Страница 55 из 68 ПерваяПервая ... 54548495051525354555657585960616265 ... ПоследняяПоследняя
Показано с 811 по 825 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #811
    03.02.2006
    20,555
    10116
    5441
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    TCI problem with SSB Macro (SSB TCI macro from Expert work fine)
    About "SSB Macros via TCI" - this is in the plans. I need to get information from the developers of ExpertSDR.
    IC-7600 CATHX problem if (SETFreqA)
    I read letter from you, but I still did not understand: log itself does not use VFOB for split.
  2. #812
    03.01.2021
    196
    18
    OK we will wait....for now we will use "RadioMacros" from ExpertSDR
    OK, here you can find my two videos
    First video with SunSDR2DX via TCI al work fine, split operation and frequency correct in the log.
    https://www.xdenews.net/managers/files/1.mp4
    Second video with ICOM IC-7600 + CatHX Interface (WRONG FREQUENCY in split operation)
    https://www.xdenews.net/managers/files/2.mp4
    I hope this video help you for understand the problem.
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
  3. #813
    03.02.2006
    20,555
    10116
    5441
    ICOM IC-7600
    Many thanks for video! Now problem is clear for me.
    Here is problem with ini-file for IC-7600.
    LogHX have 3 INI-files for IC-600
    IC-7600.ini
    IC-7600v2-DATA.ini
    IC-7600v2.ini
    What file do you use? I think - file IC-7600.ini is wrong.
  4. #814
    03.01.2021
    196
    18
    IC-7600.ini
    IC-7600v2-DATA.ini
    IC-7600v2.ini
    OK, I use IC7600v2.ini
    Thanks.
    73 de IK2XDE Andrea.
  5. #815
    03.02.2006
    20,555
    10116
    5441
    Is now Ok?
    If you use IC7600v2.ini:
    may be need delete [INIT1] section!
    [INIT1]
    ;Turn CI-V transceive OFF
    Command=FEFE7AE0.1A050097.00.FD
    ReplyLength=16
    Validate=FEFE7AE01A05009700FD.FEFEE07AFBFD
  6. #816
    03.01.2021
    196
    18
    Is now Ok?
    [INIT1]
    ReplyLength=16
    No....IC-7600v2.ini NOT work correct.
    Yes, I just delete INIT1, this is old problem.
    No I investigate....try also IC7600 and IC7600-DATA,
    but all the tree file have the same problem.
    I will make some modify, but I don not understand about CAT command in the INI file.
    Anyway correct file was IC-7600v2 because I have v2 firmware in the radio.
    73 de IK2XDE Andrea
  7. #817
    03.01.2021
    196
    18
    Well, I find a solution.
    after some test and mods on the original file ini, I have solved the problem deleting
    [STATUS 10] from the file.
    ; - Removed pmVfoA and pmVfoB when both pmFreqA and pmFreqB are available.
    ;[STATUS10]
    ;Command=FEFE7AE0.07D2.FD
    ;ReplyLength=15
    ;Validate=FEFE7AE007D2FD.FEFEE07A.07D2.00.FD
    ;Flag1=00000000000000.00000000.0000.01.00|pmVfoB
    ;Flag2=00000000000000.00000000.0000.0F.00|00000000000000.00000000.0000 .00.00|pmVfoA
    Now all work correct, ISO qso and SPLIT qso will be stored in the log,
    with the correct RX Freq. and also correct TX Freq.
    This is my personal file.
    http://www.xdenews.net/managers/files/IC-7600v2-XDE.ini
    If anyone else owns an IC-7600 please test it, and report any malfunctions to me.
    For me everything seems to be working fine now.
    73 de IK2XDE Andrea
  8. #818
    26.07.2023
    41
    4
    Changing radio
    Hi Alexei,
    How easy would it be to place a button on the log input screen to change radio from Radio 1 to radio 2? Perhaps a Button that says R1 or R2 that can be toggled?
    It would be much quicker and easier to change radios on the fly with a simple click instead of having to go into the menu to do it.
    Thanks.
  9. #819
    03.01.2021
    196
    18
    Цитата Сообщение от Jim Smith Посмотреть сообщение
    Changing radio
    Hi Alexei,
    Thanks.
    Hi Jim, to do this I found it convenient to use a HotKey (IdKeys900 - Change Active Radio),
    but it would actually be useful to have a button, and perhaps also add the change of the relevant BandMap
    Then Switch between Radio 1 and Radio 2 and Switch between BandMap1 and BandMap2.
    We hope that Alexey finds this request useful and easy to apply.
    73 of IK2XDE Andrea
  10. #820
    26.07.2023
    41
    4
    73 of IK2XDE Andrea
    Thank you Andrea, I will look into that. Need to work out how I make that work.
    Do I literally put "IdKeys900" in the window next to the hotkey that I want to use?
    - - - Updated - - -
    it's OK, I've sussed it now! Better than navigating to a button to be honest, now using Numpad and .
  11. #821
    03.01.2021
    196
    18
    Menu -> HELP -> Hot Key's
    Than score and find IdKey900 that will be "Change Active Radio"
    In the HotKeys field put key that you prefer.
    Be careful that the key combination is not already used by another function.
    73 de IK2XDE Andrea
  12. #822
    03.02.2006
    20,555
    10116
    5441
    Well, I think - it's good idea: allow user to choose -auto-switch Bandmap1 to Bandmap2 when Radio switching (will be one Bandmap) or two Bandmaps for each Radio.
  13. #823
    26.07.2023
    41
    4
    Any way to increase the "capacity" or store of DX spots?
    During busy contests, spots are disappearing from the list in less than 10 minutes, even if the life has been set to 120 minutes.
    Been looking for a setting to change but can't find it.
  14. #824
    03.02.2006
    20,555
    10116
    5441
    Use SpotMachine filter -
    for country
    or another filter.
  15. #825
    03.01.2021
    196
    18
    Here's a little request for future changes
    Send spot via telnet --> Insert macros in info
    Please add [submode] field
    Thank you.
    In this regard, I think that in a very busy contest like a CQ WW the time limit to use is 20 minutes,
    no more, 120 minutes is too much...we're talking about thousands of spots per minute.
    But anyway what is the real limit set in loghx...??
    Is there a maximum number or not..??
    73 de IK2XDE Andrea
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
