Новые SDR от FlexRadio (6600 и 6600M)
FLEX-6500 A Real SDR for Every Operator
Both the FLEX-6600™ and FLEX-6600M™ offer the ultimate performance direct sampling SDR technology and the best value for the serious HF/6m operator. The FLEX-6600 model is designed for the Ham who wants to operate the radio exclusively as a server from PC, laptop, Maestro, Mac, or iOS clients – whether local or remote. Both models share the same game changing band awareness, industry leading phase noise performance/ receiver dynamic range, and brick wall filters to give you the advantage in the most competitive DXing or contesting activities while maximizing your fun in casual operations. With a PC, laptop, or Mac client, you can utilize up to four 14 MHz spectrum/waterfall displays and independent band/ mode receivers to revolutionize your view of the bands, especially on digital modes.
Contest grade filters, ultra low spurious emissions, and the ability to operate full duplex cross band on two antennas let you transmit on one band while receiving on another – no external equipment required. Even switch to synchronous diversity reception when needed to help you pick out the weak ones in the midst of QRM. By adding FlexRadio’s new PowerGenius XL LDMOS solid state amplifier a complete legal limit, all mode SO2R station is now practical with one radio, one amp and only three interconnect cables – half the cost and none of the complexity.
The FLEX-6600M places the most used controls right at your fingertips. Controls are labeled for intuitive operation and designed to minimize hand motion for the most common operations. Occasionally used controls are easily accessible on the large touch screen display bypassing the complexity of multi-function buttons and multi-level menus found on other transceivers. Like modern smartphones and tablets, capacitive touch control is provided on the large LCD display for intuitive pan, zoom, tune, and menu operation. The FLEX-6600M controls are designed to provide maximum tempo in the most demanding applications including SO2R, Run, S&P, and Multi-op contesting.
Подробнее ...
