create utility for showing QSL-image. How do you download images from eQSL?
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
