08.09.2025, 06:51 #691QRP
- 02.10.2012
- 28
- 7
08.09.2025, 11:16 #692Very High Power
- 13.03.2003
- Лениногорск РТ
- 4,743
- 2153
- 1650
У них огромные финансовые потери вна Украине.
08.09.2025, 12:12 #693Very High Power
- 26.09.2007
- 4,927
- 6866
- 1611
Нет, это, или глюк, Или специально задуманная проверка.
Они уже сделали рассылку на эту тему, как это обойти:
We’ve received some questions regarding licensing after upgrading to SmartSDR v3.10.10, and we’d like to provide clarification.
If you previously purchased a SmartSDR v3 license, you do not need to pay for a new one. SmartSDR licenses do not expire.
If you are upgrading from SmartSDR v1 or v2, you will need to purchase a v3 license to use SmartSDR v3.10.10.
As part of the installation process, SmartSDR v3.10.10 is re-validating the existing software license by querying the FlexRadio license Server. In most setups, this happens automatically and is a 1 time event to update its internal database.
Once the radio has validated the license, a license validation will not be needed until a new license is purchased.
However, if you operate your radio in a Link-Local configuration (with the radio connected directly to your computer or Maestro via CAT5 Ethernet cable), the license validation check will fail. This is usually identified with the IP Address of the radio starting with a 169.xxx.xxx.xxx.
This is due to the radio not having access to the Internet and not being able to connect to the SmartLink licensing server. Even if the PC or Maestro has access to the Internet, the radio will not.
To resolve this:
Power off the radio.
Connect the Ethernet interface on the radio to your Internet router or an Ethernet switch that is connected to your router using a CAT 5 or greater Ethernet cable.
Reboot the radio.
As part of the boot process, the radio will query the license server, download the license validation key, and store it in the radio. By the time the radio completes the boot process, it should have the validation key downloaded and stored.
You can test this by running SmartSDR v3.10.10 on the PC (assuming it has access to your router), and you should be able to see and access the radio. It should no longer ask to purchase a license.
Once this is done and verified, if you need to reconnect the radio to your PC with a direct Ethernet connection, you will not have any future SmartSDR v3 license issues.
If you continue to experience licensing issues after following these steps, please open a HelpDesk support ticket, and our team will assist you.
08.09.2025, 14:46 #694
08.09.2025, 16:31 #695Very High Power
- 26.09.2007
- 4,927
- 6866
- 1611
Я обновил наши два (из шести) трансивера на 3.10.10
Те, которые стоят на удалёнке.
По причине того, что в 3.10.10 Флекс наконец-то, после 20 лет просьб и мольб пользователей, сделал самоконтроль в телеграфе при удалёнке при манипуляции по винкей из стороннего лога.
Это эпохальное событие (без шуток)
Сбылась мечта !
09.09.2025, 06:48 #696High Power
- 25.07.2016
- Lappeenranta
- 654
- 1523
- 1344
Последний раз редактировалось OG7F; 09.09.2025 в 06:55.
73! Евгений RK3AD/OH5DA/OG7F
09.09.2025, 07:57 #697QRP
- 02.10.2012
- 28
- 7
09.09.2025, 08:05 #698
26.09.2025, 14:32 #699High Power
- 11.07.2003
- 44
- 879
- 22
FlexRadio выкатили новую политику ПО. Начиная с 4 версии ПО будет платным, по модели подписки на 12 мес. Бесплатными будут только багфиксы, все новые и улучшенные функции будут платными. Народ взбунтовался, потому что не работает APD и есть вопросы к NR/NB. Также в 3.10.10 после 10 багфиксов добавили 10 новых багов, и получается, что в целом владельцев держат за бета-тестеров, и теперь еще и начинают просить за это деньги. Часть народа радикально настроена и начали саботировать FR, уходя на ANAN и классические трансиверы с преобразованиями.
Вообще, конечно, это ни в какие ворота, с учетом того, что довести ПО до стабильного состояния они не могут. Но лавры Apple и бизнес по модели SaaS не дает им покоя. Они хотят и продать аппарат, и иметь постоянные отчисления от владельцев.
