Страница 38 из 68 ПерваяПервая ... 2831323334353637383940414243444548 ... ПоследняяПоследняя
Показано с 556 по 570 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #556
    03.02.2006
    20,680
    10184
    5462
    Цитата Сообщение от F8GHE Посмотреть сообщение
    Thanks very much and have a nice sunday !
    Thank you also for your help in finding the problem!
  2. #557
    Low Power
    16.04.2020
    89
    3
    I am looking at putting my World Castles Awards in the log, esp the English castle awards.
    I've got the basic reference numbers, I wonder if its possible to get the actual name in there also?
    Also for 1 QSO where they have multiple references, how can we get the log to recognise this? I have given User7 to WCA references in my log, it reads great for only one reference, but for multi refs it doesn't, could it be read by comma seperated values?
  3. #558
    03.02.2006
    20,680
    10184
    5462
    No, for user-awards use only reference numbers.
    By the way - awards statistic is letter-case sensitivity. G-12345 and g-12345 - is different numbers!
    multiple references
    Also - no. For two reference write in log two QSO.
  4. #559
    Low Power
    16.04.2020
    89
    3
    Thanks Alexei for the quick reply. Yes I am going through all my logs just tieing up the references from the e-log on the castles site and correcting the G. I haven't really looked at using the awards properly yet. My next target is getting FLdigi and CW set up properly as I am getting back into CW and want to try PSK31 again.
    Spelling update under "Utilites" should be "Utilities" and then "Advancent Search" should be "Advanced Search"
    "Non Standart callsign" should be "Non Standard Callsign"
  5. #560
    03.01.2021
    196
    18
    Hi Alexey, as always thanks for your constant work to update the log.
    Unfortunately with version 708 and 709 we lost the automatic sending of QSOs on clublog.
    Back to 707 everything works fine, I also tested other logs and there doesn't seem to be a problem from clublog,
    so the problem seems to be LogHX with automatic clublog disabled.
    (in fact in the general setup the checkbox for automatic sending has disappeared).... is it a mistake.....?
    Is there some reason unknown to us...??
    It's a shame was one of the great features of this log.
    Thanks for answer.
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  6. #561
    03.02.2006
    20,680
    10184
    5462
    It's new Clublog rule - send more then 1 QSO.
    Please wait until the situation is clarified.
  7. #562
    Low Power
    02.05.2021
    6
    [QUOTE=F8GHE;1912424]After a good night everything is working
    (Check setup and Restart DXLOG and LogHX)
    73s Christian F8GHE
    Hi, here i a very simple Howto to connect LogHX to DXLog.
    ATTACH=CONFIG]332573[/ATTACH]
    Вложение 332571
    73s Christian F8GHE
    - - - Updated - - -
    [QUOTE=F8GHE;1920566]
    73s Christian F8GHE
    73s Christian F8GHE
    With the correct file
    Вложения Вложения
  8. #563
    Low Power
    02.05.2021
    6
    Hi, here it's a very simple Howto to connect LogHX to DXLog.
    Hi, here it's an update (V2) with some corrections of a very simple Howto to connect LogHX to DXLog.
    Вложения Вложения
  9. #564
    03.01.2021
    196
    18
    I'm sorry I can't help you, but I couldn't find any news about it.
    Sending real time QSOs was essential for the proper functioning of live streams
    whose instructions can be found here: https://clublog.freshdesk.com/suppor...g-live-streams
    In fact if you continue to use the 707 version everything works correctly, without errors like other logs,
    I don't receive errors and reports from clublog.
    I don't see why LogHX should disable this feature when all other logs use it without any problem.
    Try to enable real time automatic sending again, and see if the clublog authors report the bug or the problem.
    Thank you.
  10. #565
    Low Power
    02.05.2021
    6
    Thank you.
    Hi, I also regret this feature
    With the last Prerelease version 712 is the "Automatic send" to ClubLog OK like with the previous release version 707 ?
    73s Christian F8GHE
    - - - Updated - - -
    73s Christian F8GHE
    It seems that LogHx is not in this list of softwares that support QSOs upload in realtime to ClubLog:
    https://clublog.freshdesk.com/suppor...ltime-uploads-
    from this page https://clublog.freshdesk.com/suppor...g-live-streams
    Maybe could be add ?
    73s Christian F8GHE
  11. #566
    03.01.2021
    196
    18
    Unfortunately even with version 714, automatic upload is disabled.
    I hope Alexey will quickly fix this important function.
    Many other software works fine...how did they fix it...?
    Let's try to contact the clublog manager to verify the problem..??
    Alexey thank you in advance for the time you will spend on this.
    Thanks.
    73 de IK2XDE Andrea
  12. #567
    03.02.2006
    20,680
    10184
    5462
    LogHX don't use Club Log Live Stream uploads. Like here -
    But log can use this URL to upload QSO in realtime:
    https://clublog.freshdesk.com/suppor...-into-club-log
    Ok! I restore realtime uploads.
    ... Done -
    http://rx4hx.qrz.ru/files/loghx/prer..._build_714.exe
  13. #568
    Low Power
    02.05.2021
    6
    ... Done -
    Hi Alexei, Thanks very much for your help and the new release 714.
    I had not seen these articles before and I don't know what to think about them
    I hope everything will be easier next year
    Happy New Year.
    73s Christian F8GHE
  14. #569
    Low Power
    16.04.2020
    89
    3
    Happy New Year all!
    Looking for advice from you users on the CW set up in LogHx.
    At the moment, I have only used for normal logging and with WSJTX, I have different views to suit each.
    I did have it working a long time ago with PSK31 but my set up has changed and I am still trying to get it to work, I think its an FLDigi issue.
    My main question is using CW windows for Morse code. I am getting back into CW so both my sending and recieving are slow! So I am looking at creating a view to decode CW and maybe have the keyer enabled but I really plan to use my paddle again. Is there a good set up for CW that anyone can share that I could try?
    Thanks!
  15. #570
    26.10.2019
    46
    17
    9
    Report on version 3.0 build from 708 to 715
    Hello, Dear Alexei - RX4HX
    Best wishes for a Happy New Year to you and all group members.
    Report on version 3.0 build from 708 to 715 (on previous builds including 707 was normal).
    Randomly when I try to edit a QSO, the PC crashes, to restart it you have to turn off the power.
    I use Windows 7 Ultimate Service Pack 1, Intel i7-3770 CPU @ 3.40GHz, 64Bits.
    73 and Happy New Year for all, from py5ej;
    Pavanatti.
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
