Страница 21 из 68 ПерваяПервая ... 1114151617181920212223242526272831 ... ПоследняяПоследняя
Показано с 301 по 315 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #301
    07.04.2002
    г.Москва, г.Троицк
    49
    9,497
    2569
    7704
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    Have you thought about how to update the management
    of the managers on the local database ... ??
    is that strictly needed?
    If the IK3QAR and QRZ COM/RU services are included, there is no matter to update local QSLM database. Also, there is a tool in menu to see NG8K contest callsign activity/QSLm information.
    I believe everyone update it manually for their needs, I do that here.
  2. #302
    03.01.2021
    196
    18
    Obviously the local database is essential if you don't have an internet connection.
    It makes no sense to have an old, outdated database, if you don't need it, you might as well delete it.
    73 de IK2XDE Andrea
  3. #303
    03.01.2021
    196
    18
    Hello Alexey,
    the problem described in message 223 persists even with build 634.
    about message 273 I hope you will consider this implementation.
    (eqsl download QSL immage and put it in photo field)
    73 de IK2XDE Andrea.
  4. #304
    03.02.2006
    20,682
    10185
    5463
    Right mouse click over wrong selected button - menu "Set fre for button" - what band for button selected?
    May be as external programm. Not good idea make this function in log.
  5. #305
    03.01.2021
    196
    18
    Hello
    SET FREQ FOR BUTTON was correct,
    problem when a change band, (CHANGE BAD FROM RADIO)
    CAT change band in the qso entry windows, and the band map but....
    bold fond change with band so....like in example 40m (BOLD FONT)
    but yellow button background NOT hcange band...stay on old band. (17m in example)
    If I change band press bandmap button all is ok...!!
  6. #306
    03.01.2021
    196
    18
    Using VOICE WINDOWS with LogHX 3.0 build 636
    If I setup button as in image, I receive error....file NOT FOUND
    But if I remove [TX] and [RX] file was found and play by logHX regularly
    I think there is some problem with TX command.....that include [TX] and [RX] in the file path name.
    Please confirm that TX command FOR VOICE WINDOWS will be send via PTT COM SET for MMVARI (AFSK)
    If yes...please add description for PTT for MMVARI and VOICE (AFSK)
    Thanks.
  7. #307
    03.02.2006
    20,682
    10185
    5463
    file NOT FOUND
    Macros [RX]/[TX] not need. Write only path to wav-file.
  8. #308
    03.01.2021
    196
    18
    Yes....with no macros, file will play regularly,
    but radio NOT go in TX.....PTT not work....!!
    I think PTT is the same of MMVARI......right.....???
    73 de IK2XDE Andrea
  9. #309
    03.02.2006
    20,682
    10185
    5463
    No! Use PTT for CW.
    PTT for MMVari use only with MMVari for digital modes (if need).
  10. #310
    03.01.2021
    196
    18
    Well....I have a problem.
    I use different radio for CW and for SSB and DIGI.
    On SSB and DIGI I use ICOM IC-7600 ACC1 connector wired to COM7 (no CW-KEY connector)
    PTT was on COM7 (DTR) work correct with MMVARI in AFSK mode
    FSK was on COM7 (RTS) work correct with MTTY in FSK mode (with external FSK)
    No CW port was configured. (NO CABLE)
    Just put in the RADIO SETUP window the choice of PTT line for the voice keyer.
    VOICE PTT --> like CW PTT....or like MMVARI PTT
    In fact the voice is transmitted through the sound blaster as for the psk31 in AFSK.
    I hope it is possible, I await your confirmation.
    Thank you.
    73 de IK2XDE Andrea
  11. #311
    03.02.2006
    20,682
    10185
    5463
    Well, I think - this is right:
    when you use Voice macros, MMVari is not work and COM7 is free.
  12. #312
    03.01.2021
    196
    18
    Yes, if I use only one radio, but CW/PTT set on COM5,
    was connect to the second radio IC-7600
    (Yes I have two ICOM IC-7600) that work simultaneously. (of course with filter and different antenna....hi..)
    COM 2 for CAT
    COM 5 for CW on IC-7600 (1)
    COM 7 for SSB and DIGI on IC-7600 (2)
    all configured as RADIO1
    on RADIO2 I have SunSDR2DX with TCI
    My station was Multi TX and Multi Operator
    IK2XDE Andrea and my brother IK2XDF Gianpaolo
    Thanks for attention.
  13. #313
    03.01.2021
    196
    18
    Hello, using LogHX v3.0 build 636
    Start log with /D=IK2XDE
    Select view template,
    show template in C:/LOGHX/Views and not template in C:/LOGHX/IK2XDE/Views
    I thinks correct is: if I start with /D=IK2XDE will show template in C:/LOGHX/IK2XDE/Views
    I thinks correct is: if I start with /D=IQ2LZ will show template in C:/LOGHX/IQ2LZ/Views
    I thinks correct is: if I start with /D=IK2XDF will show template in C:/LOGHX/IK2XDF/Views
    All operators can have different display choices based on the operating mode and personal choices.
    SAVE TEMPLATE work correct and save template in the correct directory, but Select template show always default directory.
  14. #314
    03.01.2021
    196
    18
    Upload QSO to Clublog/Lotw/Eqsl
    If I select new function "Manually upload to server"...all work fine....!
    but at this point I think another step is needed.
    After creating the adif file ..... before closing the window .... the choice should be presented:
    Mark exported qso as SENT...... YES or NO
    Infact now, all qso exported to adif, was NOT marked as send.
    Thanks.
    COM 2 for CAT
    In this regard, it would be enough to have a separate configuration for the voice.
    CW / PPT
    MMVARI / PTT
    VOICE / PTT
    surely other colleagues will have different configurations
    73 de IK2XDE Andrea
  15. #315
    Low Power
    02.05.2021
    6
    Hi, who knows when the 705 will be supported for a CatHX configuration ?
    When I'm using LogHX with Win4IcomSuite and CWskimmer with Omnirig (The only way for cwskimmer), I,m not able to configure the IC-705 in LogHX with Omnirig (I have a violation). To bypass this issue I use the last version of Flrig that support the IC-705 for LogHX but it is not optimum. I have some trouble durng the initialization of LogHX and Flrig. After some time it works but it is not very friendly
    73s Christian F8GHE
    - - - Updated - - -
    Hi, who knows when the Icom IC-705 will be supported for a CatHX configuration ?
    73s Christian F8GHE
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
