Страница 53 из 68 ПерваяПервая ... 34346474849505152535455565758596063 ... ПоследняяПоследняя
Показано с 781 по 795 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #781
    26.10.2019
    46
    17
    9
    Feedback for the LogHX 754 version
    Hello Alexei;
    I encountered a problem installing version 754, see below:
Название:	loghx flrig.png
    Thanks for your attention, 73 from py5ej.
  2. #782
    03.02.2006
    20,621
    10150
    5452
    Is here path to Flrig.exe OK?
  3. #783
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Hello Alexei,
    I found this situation on filtering QSOs with date(s) and a custom field.
    73 Egon
  4. #784
    03.02.2006
    20,621
    10150
    5452
    Thanks! Yes, it's mistake! Will be fixed!
    Fixed -
    http://rx4hx.qrz.ru/files/loghx/LogH..._build_754.exe
  5. #785
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Fixed -
    Hello Alexei,
    Sorry but I forgot to say in my last message, I use 754!
    What do I do wrong?
    73 Egon
    - - - Updated - - -
    Название: Date and custom field 2.PNG
    But this is OK!
    DateQSO>=#01/01/2024# and DateQSO<=#02/02/2024# and Country="UA"
    or
    DateQSO>=#01/01/2024# and DateQSO<=#02/02/2024# and Country LIKE "UA"
    73 Egon
  6. #786
    03.02.2006
    20,621
    10150
    5452
    This is the corrected version 754! Reload and install it!
  7. #787
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Hello Alexei,
    Thank you for the info, YES it works now!
    But I had to reinstall v754 again. My 754 was updated by
    the automatic update but it does not work! Hmmm...
    I downloaded LogHX3Setup_build_754.exe from your website
    and reinstalled it and NOW it works!
    Thanks again!
    73 Egon
  8. #788
    03.01.2021
    196
    18
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    LOGHX v 3.0 build 754
    HXCAT --> IC 7600v2
    When LOGHX start send to transceiver command CI-V TRANSCEIVE OFF
    also when I enter and exit from Radio setup.
    I'm sure it didn't happen before, if we go back a few versions.
    This is a problem for me that I have connect PC+AMPLIFIER+Externat SDR Receiver+SDR CONSOLE....all need CAT
    CI-V Transceive
    Each Icom radio can operate in one of two modes concerning the CI-V interface: CI-V Transceive on or off. What is this?
    With CI-V Transceive set to on, two things happen:
    the rigs transmits data automatically over the bus, whenever frequency or mode changes
    the rig reacts to data sent over the bus which is adressed not only to it’s own adress but also to a special adress meaning “all rigs connected”
    With CI-V Transceive set to off, the behaviour changes:
    the rig does not send data automatically, when turning the dial or changing mode, the connected computer must request (poll) data
    the rig reacts only to data sent to it’s specific adress, data sent to “ALL” is ignored.
    The default setting is CI-V Transceive set to On.
    This is useful when connecting a rig to an accessory like an amplifier which can read the CI-V data (and switch bands accordingly).
    Also this mode is used to synchronize two radios all the time, maybe in a contest setup.
    Another little problem,
    I usually use tu set FREQ A from CAT,
    Now not read freq A when I am in split, but read Freq B
    Thanks.
    73 de IK2XDE Andrea
    Hello Alex,
    tell me something about it,
    every time I start loghx, it sends TRANSCEIVE OFF via CAT, and I have to manually go into the radio menu and re-enable TRANSCEIVE ON.
    It's inconvenient to have to change it all the time.
    Thanks.
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  9. #789
    03.02.2006
    20,621
    10150
    5452
    I'm use INI-files for Radio from OmniRig.
    Now I check file IC-7600v2.ini for you Radio and found this:
    ; Icom IC-7600 ver. 2.00 firmware command set
    ; IC-7600v2 File created by Bob Wilson, N6TV, n6tv@arrl.net
    ; Tested by: N6TV @ KE1B & HRO Sunnyvale, CA
    ; Updated by N6TV 2019-03-23:
    ; - Comment out compound CI-V commands under pmVfoAA, pmVfoAB, pmVfoBA, and
    ; pmVfoBB because Icom firmware doesn't handle them consistently.
    ; - Removed pmFreq as recommended when both pmFreqA and pmFreqB are available.
    ; initialize
    [INIT1]
    ;Turn CI-V transceive OFF
    Command=FEFE7AE0.1A050097.00.FD
    ReplyLength=16
    Validate=FEFE7AE01A05009700FD.FEFEE07AFBFD
    [INIT2]
    ;disable RS-232C decode, use CI-V
    Command=FEFE7AE0.1A050098.00.FD
    ReplyLength=16
    Validate=FEFE7AE01A05009800FD.FEFEE07AFBFD
    [INIT3]
    ;set CW normal to lower sideband
    Command=FEFE7AE0.1A050089.00.FD
    ReplyLength=16
    Validate=FEFE7AE01A05008900FD.FEFEE07AFBFD
    Try delete section [INIT1] from file IC-7600v2.ini (LogHX\Rigs\IC-7600v2.ini)
    I think this should help.
    Do you use CatHX? If yes then in log - Setup - Test CAT window- then set split ON/Off, close Test CAT window and send file with CAT info to me.
  10. #790
    03.01.2021
    196
    18
    ; initialize
    [INIT1]
    ReplyLength=16
    Yes this is the problem,
    now problem solved I just put ; before
    So initialize ignore/skip this line.
    [INIT1]
    ;Command=FEFE7AE0.1A050097.00.FD
    ;ReplyLength=16
    ;Validate=FEFE7AE01A05009700FD.FEFEE07AFBFD
    OK I send you personl mail with file.
    73 de IK2XDE Andrea
  11. #791
    03.01.2021
    196
    18
    Hi Alex,
    I no longer remember how to disable auto reconnection to the cluster.
    After sending "bye" to the cluster, loghx automatically reconnects.
    I would like to disable the function.
    Thank you.
    73 de IK2XDE Andrea.
  12. #792
    03.02.2006
    20,621
    10150
    5452
    Use Alt+D to manually disconnect. Open Tab with Telnet and press Alt+D. (For each teltet)
  13. #793
    03.01.2021
    196
    18
    Ok, I tried your solution, but something is wrong.
    with ALT+D disconnect telnet correctly.
    But if I send the command via telnet
    [DISCONNECT] - disconnect from telnet (command provided in the telnet macros)
    loghx freezes. and blocks the system.
    On the contrary, if I send the manual command "bye" via telnet,
    telnet disconnects from the cluster and then reconnects automatically.
    So I think you will have to adjust the macro command
    [DISCONNECT] = ALT+D
    so we can create the macro button in the telnet window to disconnect from the cluster.
    Thanks for the attention.
    73 of IK2XDE Andrea
  14. #794
    25.07.2023
    10
    Quick question and apologies if I am missing something - is there a QSO timer built in? I am working towards various CW awards that require QSO's over a certain length and I want to be able to start and stop a timer and for this to log the start and end time of a QSO.
    I have tried doing this manually and when I set the start time the end time mirrors the start time and greys out so I cannot edit it. Plus I sometimes forget to note the start and end time so a timer would be useful.
    Many thanks and vy 73 Danny M0SDB
  15. #795
    07.04.2002
    г.Москва, г.Троицк
    49
    9,497
    2569
    7700
    yep
    it equals to start time of QSO.
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
