Страница 50 из 68 ПерваяПервая ... 4043444546474849505152535455565760 ... ПоследняяПоследняя
Показано с 736 по 750 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #736
    03.01.2021
    196
    18
    Wonderful,
    with v.3.0 buid 744 dated 31/12/2023 20.31
    the database manager seems to work fine.
    All insert and update functions seem to work.
    I will do more tests in the next few days.
    Thanks Alex.
    Happy New Year to all users
    and Good DX
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  2. #737
    03.01.2021
    196
    18
    I warmly thank Alex for his efforts in the development of LogHX.
    Finally, the management of the offline manager database work fine and allows various import solutions by users.
    Personally, I have kept my database updated for years, and I thought I would make it available to all LogHX users.
    I normally update it a couple of times a month.
    You can find the file at the following address: http://www.xdenews.net/managers
    There are also complete instructions to update your log.
    The database can certainly be improved,
    so if anyone would like to send me updates or corrections they are welcome.
    Thanks for the attention.
    73 de IK2XDE Andrea
  3. #738
    03.01.2021
    196
    18
    ALARMED SPOT GRID ...problem....I think.....!!
    When i select some call for alarms spot,
    and in "country status for selected call" i chose Highlight color,
    backgroud spot was colored also if I just work the call on same band and mode.
    It does not take into account whether the station has already been worked.
    I think correct solution will be
    BACKGROUND COLOR only if station will be new one on the same band and mode.
    If station just worked....NOT BACKGROUND COLOR....spot grid background will be white.
    73 de IK2XDE Andrea.
  4. #739
    03.02.2006
    20,559
    10120
    5442
    But many people think differently!
    Therefore, there is a setting here -
    change priority here! Set "Dupes" - UP, "Selected call" - DOWN.
  5. #740
    03.01.2021
    196
    18
    Everything is OK,
    everything works correctly,
    I didn't understand how priorities and colors worked correctly.
    Thank you.
    73 de IK2XDE Andrea
  6. #741
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Hello, just a simple question...
    In the Cluster window I lost the red bracket (when I am on the given frequency).
    How can I switch it back again?
    (This picture is NOT my Cluster window)
    The "Highlight spots on freq" is checked.
    Thank you for help!
    73 Egon
  7. #742
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    I mean "red frame", not "red bracket"
  8. #743
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Two other question:
    - How can I select a QSO in the log window in the new version of LogHX (b748). The SPACE button does not work.
    - What is the function of the "Call" (underlined) in Radio1 window.
    Thank you for help!
    73 Egon
  9. #744
    04.01.2019
    101
    38
    32
    Hi Egon
    SPACE works for me
    If Call is not underlined and you have entered other data (QTH, Name, Loc...) and then you change the letter in the call, this data will be lost.
    If Call is underlined and you have entered other data (QTH, Name, Loc...) and then you change the letter in the call, this data will not be lost.
    Vlado OM3BY
  10. #745
    03.02.2006
    20,559
    10120
    5442
    Is CAT work well? Here is OK!
    Check here - menu Help - Hot keys - set key for Select QSO.
  11. #746
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Hello Alexei,
    Thank you for the help!
    - Yes, CAT is OK in Radio1 window.
    - Help / Hot keys / is OK, SPACE 111
    I reloaded an older View, now SPACE is OK but the red frame is not showing in the Cluster window!
    In MY newest View if I click in the log window anywhere, the log is goes to EDIT mode in the clicked row, so in EDIT mode the SPACE is not functioning as Select/Unselect because the cursor is blinking in the row.
    So I investigate ... But I think, it is time to reinstall the beloved LogHX from the begining.
    I wait a few days, maybe somebody has better idea before I reinstall all again.
    Thank you again!
    73 Egon
    - - - Updated - - -
    Цитата Сообщение от Vlado Посмотреть сообщение
    Hi Egon
    SPACE works for me
    Vlado OM3BY
    Thank you Vlado!!
    Yes I had problem with the disappearing datas in Radio1 window but thank you for you, it will be just bad memories!
    73 Egon
  12. #747
    04.01.2019
    101
    38
    32
    Hi Egon
    Ctrl+E
    Vlado OM3BY
  13. #748
    QRPP
    05.01.2024
    41
    6
    Hi Alexei.
    How to config the CAT-Interface to use the RIG-2 of Omni-Rig
  14. #749
    03.02.2006
    20,559
    10120
    5442
    Good day!
    Here - Название: 1.jpg
  15. #750
    QRPP
    05.01.2024
    41
    6
    Good day!
    It's ok now.thanks a lot!
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
