Страница 52 из 68 ПерваяПервая ... 24245464748495051525354555657585962 ... ПоследняяПоследняя
Показано с 766 по 780 из 1015
Like Tree167Спасибо
Тема: LogHX: English version
  1. #766
    QRPP
    16.01.2024
    3
    Now all good Alexei with V751 - tnx for the fix! :
    Very 73 - Steve G0UIH
    Hi Alexei - tnx for the fix.
    All good now in V751
  2. #767
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Цитата Сообщение от Jim Smith Посмотреть сообщение
    The Awards window... I set the fonts to optimum for my display. I close down the software and restart, and on restarting, the fonts are much larger....
    Did you saved the changes in "Select view"?
    73 Egon
  3. #768
    QRPP
    20.01.2024
    7
    Hello,
    Since version 749, I have the followings problems:
    - Very long statistics calculating time (10s max before, now 2 minutes)
    - Synchronisation with lotw, eqsl or clublog is freezing
    Same problems with 750 or 751
  4. #769
    26.07.2023
    41
    4
    73 Egon
    Yes. Makes no difference. I get things how I want, save the view with a new name. Display reloads and the fonts in those two windows are big again and I'm back to square one.
  5. #770
    QRPP
    20.01.2024
    7
    Hello,
    With 752 version: no more long calculation of statistics!
    Thanks
  6. #771
    03.02.2006
    20,461
    10078
    5415
    How many QSO in log? I have about 20 000 QSO - recalculate statistic less than 1 sec.
  7. #772
    26.07.2023
    41
    4
    More on the issue I covered in my post in post #765.
    I have prepared some screenshots to show the issue...
    First, the Awards window with the desired font settings: font size set to 16
Название:	Awards window before restart.png
    Then I close LogHX down, and restart it:Now you see all font sizes in that window have approximately doubled...
Название:	awards table after restart 1.png
    So I go through and reset the fonts to how they were, save the view, close and restart, fonts doubled again.
    A similar thing is happening with the Band review window - this screenshot is with the desired font settings...
Название:	Band review before restart.png
    And then, after a closedown/restart - note the column header and the row size has increased, and I cant see a way to adjust those, so they carry on getting bigger with each restart...
    Solution is to open a new Band Review window, configure it and close the other one down....
Название:	Band review after restart.png
    - - - Updated - - -
    One more thing.. (sorry!!)
    WW Locators window:
    Selecting a time period returns no data despite there being data to show:
    In this screenshot, 1/1/23 to 31/12/23 are selected, but the map is blank:
Название:	LogHX grid map no data.png
    ... but the data is there, because using the same pair of dates in the Awards window does return data:
Название:	LogHX grid list with same data.png
  8. #773
    03.02.2006
    20,461
    10078
    5415
    WW Locators window:
    Yes, it's bug! Thanks!
    Fixed -
    https://forum.qrz.ru/355-loghx-appar...ml#post2006303
    What skin (name) do you use?
  9. #774
    26.07.2023
    41
    4
    "AutumnSky". I am also using "Golden" on a 2nd instance, but the same issue shows there as well.
    - - - Updated - - -
    Ah. If I use a skin or a style, the issue is present. It goes away if I do not use skins or styles.
  10. #775
    03.02.2006
    20,461
    10078
    5415
    That's good! The cause of the problem has been found! I will look for a solution to the problem.
  11. #776
    QRPP
    20.01.2024
    7
    Now it takes only five seconds for 220 000 qso
  12. #777
    03.02.2006
    20,461
    10078
    5415
    Thanks for info! It's good info!
  13. #778
    QRPP
    29.01.2024
    UDP issue 4348 QSOs!!
    Hello,
    I have just migrated my log to LOGHX. I have a problem.
    I just made a QSO in FT8 and when WSJT-X UDP the QSO in LOGHX this strange
    thing happened...
    4348 QSOs were registered and the software froze! Can anyone help me to solve this problem?
    Thanks,
    73, Pierre VA2CZ
    See the screen shot of my problem
    https://u.pcloud.link/publink/show?c...eaiipIsyTU2Bck
  14. #779
    03.02.2006
    20,461
    10078
    5415
    thing happened...
    Check in log - setup for WSJT-X - here -
    may be here same ports for UDP and Rebroadcast UDP?
    Also check setup for Net.
  15. #780
    03.01.2021
    196
    18
    LOGHX v 3.0 build 754
    HXCAT --> IC 7600v2
    When LOGHX start send to transceiver command CI-V TRANSCEIVE OFF
    also when I enter and exit from Radio setup.
    I'm sure it didn't happen before, if we go back a few versions.
    This is a problem for me that I have connect PC+AMPLIFIER+Externat SDR Receiver+SDR CONSOLE....all need CAT
    CI-V Transceive
    Each Icom radio can operate in one of two modes concerning the CI-V interface: CI-V Transceive on or off. What is this?
    With CI-V Transceive set to on, two things happen:
    the rigs transmits data automatically over the bus, whenever frequency or mode changes
    the rig reacts to data sent over the bus which is adressed not only to it’s own adress but also to a special adress meaning “all rigs connected”
    With CI-V Transceive set to off, the behaviour changes:
    the rig does not send data automatically, when turning the dial or changing mode, the connected computer must request (poll) data
    the rig reacts only to data sent to it’s specific adress, data sent to “ALL” is ignored.
    The default setting is CI-V Transceive set to On.
    This is useful when connecting a rig to an accessory like an amplifier which can read the CI-V data (and switch bands accordingly).
    Also this mode is used to synchronize two radios all the time, maybe in a contest setup.
    Another little problem,
    I usually use tu set FREQ A from CAT,
    Now not read freq A when I am in spit, but read Freq B
    Thanks.
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
