20.06.2010, 13:13 #31
- 03.04.2002
- Химки, Московская обл.
- 71
- 5,371
- Записей в дневнике
- 8
- 920
- 1393
Михаил.
Обнови прошивку базового блока на своём FTM-350.
Вот какие версии должны быть.
См. ссылку и на файлы находящиеся по этой ссылке (закладка 'Files').
Далее см. Amateur Radio Software :: FTM-350R (USA) Update Software Ver 1.1 (6/16/10) ( 873.98 KB )Последний раз редактировалось UA3IRS; 20.06.2010 в 13:40.
[SIZE=1][FONT=Verdana]73. Сергей ([B]UA3IRS[/B] aka [B]UR3IRS[/B]) :ru: :: OnLine: [url=facetime://ur3irs@gmail.com]FaceTime[/url], [url=callto://ur3irs]Skype[/url], [url=xmpp://ur3irs@gmail.com]Jabber[/url] :: Web: [url=twitter.com/ur3irs/]Twitter[/url], [url]aprs.ru[/url], [url]echolink.ru[/url], [url=https://www.flickr.com/photos/ur3irs/sets/]Flickr[/url], [url]ur7iwz.qrz.ru[/url][/FONT][/SIZE]
20.06.2010, 14:53 #32
- 03.04.2002
- 71
- 5,371
- 8
- 920
- 1393
Информация по прошивкам для базового блока YAESU FTM-350:
Version UP history
The past contents of Version UP are as follows.
* Version 1.1 (2010-июнь)
- Enabled to indicate the model name "VX-8G" when receiving a position packet from a Yaesu "VX-8G" transceiver.
- Corrected a problem where under certain circumstances the transceiver would lock up when receiving a "NAVITRA PACKET".
- Corrected a problem when an APRS message is being read using the FVS-2. If you transmit during this time the transmitted audio would be muted until the FVS-2 completed reading the message.
- Corrected the model name displayed when a position packet was received from a Kenwood "TH-D7" transceiver.
- Corrected a compass error in the south latitude/west longitude directions when using the Heading UP display.
- Corrected a state of the compass display mode of an APRS position packet may not be held.
- Corrected a fault where if SET MENU G03 is set to (AUTO STEP) and if the SQL type is changed the VFO step rate would default to 5 kHz steps.
- Changed a control so that the SQL port output signal of a Data jack might be interlocked with a TSQ/DCS signal.
* Version 1.0 (2009-декабрь)
Initial VersionПоследний раз редактировалось UA3IRS; 20.06.2010 в 15:23.
21.06.2010, 12:29 #33
- 10.06.2005
- Химки, Московская обл., Россия
- 41
- 709
- 149
- 45
Сергей, а можно ли сохранить копии каналов памяти на компьютере для дальнейшего восстановления? Я так понял, что после установки обновления нужно сделать общий сброс! Что совсем не хочется делать. Я 200 каналов памяти вбивал в ручную! убил на это 2.5 дня. Около 70% всех каналов - Московские и подмосковные ведомственные службы, которые используют разносы по приему и передачи с кодами и тонами. Эту информацию я собирал (сканировал долго и кропотливо) 7лет, пока в моих автомобилях стояло УКВ радио. Копии есть и на бумаге и на FT-60R и FT-7800, но опять потратить столько времени на восстановление памяти
Михаил (RW3DKE) :: Связь - это как воздух. "Когда есть - не замечаешь, а когда нет - задыхаешься!"
23.06.2010, 02:41 #34
- 10.06.2005
- 41
- 709
- 149
- 45
Последний раз редактировалось RW3DKE; 23.06.2010 в 02:48.
23.06.2010, 07:24 #35
- 23.07.2009
- Москва_кантемировская
- 3,522
- 574
- 552
23.06.2010, 09:02 #36
- 03.04.2002
- 71
- 5,371
- 8
- 920
- 1393
24.06.2010, 21:06 #37
- 03.04.2002
- 71
- 5,371
- 8
- 920
- 1393
Два последних сообщения удалены. Эмоции тут не к месту.
