Страница 57 из 68 ПерваяПервая ... 74750515253545556575859606162636467 ... ПоследняяПоследняя
Показано с 841 по 855 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #841
    26.10.2019
    46
    17
    9
    Prerelease build_759, Win10, Sleep Screen.
    Hello Alexei.
    In Windows 10, up to Test version 759 of 2024-April-24 the Sleep Screen function worked properly, but now with Prerelease build_759 of 2024-May-13 it no longer works.
    Is there any configuration to be done?
    Thanks for any guidance,
    73 from py5ej.
    Pavanatti.
  2. #842
    03.02.2006
    20,620
    10149
    5452
    Yes, now log controls that the computer does not go into sleep mode. If need, I can make this feature on/off.
  3. #843
    26.10.2019
    46
    17
    9
    Hello Alexei;
    Thank you for your attention.
    The on/off functionality would be great, thanks for implementing it.
    Sleep mode is useful for monitoring reception on the VHF bands (e.g. 2m, 6m), or on HF (e.g. 60m, 80m or 160m).
    Thank you for your dedication to the fine work of developing LogHX.
    73 from py5ej,
    Pavanatti.
  4. #844
    03.02.2006
    20,620
    10149
    5452
    Done - Setup->Default->add "Disable computer sleep mode" checkbox
    Reload -
    http://rx4hx.qrz.ru/files/loghx/prer..._build_759.exe
  5. #845
    QRPP
    20.01.2024
    7
    Hello,
    I still have a very long process of synchronisation with eqsl, clublog... ending with an error in "reading adif" And sometimes it's very quick without error. QSO numbers is not important. It can freeze at the first as at the 600th
    73, Thierry.
  6. #846
    03.02.2006
    20,620
    10149
    5452
    Hello! Show error printscreen.
  7. #847
    QRPP
    20.01.2024
    7
    Hello Alexei,
    I think that I've found the problem. The lhx2 file was stored on a cloud syncronised folder. I had multi conflicted .ldb files.
    What I did: I moved the database on a local drive and it seems ok.
    I will check lotw when it will be back.
    73, Thierry.
  8. #848
    QRPP
    17.05.2023
    7
    Dear Alexi,
    I have noticed a strange behavior with my micro KEYER III. At startup, I receive the following errors regarding the internal CW Keyer WinKey2 (see attached files). I have to press OK twice, and then the WinKey2 is recognized.
    I suspect that some routines are checking for the presence of the WinKey2.
    Just an FYI, and I hope you can provide a fix in the near future.
    73,
    HB9DHG Fulvio
    Изображения Изображения
  9. #849
    03.02.2006
    20,620
    10149
    5452
    Yes, it is, that's the reason. LogHX is slowly syncing with the cloud. The right decision -
    Do you use one or two Radios? May be do you setup WinKey for both Radios? (If use two Radio).
  10. #850
    QRPP
    17.05.2023
    7
    That's a good tip, Alexei.
    I'm using two radios. How I can disable the winKey on one radio and use it only on the second one?
    Thanks, Fulvio
    UPDATED: never mind Alexei,
    You pointed out to the right direction. I had to select RADIO 1 first, then disable WinKey.
    Everything is fine now and I do appreciate your help with my issue.
    Much appreciated!!!
    HB9DHG Fulvio
  11. #851
    QRPP
    13.04.2024
    8
    13
    5
    Цитата Сообщение от S50U Посмотреть сообщение
    The LogHX3 user mistakenly thinks that by turning on the "Skimmer" checkbox he will also receive skimmer spots. Enabling this option leads to a huge number of telnet retries (unknown command) and a headache for dx cluster administrators who consequently block the user from entering the dx cluster. Enabling RBN skimmer spots is done on the dx cluster itself.
    Is the problem fixed in the latest 761 as I don't see it written in the "Change log"? I only ask enough to inform the DXSpider sysop community. Alex keep up the good work.
    Dan S50U sys S50CLX
    https://s50clx.infrax.si
  12. #852
    03.02.2006
    20,620
    10149
    5452
    In the new version of the log (build 762), this setting will be "hidden" so that it cannot be accidentally enabled.
  13. #853
    21.07.2022
    80
    20
    LogHX build 761 issue?
    Hello,
    in the last version of LogHX I am noticed the problem:
    QSO from MSHV is written to log with ?????? as callsign, sometimes. Previous versions were OK, no ??????...
    73 de Josef, OK2WO
  14. #854
    03.02.2006
    20,620
    10149
    5452
    Yes, I am aware of this problem. Use the 758 version. There will be a 762 version soon. This problem will be fixed there.
  15. #855
    03.01.2021
    196
    18
    SunSDR2DX with ESDR 1.0.8 with LogHX build 762
    CW Macros from LOGHX work great with TCI
    Problem with SSB Macros from LOGHX - do NOT send audio via TCI
    How we can config it.....??
    NO TCI in the Output option.
    (Work correct with IC-7600+COM PTT and Audio from PC)
    Normally I keep only one band map open, the one relating to the radio I am using.
    Normally
    Radio 1 - ICOM IC-7600 - Band Maps 1
    Radio 2 - SunSDR2DX - Band Maps 2
    It would be nice if when I change the radio, the band maps would also change automatically,
    so if I am with radio 1 and switch to radio 2, it should automatically close band maps 1 and open band maps 2
    I don't know if it's possible and easy to implement, but it would be a nice utility
    Thanks for attention.
    73 de IK2XDE Andrea.
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