Из-за последних отзывов на FB, комментировать там они как бы перестали, и пытаются вернуть сообщество владельцев на свой форум. Но это у них получаются плохо, так как на FB им напихали полную панамку, и подавить волну негатива они не могут. Конечно, россиянам в целом на это пофиг, вряд ли кто-то будет платить за это ПО, ну или 1-2 человека, но все же это тревожное и неприятное событие. Рожденные в СССР не приемлют модель попдписки, и многие в восточной Европе тоже - не тот менталитет. Я лично не против платить за ПО, но когда там нет глюка на глюке.
А тут еще и выяснилось, что с APD они по сути обманули людей, и функци не работает даже без УМ. С внешним же УМ она точно работать не может, и это не скрывается. Есть мнение у нескольких членов сообщества, что у FR пока вообще нет технологии APD. То есть, речь идет про обман (осознанное введение в заблуждение), но пока еще никто не придумал судиться.
Да, для старых аппаратов сообщение об оплате уже вылезло. Вообще же на 6000 серии и ниже, судя по отзывам, сплошной глюкодром, видимо, хоть какое-то альфа-тестирование идет только на 8000 серии. На остальное уже забили. Основной ответ по глюкам на 6000 серии - сделайте ресет. После ресета часть проблем решается, часть нет. Далее просят создать тикет, но после создания тикета в нем тишина или его закрывают. Вопрос качества поддержки и ее этики также часто поднимается, и не находит ответа, что также стало отталкивать часть аудитории.Последний раз редактировалось RK3AAG; 26.09.2025 в 14:41.
Привет, канифольщики! - RK3AAG
26.09.2025, 14:53 #700Very High Power
- 04.06.2009
- Смоленск
- 1,595
- 422
- 341
Не раскачивайте лодку ! Как это они еще не выкатили платную подписку за пользование удаленкой .
Последний раз редактировалось UA3LM; 26.09.2025 в 15:03.
UA3LМ
26.09.2025, 15:24 #701
26.09.2025, 16:14 #702Standart Power
- 09.02.2021
- 400
- 85
- 47
Давно уже понять стоит, что любой софт, любое железо с прошивками должно активироваться (если покупное с ключами) и работать полностью автономно. Причем с самого начала никаких "одноразовых" позывов вылезти в сеть и где-то там что-то сделать не должно быть.
26.09.2025, 16:15 #703
26.09.2025, 16:20 #704Very High Power
- 26.09.2007
- 4,927
- 6866
- 1611
Какой-то жути нагнал RK3AAG своими личными комментариями, своим личным пониманием.
В рассылке Флекса все помягче.
Главное, что обновление на 4 версию будет бесплатным для всех.
А кто хочет платную подписку на под-версии, пусть платит.
Но это лохотрон.
Внутри большой версии мало что меняется.
За прошедшие лет 7 я даже не могу найти разницы между звучанием разных версий.
26.09.2025, 18:14 #705High Power
- 11.07.2003
- 44
- 879
- 22
Это не мое личное понимание, а то что написано в официальном релизе, и далее Майк дал комментарии по всем вопросам, которые ему успели задать другие пользователи + они уже запилили статью на сайте + FAQ. Научитесь собирать информацию, а потом делайте заявления. Если вы думаете что отпугнете 2 ваших клиентов, то навряд ли, любители FR слишком фанатичны, да и шила в мешке не утаить при любом раскладе.
Обновление на 4 бесплатное только для текущих пользователей v3.x (то есть у кого на нет сообщения о проэкспайренной лицензии), и только на v4 basic без новых функций и обновленных функций. Для пользователей v1.x и v2.x - только через кассу.
На v4.x чтобы получать новые или обновленные функции платим $199 или $299 долларов в год (199 получать обноление вместе со всеми, 299 - раньше всех, как только они разрабатываются; фактически речь идет о том, чтобы быть бета-тестером и платить на $99 больше).
Вся информация в свободном доступе:
https://community.flexradio.com/disc...iption-service
https://community.flexradio.com/discussion/8032305
https://www.facebook.com/groups/flex...ghts&ref=notif
С получением функций раньше всех тоже не понятно. Обычно платят бета-тестерам деньгами или товаром, как правило, раздают устройства бесплатно или продают со скидкой, а здесь с людей берут деньги за тестирование глюкавого ПО. Получается мазохизм за свой счет.Последний раз редактировалось RK3AAG; 26.09.2025 в 18:03.
259Спасибо