Да и не по теме топика они.[SIZE=1][FONT=Verdana]73. Сергей ([B]UA3IRS[/B] aka [B]UR3IRS[/B]) :ru: :: OnLine: [url=facetime://ur3irs@gmail.com]FaceTime[/url], [url=callto://ur3irs]Skype[/url], [url=xmpp://ur3irs@gmail.com]Jabber[/url] :: Web: [url=twitter.com/ur3irs/]Twitter[/url], [url]aprs.ru[/url], [url]echolink.ru[/url], [url=https://www.flickr.com/photos/ur3irs/sets/]Flickr[/url], [url]ur7iwz.qrz.ru[/url][/FONT][/SIZE]
24.06.2010, 22:59 #38
- 10.06.2005
- 41
- 709
- 149
- 45
Ну что Россияне, сообщил мне 'Компас-Р', что приехали к ним YAESU FTM-350. И поставили их по цене 925$ в розницу. По сегодняшнему курсу получается - 28648 руб. Так что все на Митинский, покупать за 21500 руб.
Только FVS-2 к ним не приехала. Придётся мне её купить в Нью-Йорке в США. 8))Последний раз редактировалось UA3IRS; 24.06.2010 в 23:04.
16.07.2010, 13:53 #39
- 10.06.2005
- 41
- 709
- 149
- 45
Заметил я тут вот что. Мне необходимо складывать антенну COMET CSB-7900, перед парковкой на подземной стоянке.
Помогает мне в этом DIAMOND K-9000 Автоматическое антенное крепление -
http://forum.ci-bi.ru/viewtopic.php?f=10&t=1892
После складывания антенны и заезда внутрь у меня не с того не с сего вырубалась станция! Я не понимал - почему? Проверил несколько раз питание идущее к станции, все в порядке, сделал я там все наверняка! И меня это забеспокоило пока я не сложил антенну вне стоянки. Произошло тоже самое. Меня осенило! Этож защита по КСВ! При высоком КСВ после срабатывания на передачу - станция вырубается! А передача у меня включается при посылки APRS пакета. Станция перестает передавать пакеты как только прекращается GPS сигнал, но в течении 15-ти сек. после въезда на парковку станция еще думает, что GPS сигнал есть и посылает последний пакет, при котором и происходит отрубон.
На предыдущей станции FT-7800 я такого не наблюдал. Эта станция как кирпич, перестанет работать только после прямого попадания снаряда, а на FTM-350 Yaesu-цы отнеслись с предосторожностью от шаловливых ручек.
Вот как-то такПоследний раз редактировалось UA3IRS; 20.07.2010 в 20:01.
20.07.2010, 19:36 #40
- 26.05.2009
- Ступино
- 421
- 139
- 104
ftm-350 намбер ту
Обзавёлся этим приятным девайсом и пользуюсь второй день.
Человечачья модель во всех отношениях.
Мужская кандовая двухдиапазонная мобильная радиостанция.
Начиная с глазастой панели управления из йесувского "антивандального пластика" с неписюлишными внятными кнопками и ручками и заканчивая main unit тяжёлым цельнометаллическим железным кирпичом холодным на ощупь.
На разбирательство и первую настройку с небольшим подглядыванием в английскую инструкцию(русская есть на yaesu.ru) хватило минут 30. Забитие в память репитеров нужных частот и конечно настройки(не тонкой, но работающей) APRS.
Пока первые впечатления очень не плохие. Дальше буду искать к чему придраться и пожурить.Андрей, RZ3DHN
20.07.2010, 19:45 #41
- 10.06.2005
- 41
- 709
- 149
- 45
Ну наконец-то дождался я помощника в тестировании этого железа. Андрей если что-то ты там найдешь, того что я не углядел, чур сразу расскажи про это!
