Страница 5 из 68 ПерваяПервая 1234567891011121555 ... ПоследняяПоследняя
Показано с 61 по 75 из 1015
Like Tree167Спасибо
Тема: LogHX: English version
  1. #61
    07.04.2002
    г.Москва, г.Троицк
    48
    9,477
    2567
    7672
    Вопрос
    Цитата Сообщение от Alde Посмотреть сообщение
    I did try the new version 562 with large.adi
    I did import 50...70k+ ADIF records in one file , and had no problems to import it.
    But prior to import I did edit some tags <> which I need to add or change.
    Can I take a look of piece of that large.adi?
    73! Anton RC3C (ex.RV3DHC, RK3KPE, 5ØVE/Ø) & RY3AAL & 5ØRDXØØ3 & RK5AØØ2SWL & 5ØRC/38A2
  2. #62
    26.10.2019
    46
    17
    9
    Hello friends, RX4HX and RC3C.
    In search of a solution, I adopted an action radical all was deleted, and a new installation was done, and to work fine, all field from "ADIF setup" now are in blank.
    Alexei, in all old versions, until the version 558 the "ADIF setup" were :
    [ConvertADIFField]
    ADIFField1 = QSLMSG # ADDRESS
    ADIFField2 = COMMENT # NOTES
    ADIFField3 = STATE1 # USER1
    ADIFField4 = STATE2 # USER2
    ADIFField5 = STATE3 # USER3
    [SetADIFField]
    USER1 = STATE1
    USER2 = STATE2
    USER3 = STATE3
    To summarize, the problem cannot be attributed to the size of large.adi, as reported, but perhaps due to the combination of fields assigned into "ADIF setup" together with the recent versions.
    I appreciate the collaboration and the attention received.
    73 from py5ej.
    Pavanatti.
  3. #63
    07.04.2002
    г.Москва, г.Троицк
    48
    9,477
    2567
    7672
    You're welcome any time.
  4. #64
    03.02.2006
    20,430
    10038
    5400
    ADIF setup
    You right! Problem was here. Fixed:
    http://rx4hx.qrz.ru/files/loghx/prer..._build_563.exe
    P.S. Check Setup->ADIF setup - I changed here.
  5. #65
    26.10.2019
    46
    17
    9
    Hello!
    Dear Alexei, with the new version 563 everything is back to normal, now it is possible to use the old ADIF setup.
    Thanks and,
    73 from py5ej,
    Pavanatti.
  6. #66
    Low Power
    16.04.2020
    88
    3
    When I work a station from the USA for example and I am using QRZ.com as the lookup, the log fills in the name and address but not the state and QSL information. I need to manually run "find from internet" for the date tag before it updates. Any ideas what I am missing?
  7. #67
    03.02.2006
    20,430
    10038
    5400
    Get me call for check it. May be info placed in wrong fields.
  8. #68
    Low Power
    16.04.2020
    88
    3
    All these do it.
    sorted, found I have messed the State box on the QSO input field so it wasn't in line, State was linked to another field. So put it back to state and it works.
  9. #69
    25.03.2020
    30
    3
    20
    Цитата Сообщение от lb2eg Посмотреть сообщение
    Aexei,
    After version 555/555 automatic reading of wsjtx_log.adi does not work anymore. Only UDP works. This is also the case on 560.
    73 de LB2EG
    Hello again Alexei,
    I understand that you are quite busy working on other parts of your log program these days. I do, however, hope that you will find time to make automatic reading of wsjtx_log.adi work again.
    Using the test versions, i understand that the "Active calls for JT65/Jt9FT8... modes" window will read the frequency of RX1. In my setup using Sunsdr2-DX, I use RX2 for FT8/FT4, picking CW DX on RX1. I may have overlooked something in the setup, but otherwise it would be nice to have an option to direct the active calls window to the QRG of RX2.
    73 de LB2EG Richard
  10. #70
    03.02.2006
    20,430
    10038
    5400
    wsjtx_log.adi
    I'm check this - all is ok! May be wrong path to wsjtx_log.adi in log setup for external programs?
    How JTDX/WSJT-X work with SunSDR2?
    May be two path:
    1. JTDX use LogHX as virtual TS-870 - set number radio here:
    2. LogHX use TCI and JTDX work with ExpertSDR as TS-480 (select COM port for second radio)
  11. #71
    25.03.2020
    30
    3
    20
    checked again and it works with 569.
    May be two path:
    I have never used the LogCAT, but connected directly to EXpertSDR RX2 CAT. Using LogCAT with RX2 as active radio solved my Active calls display problem.
    Thanks!
    73 de LB2EG Richard
  12. #72
    25.03.2020
    30
    3
    20
    Hello Alexei,
    I have two radios in home shack, SunSDR2-DX and Flex-6300. When using the Flexradio with loghx (build 575) i am trying to direct dxcluster spots to the SMARTSDR waterfall, using the N1MM UDP protocol. I can monitor the xml data sent from loghx to SmartsSDR via SmartCAT N1MM UDP port but no spots shows up on the waterfall. Using N1MM sending spots to SMARTSDR works ok.
    Reading the Russian language loghx groups, I understand that you did some testing on this in December 2018, but I cannot find any info on success..
    If this function is not working in loghx, I can assist on testing.
    73 de LB2EG Richard
  13. #73
    03.02.2006
    20,430
    10038
    5400
    Where set in N1MM for sending spots to SmartSDR? It is simple function and i can make it fast.
  14. #74
    25.03.2020
    30
    3
    20
    On N1MM website you will find the information here (spot data) https://n1mmwp.hamdocs.com/appendice...dp-broadcasts/
    Comparing xml data sent from loghx to SmartSDR on UDP port 12061 to data from N1MM shows very little difference :
    From LOGHX:
    From N1MM:
Название:	N1MM to SmartSDR spots.PNG
    73 de LB2EG Richard
  15. #75
    03.02.2006
    20,430
    10038
    5400
    Thanks for info!
    little difference
    Correct - try this version:
    http://rx4hx.qrz.ru/files/loghx/prer..._build_576.exe
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
