16.01.2024, 12:26 #751Low Power
- 19.11.2019
- Nyirabrany
- 11
- 43
Thank you for everyone for the helps!
Unfortunately, my PC broke down, so I am now working with a laptop.
I reinstalled all of LogHX, everything works fine now!
Thank you again!
73 Egon
- - - Updated - - -
Hello Vlado,
Thank you for this info! I did not know it!
You told me a new thing again!
Thank you for your help Vlado!
73 Egon
16.01.2024, 17:29 #752QRPP
- 16.01.2024
Hi LogHX3 friends from Steve G0UIH
From V745 onwards.
Changing database [I have 12 current good databases] – error as below.
Database[s] won’t open from within the app.
Fix is to quit the program and then re-open.
Program then requests you to pick a log from the database you have just tried to open.
This works [as a workaround] and the d/base opens.
Databases are all ‘Good’ and open fine in MS Access without issues.
No anti-virus or protection enabled
All was good on versions before V745
Error message = “Open ADO Connection Error”.
I was looking to see if this is ODBC related but LogHX3 does not seem to use any ODBC entries.
Running now V750 and error still exists.
Any thoughts
Very 73 – Steve G0UIH
16.01.2024, 18:00 #753Координатор темы
- 03.02.2006
- 53
- 20,631
- 10151
- 5453
It's strange. Send base to rx4hx@mail.ru - I'm check it!
Ant.: UW4HW, Pwr.: ~500 Wtts
17.01.2024, 22:26 #754Standart Power
- 03.01.2021
- 196
- 18
CAT problem with build 750
With this version CAt not work.
CATHX + IC7600v2
Return to build 749 all work fine.
Thanks for attention.
73 de IK2XDE AndreaIK2XDE Andrea - WWLoc. JN45MQ
https://www.xdenews.net/ik2xde/logonline/
RADIO Setup (update 30/08/2025)
ICOM IC-7600 - (HF - 50MHz.)
SunSDR2DX - (HF - 50MHz. - 144 MHz.)
OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
OB11-3 (11 element - 3 band - 10m-15m-20m)
OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
SkyWire Loop (40-60-80-160 m.)
LogHX Managers Database (update for free)
https://www.xdenews.net/managers/
17.01.2024, 23:29 #755Координатор темы
- 03.02.2006
- 53
- 20,631
- 10151
- 5453
Fixed -
http://rx4hx.qrz.ru/files/loghx/LogH..._build_751.exe
Pse QRX! Looking for a problem!
Fixed:
http://rx4hx.qrz.ru/files/loghx/LogH..._build_751.exe73 de RX4HX, Alexei, http://rx4hx.qrz.ru
18.01.2024, 01:12 #756Standart Power
- 03.01.2021
- 196
- 18
OK confirm.
With build 751
CAT work fine (like before)
Thanks.
73 de IK2XDE Andrea
Managers update ....!!
Available to all users
18.01.2024, 15:37 #757QRP
- 07.07.2023
- 16
[OFF-TOPIC] Icon for my QRZ.com page
Alexey, it is ok to use this picture on my QRZ.com page?
Do you see any problem?
18.01.2024, 18:15 #758
18.01.2024, 20:08 #759
18.01.2024, 20:28 #760Координатор темы
- 03.02.2006
- 53
- 20,631
- 10151
- 5453
18.01.2024, 21:43 #761Standart Power
- 03.01.2021
- 196
- 18
This is the least we can do to contribute to the best development
of the software you have made available to us for free.
A small clarification, which you can correct in future versions,
in the whatsnew.txt file indicate the version of the program as Ver. 3.1 build 751 (17 January 2023 y.)
but in reality in the program, both in the logo and in the info, everywhere it says v 3.0 and not v3.1.
It's a small nitpick, but it's worth fixing.
Thanks again for the great work you are doing.
19.01.2024, 13:01 #762Low Power
- 19.11.2019
- Nyirabrany
- 11
- 43
19.01.2024, 15:42 #763Standart Power
- 03.01.2021
- 196
- 18
>Hello Andrea,
>I tried to save your website for the update instructions but right-click does not work.
>I used a online converter to do it.
>73 Egon
Here pdf file.
LogHX - Managers database by IK2XDE & IK2XDF.pdf
19.01.2024, 20:20 #764Low Power
- 19.11.2019
- Nyirabrany
- 11
- 43
As I said, I downloaded the website with a online converter.
That is same as yours!
Thank you for your helping Andrea!
73 Egon
PS: I do not use the QSL manager database but I help to others to get the best within LogHX!
I recommended and helped to install the LogHX* to others. QSL Manager system makes it better.
* (the Best of bests)
Последний раз редактировалось HA3MN; 19.01.2024 в 20:26.
20.01.2024, 14:26 #765QRP
- 26.07.2023
- 41
- 4
Hi Alexei,
One oddity with all recent versions since at least 732 - keep meaning to mention this.
The Awards window... I set the fonts to optimum for my display. I close down the software and restart, and on restarting, the fonts are much larger. Shut down and restart again, and the fonts come back bigger still. Both the General (typo "Genegal" in the menu ) Table fonts and the Title/worked/confirmed. Very strange. I have to adjust them back each time I restart.
I guess it's something to do with the user-set fonts, (I was the one who asked for the size to be made variable) maybe everyone else has the default size and are unaffected.
- - - Updated - - -
Just to add that the Band Review windows are similarly affected, exacerabted by the need that one has to reset each column individually......
167Спасибо
