03.08.2021, 09:13 #361Standart Power
- 03.01.2021
- 196
- 18
I use eQSL Show by IZ0ROQ
You can find it here: https://www.iz0roq.com/i-miei-programmi/
Others info about file format in my msg #335
We need HRDLOGS to know if qso was upload to hrdlog server.
For HRDLOGR i do not know if we can download an adif with all confirmed qso like eqsl or clublog.
73 de IK2XDE AndreaIK2XDE Andrea - WWLoc. JN45MQ
https://www.xdenews.net/ik2xde/logonline/
RADIO Setup (update 30/08/2025)
ICOM IC-7600 - (HF - 50MHz.)
SunSDR2DX - (HF - 50MHz. - 144 MHz.)
OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
OB11-3 (11 element - 3 band - 10m-15m-20m)
OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
SkyWire Loop (40-60-80-160 m.)
LogHX Managers Database (update for free)
https://www.xdenews.net/managers/
03.08.2021, 23:22 #362Координатор темы
- 03.02.2006
- 53
- 20,471
- 10086
- 5420
Ant.: UW4HW, Pwr.: ~500 Wtts
04.08.2021, 09:06 #363Standart Power
- 03.01.2021
- 196
- 18
10.08.2021, 15:24 #364QRP
- 25.03.2020
- 30
- 20
Hi Alexei,
I am using LogHX (build 660) with JTDX and Gridtracker.
To keep control over Gridtracker (memory/prosessor usage) i have Gridtracker on a Rasperry PI on the same LAN as my shack PC. As the UDP forward function in LogHX (setup for external programs) does not allow portforwarding to another PC (am i wrong?), I have enabled multicast in JTDX. UDP packets from JTDX are now received by Gridtracker on the Raspberry pi, and forwarded by Gridtracker to the listening port on LogHX on shack PC. This works Ok, but it is a one way stream that does not allow any action to JTDX coming from LogHX.
Is it a big task for you to expand the UDP forward function in LogHX "setup for external programs" to allow portforwarding to another pc/ip-adress (or to expand LogHX to send and receive UDP using Multicast)?
73 de LB2EG Richard
11.08.2021, 00:39 #365Координатор темы
- 03.02.2006
- 53
- 20,471
- 10086
- 5420
14.08.2021, 09:40 #366Low Power
- 19.11.2019
- Nyirabrany
- 11
- 43
RDA synchronization
Hello Alexei,
Are you planning to built in any kind of RDA synchronization (or just check/uncheck fields), as like LoTW, eQSL, Clublog, etc? I can't control what I uploaded and downloaded as worked/confirmed QSO/QSL.
Thank you,
73 Egon
14.08.2021, 16:24 #367Координатор темы
- 03.02.2006
- 53
- 20,471
- 10086
- 5420
16.08.2021, 14:19 #368Координатор темы
- 03.02.2006
- 53
- 20,471
- 10086
- 5420
17.08.2021, 02:34 #369QRP
- 25.03.2020
- 30
- 20
17.08.2021, 08:40 #370Координатор темы
- 03.02.2006
- 53
- 20,471
- 10086
- 5420
Correct - check settings for rebroadcast and try again:
http://rx4hx.qrz.ru/files/loghx/prer..._build_662.exe73 de RX4HX, Alexei, http://rx4hx.qrz.ru
17.08.2021, 13:34 #371Low Power
- 19.11.2019
- Nyirabrany
- 11
- 43
Alexei,
I would be great if you would prepare just two fields into database for future use, like for LoTW, eQSL, etc. I would use it for "hand" synchronisation with any source from Hamlog, mydx.eu, cfmrda. I have confirmed QSOs now only from the LoTW in my log, which is just less than half of my confirmed QSOs. And in the future, when will be any server, LogHX can "continue" the synchronisation.
73 Egon
17.08.2021, 16:47 #372QRP
- 25.03.2020
- 30
- 20
17.08.2021, 22:23 #373Координатор темы
- 03.02.2006
- 53
- 20,471
- 10086
- 5420
17.08.2021, 23:35 #374Low Power
- 19.11.2019
- Nyirabrany
- 11
- 43
18.08.2021, 08:21 #375Координатор темы
- 03.02.2006
- 53
- 20,471
- 10086
- 5420
167Спасибо
