Страница 56 из 68 ПерваяПервая ... 64649505152535455565758596061626366 ... ПоследняяПоследняя
Показано с 826 по 840 из 1015
Like Tree167Спасибо
Тема: LogHX: English version
  1. #826
    03.02.2006
    20,422
    10030
    5395
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    Send spot via telnet --> Insert macros in info
    Please add [submode] field
    Not problem!
  2. #827
    Low Power
    16.04.2020
    88
    3
    I updated the log today and now I cannot open anything says open ADO connection error, log is bad, if I say no dont load it says autorisation failed. any ideas as cannot use my log at the moment as it won't open.
    it has opened my older log from a few days ago, so I am missing QSO's is there a way to fault find the broken log?
  3. #828
    03.02.2006
    20,422
    10030
    5395
    Please - make printscreen of error!
    First - save log base file in another folder!
    Second - find file \LogHX\Log\<BaseName>.lhx2_bkp
    Thrid - rename <BaseName>.lhx2_bkp to <BaseName>.lhx2 and try load log again.
  4. #829
    Low Power
    16.04.2020
    88
    3
    I tried the renaming steps below, still the same error from the bkp file
  5. #830
    26.10.2019
    46
    17
    9
    LogHX & MSHV
    Hello Dear Alexei.
    Issues about configuration to use the MSHV with LogHX :
    1) - How to add: Command line option, (--inst-name=) to use the MSHV in multi-instance ?
    2) - How to set up: LogHX JT (JT/FT - modes actives calls -> Setup auto Call) to MSHV when in FT8 mode ?
    Thanks for your attentions,
    73 de PY5EJ.
  6. #831
    03.02.2006
    20,422
    10030
    5395
    Send file to me rx4hx@mail.ru
    It's will be in 759 version of LogHX.
  7. #832
  8. #833
    03.02.2006
    20,422
    10030
    5395
    sent a dropbox link to your email.
    I'm checking files. Only file M0CGF_20230905_2_20240329.lhx2 is Ok, all other files is absolutely empty!
  9. #834
    Low Power
    16.04.2020
    88
    3
    oh damn! not good. OK let me place the whole of the log folder in there incase I missed one, the one that should be the latest shows 12mb filesize here.
    There is a folder called Log that is uploading and contains 54 files.
  10. #835
    QRPP
    13.04.2024
    8
    12
    5
    Lightbulb Skimmer option, Spot machine window
    Alex, thank you for the tremendous work you give to the amateur radio community with your LogHX3 programme.
    Maybe it would not be a bad idea to remove the "Skimmer" option from the Spot machine window because switching this option on leads to a range of problems. As a dx cluster administrator I notice problems when connecting to the cluster in my case the "market leader" DXSpider which allows to receive spots also from the RBN network. The LogHX3 user mistakenly thinks that by turning on the "Skimmer" checkbox he will also receive skimmer spots. Enabling this option leads to a huge number of telnet retries (unknown command) and a headache for dx cluster administrators who consequently block the user from entering the dx cluster. Enabling RBN skimmer spots is done on the dx cluster itself. I am adding an S50CLX example which could be sensibly included in the LogHX3 instructions.
    Server Name: S50CLX
    Address: s50clx.infrax.si
    Port: 41112
    S50CLX DXSpider Skimmer Usage. Use command line in Telnet window to Send a command to the dx cluster
    SET/SKIMMER (Enabling for ALL MODES)
    SET/SKIMMER CW (Enabling for CW only)
    SET/SKIMMER RTTY PSK (Enabling for RTTY, PSK/FSK)
    SET/SKIMMER FT (Enabling for FT4/8 only)
    SET/SEEME (Turn on RBN spots for own call)
    UNSET/SKIMMER (Disabling for ALL MODES)
    HELP RBN and HELP SET/SKIMMER for a full set of instructions on how to use a feature.
    In case of problems connecting to S50CLX I am available via emial address, see qrz.com.
    Thanks & 73 Dan S50U sysop S50CLX
    https://s50clx.infrax.si
  11. #836
    07.07.2023
    16
    3
    3
    [QUESTION] FT4 vs MFSK/FT4
    FT4 Wise, is this setup right? Do you have any improvement to suggest?
    PS. Mode: MFSK SubMode: FT4 is what is in https://adif.org/314/ADIF_314.htm - III.B.9 Mode Enumeration
    - - - Updated - - -
    PS. Mode: MFSK with SubMode: FT4 is what is in https://adif.org/314/ADIF_314.htm - III.B.9 Mode Enumeration
  12. #837
    03.01.2021
    196
    18
    Dan is actually right.
    Many users don't know the correct commands
    to use the cluster and skimmer function.
    Currently DXSPIDER and CC-Cluster (by VE7CC) are the two most popular cluster software
    For example, these are the commands to use with a my CC-Cluster:
    Server Name: IK2XDE-6
    Address: ik2xde.ddns.net
    Port: 8000
    command----> SET/SKIMMER (skimmer CW & RTTY spots enabled)
    command----> UNSET/SKIMMER (skimmer CW & RTTY spots disabled)
    command--> SET/CW - SET/NOCW (Turn on/off CW spots)
    command--> SET/RTTY - SET/NORTTY (Turn on/off RTTY spots)
    command--> SET/FT8 - SET/NOFT8 (Turn on/off FT8 spots)
    command--> SET/FT4 - SET/NOFT4 (Turn on/off FT4 spots)
    command--> SET/BEACON - SET/NOBEACON (Turn on/off BEACON spots)
    command--> SET/OWN - SET/NOOWN (Turn on/off spots for your own call)
    Thanks for the attention
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  13. #838
    03.02.2006
    20,422
    10030
    5395
    Not, you setup ADIF mode -> Log mode is wrong.
    If you want use FT4 as Mode in log, you must:
    - setup Log mode -> ADIF mode - is Ok!
    - setup ADIF mode -> Log mode must be
  14. #839
    07.04.2002
    г.Москва, г.Троицк
    48
    9,476
    2567
    7671
    Port: 8000
    I have the same functionality on my DX Spider
    RC3C-2 , dxc.rc3c.ru:17300
    73! Anton RC3C (ex.RV3DHC, RK3KPE, 5ØVE/Ø) & RY3AAL & 5ØRDXØØ3 & RK5AØØ2SWL & 5ØRC/38A2
  15. #840
    QRPP
    13.05.2024
    UDP ADIF broadcast, cloudlog interface
    Hi Alexei, hi all, I've enabled UDP Adif broadcast but nothing happens, I don't see packets in wireshark when a QSO is entered.
    Is UDP ADIF broadcast working?
    Basically what I want to do, use a UDP listener to automatically upload QSOs to cloudlog.
    Or Alexei, would you be interested in implementing an automatic QSO upload for cloudlog aka Clublog etc. ?
    https://github.com/magicbug/Cloudlog/wiki/API
    Thank you
    Frank
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
