01.02.2024, 16:23 #781
- 26.10.2019
- 41
- 17
01.02.2024, 21:39 #782
- 03.02.2006
- 51
- 17,278
- 8084
- 4235
Ant.: UW4HW, Pwr.: ~500 Wtts
02.02.2024, 11:44 #783
- 19.11.2019
- Nyirabrany
- 11
- 43
Hello Alexei,
I found this situation on filtering QSOs with date(s) and a custom field.
73 Egon
02.02.2024, 12:36 #784
- 03.02.2006
- 51
- 17,278
- 8084
- 4235
Thanks! Yes, it's mistake! Will be fixed!
Fixed -
http://rx4hx.qrz.ru/files/loghx/LogH..._build_754.exe73 de RX4HX, Alexei, http://rx4hx.qrz.ru
02.02.2024, 13:06 #785
- 19.11.2019
- Nyirabrany
- 11
- 43
02.02.2024, 20:42 #786
- 03.02.2006
- 51
- 17,278
- 8084
- 4235
04.02.2024, 10:48 #787
- 19.11.2019
- Nyirabrany
- 11
- 43
09.02.2024, 02:36 #788
- 03.01.2021
- 165
- 18
Hello Alex,
tell me something about it,
every time I start loghx, it sends TRANSCEIVE OFF via CAT, and I have to manually go into the radio menu and re-enable TRANSCEIVE ON.
It's inconvenient to have to change it all the time.
Another little problem,
I usually use tu set FREQ A from CAT,
Now not read freq A when I am in split, but read Freq B
Thanks.
73 de IK2XDE AndreaIK2XDE Andrea - WWLoc. JN45MQ
https://www.xdenews.net/ik2xde/logonline/
RADIO Setup (update 20/02/2019)
ICOM IC-7600 - (HF - 50MHz.)
SunSDR2DX - (HF - 50MHz. - 144 Mhz.)
OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
OB11-3 (11 element - 3 band - 10m-15m-20m)
OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
SkyWire Loop (40-60-80-160 m.)
09.02.2024, 15:06 #789
- 03.02.2006
- 51
- 17,278
- 8084
- 4235
I'm use INI-files for Radio from OmniRig.
Now I check file IC-7600v2.ini for you Radio and found this:
; Icom IC-7600 ver. 2.00 firmware command set
; IC-7600v2 File created by Bob Wilson, N6TV, n6tv@arrl.net
; Tested by: N6TV @ KE1B & HRO Sunnyvale, CA
; Updated by N6TV 2019-03-23:
; - Comment out compound CI-V commands under pmVfoAA, pmVfoAB, pmVfoBA, and
; pmVfoBB because Icom firmware doesn't handle them consistently.
; - Removed pmFreq as recommended when both pmFreqA and pmFreqB are available.
; initialize
[INIT1]
;Turn CI-V transceive OFF
Command=FEFE7AE0.1A050097.00.FD
ReplyLength=16
Validate=FEFE7AE01A05009700FD.FEFEE07AFBFD
[INIT2]
;disable RS-232C decode, use CI-V
Command=FEFE7AE0.1A050098.00.FD
ReplyLength=16
Validate=FEFE7AE01A05009800FD.FEFEE07AFBFD
[INIT3]
;set CW normal to lower sideband
Command=FEFE7AE0.1A050089.00.FD
ReplyLength=16
Validate=FEFE7AE01A05008900FD.FEFEE07AFBFD
Try delete section [INIT1] from file IC-7600v2.ini (LogHX\Rigs\IC-7600v2.ini)
I think this should help.
Do you use CatHX? If yes then in log - Setup - Test CAT window- then set split ON/Off, close Test CAT window and send file with CAT info to me.73 de RX4HX, Alexei, http://rx4hx.qrz.ru
09.02.2024, 18:19 #790
- 03.01.2021
- 165
- 18
Yes this is the problem,
now problem solved I just put ; before
So initialize ignore/skip this line.
[INIT1]
;Command=FEFE7AE0.1A050097.00.FD
;ReplyLength=16
;Validate=FEFE7AE01A05009700FD.FEFEE07AFBFD
OK I send you personl mail with file.
12.02.2024, 10:18 #791
- 03.01.2021
- 165
- 18
Hi Alex,
I no longer remember how to disable auto reconnection to the cluster.
After sending "bye" to the cluster, loghx automatically reconnects.
I would like to disable the function.
Thank you.
73 de IK2XDE Andrea.IK2XDE Andrea - WWLoc. JN45MQ
12.02.2024, 11:27 #792
- 03.02.2006
- 51
- 17,278
- 8084
- 4235
12.02.2024, 20:57 #793
- 03.01.2021
- 165
- 18
Ok, I tried your solution, but something is wrong.
with ALT+D disconnect telnet correctly.
But if I send the command via telnet
[DISCONNECT] - disconnect from telnet (command provided in the telnet macros)
loghx freezes. and blocks the system.
On the contrary, if I send the manual command "bye" via telnet,
telnet disconnects from the cluster and then reconnects automatically.
So I think you will have to adjust the macro command
[DISCONNECT] = ALT+D
so we can create the macro button in the telnet window to disconnect from the cluster.
Thanks for the attention.
73 of IK2XDE AndreaIK2XDE Andrea - WWLoc. JN45MQ
19.02.2024, 13:30 #794
- 25.07.2023
- 10
Quick question and apologies if I am missing something - is there a QSO timer built in? I am working towards various CW awards that require QSO's over a certain length and I want to be able to start and stop a timer and for this to log the start and end time of a QSO.
I have tried doing this manually and when I set the start time the end time mirrors the start time and greys out so I cannot edit it. Plus I sometimes forget to note the start and end time so a timer would be useful.
Many thanks and vy 73 Danny M0SDB
19.02.2024, 17:01 #795
- 07.04.2002
- г.Москва, г.Троицк
- 47
- 8,913
- Записей в дневнике
- 8
- 2274
- 6968
73! Anton RC3C & RY3AAL & 5ØRDXØØ3 & 5ØRC1Ø7 & RK5AØØ2SWL & 4K8/RC3C
Клубы 4U1A, RC5C, 5ØRDXØØØ/C, New Moscow DX Club : DMR 2503041 : D-STAR XLX937-B : YSF 25001 : EchoLink 2102
RL3F QSL Print | Фото для QSL | FT8DigiClub | Донбасс | DXCluster | APRS2.RU | Discord
