Страница 46 из 68 ПерваяПервая ... 3639404142434445464748495051525356 ... ПоследняяПоследняя
Показано с 676 по 690 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #676
    03.02.2006
    20,680
    10184
    5462
    Цитата Сообщение от Jim Smith Посмотреть сообщение
    How does one get rid of the "-ZD4" ??
    "-" - Deleted country. Got here by mistake.
    For edit award use Awards window ->
    Цитата Сообщение от dannybgoode M0SDB Посмотреть сообщение
    I have been testing the click-select and on further testing it does not quite behave. If I select the first record and then scroll down to find the last record the first record becomes de-selected straightaway so I can only bulk select a group of QSOs if they are all displayed in the window at the same time. If I want to select say 200 from a contest I cannot do this.
    Yes, it's problem.... Ok, I will think about how to fix the problem.
  2. #677
  3. #678
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    User11-20
    Hello Alexei,
    (How) Can I rename User11-20 fields' name in Setup/QSL Status or somewhere. I would like to see it in Award window / QSL method window. To rename in the Log window is OK but it does not help.
    Thank you for your answer!
    73 Egon / HA3MN
  4. #679
    03.02.2006
    20,680
    10184
    5462
    You can rename User11..20 fields only in log-table. It will be possible to rename this fields in Setup-QSL status (if need).
  5. #680
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Thank you Alexei!
    In the log window I will see the renamed field, OK.
    In the QSL method window it stays as User11 but I KNOW User11 is what I want to see in log. So it is OK!
  6. #681
    26.07.2023
    41
    4
    Hi Alexei...
    Suggestion: - in the WW Locators map - would it be possible to be able to navigate around the fields by using arrow keys or buttons (up/down/left/right) instead of having to double-click to go back to the world map and select another field? In other words, to go from IO to JO, just click right. Would improve the useability of this window.
    Cheers!
  7. #682
    03.02.2006
    20,680
    10184
    5462
    Well, it's good idea! Will be done!
  8. #683
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Hello Alexei,
    Sorry to remember you but you did not say anything about that:
    #659
    07.06.2023, 09:41
    Thank you,
    73 Egon / HA3MN
  9. #684
    03.02.2006
    20,680
    10184
    5462
    #659
    07.06.2023, 09:41
    Hello Egon!
    For Radio - use this checkbox for save Radio setup in View
    For Rotor - not problem! Will be done!
  10. #685
    26.10.2019
    46
    17
    9
    Feedback (LogHX - Time synchronization function)
    Alexei, hi!
    Feedback.
    Here with Windows 10, Intel i7, and JTDX 160rc2, the time synchronization function does not work in the latest versions of LogHX v.3.0 build 734 and 735. I went back to version 733 and everything works normally.
    73 from py5ej,
    Pavanatti.
  11. #686
    03.02.2006
    20,680
    10184
    5462
    Yes, there are some problems with time synchronization. But I haven't figured out what's going on yet. I have now and in Windows itself synchronization does not work. I didn't change anything in the log to synchronize the time. I am dealing with this problem.
  12. #687
    25.07.2023
    10
    Is there a way of having two seperate configuration files/setups? The scenario is my normal call is M0SDB however I now have a second call for contesting, M3O.
    All my contesting will therefore be logged under M3O and I have another LoTW tSQL for it, QRZ page etc so I need to be able to configure LogHX to use those details when contesting. I have set up a new database for M3O however things like the LoTW settings, QRZ settings etc are shared with overall with M0SDB and ideally I would have two separate configuration files that would load with the connected database.
    There are ways of overcoming this but they are not ideal.
    Many thanks as always for any help
    de Danny M0SDB/M3O
  13. #688
    03.01.2021
    196
    18
    de Danny M0SDB/M3O
    Yes, you can start log as:
    ....\LogHX\LogHX3.exe /D=M0SDB
    ....\LogHX\LogHX3.exe /D=M3O
    You will have two different log in different directory, also with different configuration.
    73 de IK2XDE Andrea.
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  14. #689
    03.02.2006
    20,680
    10184
    5462
    By the way - check here:
    Setup->Default
    for set system time log must be have administrator right.
  15. #690
    25.07.2023
    10
    Many thanks Andrea - yes that works perfectly.
    73 De Danny M0SDB
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