21.07.2010, 13:27 #42
- 10.06.2005
- 41
- 709
- 149
- 45
Еще я заметил вот что (может кому и пригодится):
Мой автомобиль ночует на подземной стоянке. Вечером я заезжаю, а с утра на след день выезжаю. После парковки более чем на 1 час в месте где не возможен приемом GPS сигнала со спутников, траектория спутников меняется кардинально и поиск спутников занимает достаточно продолжительное время. Иногда до 15мин. А вот если оставить авто с выключенной станцией под открытым небом (хоть на ночь), после включения станция сразу показывает свою позицию (координаты). Видимо, (как я понял) питание идущее от станции к FGPS-1 (GPS антенна) не прекращается и слежка за спутниками продолжается даже при выключенном трансивере. Это приятно для пользователей APRS системы, включил, поехал и пакеты отправляются сразу. Не надо ждать начала работы со спутниками.
И еще есть информация для людей у которых нет возможность спрятать свой автомобиль от вандалов.
В арсенале FTM-350 есть переходник CT-133
Который можно приспособить на CT-136 (он еще на VX-8R используется)
И во все это воткнуть FGPS-2 ( тож от 8-ки)
При таком железе можно спрятать выносную панель хоть под сидение и вывести в район лобового стекла GPS антенну не боясь вандалов.Последний раз редактировалось UA3IRS; 21.07.2010 в 21:40.
22.07.2010, 14:26 #43
- 26.05.2009
- Ступино
- 421
- 139
- 104
прошивка
Есть новая прошивка v1.1 на сайте yaesu.com на радость потребителя прошить станцию можно напрямую через com порт компьютера.
Из подручных средств был собран провод. Проводки без разъёма воткнуты в станцию. Их всего три txd rxd gnd. Рекомендую прошивать с компьютером который имеет com порт, а не использовать переходники usb-com.
Версии прошивок для модификаций AUS EXP и USA. У меня EXP(указывается на коробке где штрих код).
Следуя инструкции (см. подробные картинки в хелп приложении, оно в файле с прошивочной программой) надо открыть станцию отключив её, перевести переключатель внутри в положение PROG. Нажать в программе на апдейт и подождать пока бегунок в программе два раза пробежит по 100%. Далее выключаем станцию, переводим выключатель в положение NORM и вуаля версия 1.1. Производитель пишет, что надо делать полный ресет через меню после прошивки. Все забитые настройки станции стираются.
Производитель предупреждает не прошивать станцию не соответствующей версией. Если вы ошиблись станция после процедуры прошивки выдаст на табло FIRM ERROR. Это не страшно. Прошиваете своей прошивкой и всё будет работать.
В версии EXP нет передачи на 220mhz. Американизировать станцию можно запайкой ещё одной перемычки возле процессора(о расположении перемычек в теме есть фото)
Наблюдения показали, что вы теряете часть приёмных частот в диапазоне 7xx мГц-800xx мГц. для американской версии эти частоты блокированы. Также при первом запуске будет кривой шаг на фм приёмнике(что поправимо меню step) и в настройках везде надо менять на метрику футы дюймы и тд. Я поставил всё обратно, мне лучше сплошной приёмник без дырок. Американскую станцию думаю тоже можно сделать европейской убрав первую перемычку от процессора оставив только одну 3-ю.(единственно прошивать её надо версией USA)
Возвращаясь к com порту станции могу сказать что с помощью гипертерминала можно выводить со станции строчки принятого пакета так и данные в gps формате, если установлен gps приёмник на станцию. всё это добро можно поочерёдно включать через меню станции.
Коллеги из иностранных форумов писали письма производителю мол слабо сделать tnc станции в KISS режим благо всё для этого есть. Yaesu пока брыкается.
p.s. В станции монтаж деталей мелкосотовотелефонный поэтому будьте очень аккуратны.Последний раз редактировалось RZ3DHN; 22.07.2010 в 14:50.
Андрей, RZ3DHN
22.07.2010, 19:17 #44
- 10.06.2005
- 41
- 709
- 149
- 45
03.08.2010, 15:42 #45
- 26.05.2009
- Ступино
- 421
- 139
- 104
dtmf
Интересно можно ли регулировать длину dtmf посылки?(может как то программно). Слишком быстро цифры набирает из памяти в Эхолинк и часто набор ошибочный.
Последний раз редактировалось RZ3DHN; 03.08.2010 в 15:46.
Андрей, RZ3DHN
