каждый раз при открытии и при попытке архивации вот такая штука:
пересчитываю, но ничего не меняется.
Добавлено через 3 минуты
Такое наблюдается и на домашнем компе и на дачном.
На домашнем компе, где Логгер обновляется регулярно, всё нормально. Сегодня обновился на дачном компе, где не делалось обновлений с сентября прошлого года, запустил пересчёт и занялся делами. Прихожу - такая же ерунда, как у Романа.
Нашел переписку по той же проблеме
Hi to all,
I was having same issue after changing short date format in regional settings.
So, I was reverting changes, recalculate again and problem gone away.
73, Davor 9a5adh
--- In hamlogger@yahoogroups.com, k4cy@... wrote:
> I repeat the question. Is it possible (I would suggest it's probable) that the Logger32.INI that you keep restoring from a backup copy is pointing to a different logbook name than the one you have reconstituted by importing an ADIF copy of your log? 73.
> ----- Original Message -----
> From: "benhofmann" <bkhofmann@...>
> To: hamlogger@yahoogroups.com
> Sent: Monday, April 16, 2012 7:12:52 PM
> Subject: [hamlogger] Re: Recalculating statistics doesn't resolve pop-up message
> Â
> Ok, I tried this tonight, and found that the Logger32.INI
> file is the one that was copied last before the recalculate message appeared. It was also the last file copied (all the others were already copied, and the program started after copying each without the message appearing)
> -Ben
> --- In hamlogger@yahoogroups.com , k4cy@ wrote:
> > Please try that. I see no reason why you are getting the message unless a logbook database was restored. 73.
> > From: "benhofmann" <bkhofmann@>
> > Sent: Sunday, April 15, 2012 5:40:41 PM
> > ÂÂ
> > Here is a list of the files in my user files zip.
> > Arrlsect.db
> > BandMode32.db
> > ChildFormsOpen.INI
> > CW.INI
> > DataTerminal.ini
> > Logger32.INI
> > MMVARISoundCardMacros.ini
> > QRZXMLLookup.ini
> > SoundCardMacros.ini
> > TelnetAddresses.INI
> > UserPara.ini
> > Would it be helpful to copy each of these one at a time after a clean install and see which was the last copied before the recalculate message appears?
> > -Ben
> > > <you said>
> > > I did a clean install of 3.39.0, then imported the adif. Message was gone. Then I restored my user files. The message is back ...
> > > <unsnip>
> > > A list of the user files you restored please, 73.
> > > Sent: Sunday, April 15, 2012 4:46:50 PM
> > > ÂÂÂ
> > > Ok, the top of the window says: "Database: Z:\Shared Files\Logger32\Logs\" then the logbook name then ".EXTENSION"
> > > -Ben
> > > > There's a colored bar at the top of the message window.ÃÆ'‚Â&# 195;‚ What's the text?ÃÆ'‚Â 5;‚ 73.
> > > > Sent: Sunday, April 15, 2012 2:42:15 PM
> > > > ÃÆ'‚ÂÂ&# 194;
> > > > I'm not sure what is meant by the "caption"
> > > > -Ben
> > > > > ... and the caption of the message?ÃÆ'Æ'ââ‚& #194;¬Ã…¡ÃÆ'‚ ; 73.
> > > > > Sent: Saturday, April 14, 2012 7:25:46 PM
> > > > > ÃÆ'Æ'â€&# 195;…¡ÃÆ'‚à ‚ÂÂ
> > > > > The message I get says "There is a problem with database synchronization. The statistics do not match your logbook. Please recalculate your statistics. Click TOOLS | DATABASE MAINTENANCE | RECALCULATE STATISTICS."
> > > > > -Ben
> > > > > > ... and the exact message you receive is?ÃÆ'Æ'Æ'ÃÆ'¢âââ ;‚¬Å¡Ã‚¬Ã…¡Ã Æ'Æ'â€Å&# 194;¡ÃƒÆ'‚ƚ 73.
> > > > > > Sent: Saturday, April 14, 2012 4:48:57 PM
> > > > > > ÃÆ'Æ'Æ'ÃÆ'¢âââ ;‚¬Å¡Ã‚¬Ã…¡Ã Æ'Æ'â€Å&# 194;¡ÃƒÆ'‚ƚÂÂ
> > > > > > Upgraded to 3.39.0 and the problem persists.
> > > > > > I exported the log as adif, then re-imported, and I still got the message. I did a clean install of 3.39.0, then imported the adif. Message was gone. Then I restored my user files. The message is back. So it must have something to do with my user files. Any ideas on what I might be able to change to get this to go away, or will I just have to start from scratch on my program setup?
> > > > > > -Ben
> > > > > > > It may be time for an upgrade to the latest version .ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'Ãƒâ€šÃ‚Â¢ÃƒÆ '¢â€ 5;…¡Ã‚¬ÃÆ'â €¦Ã‚¡ÃÆ'Æ 'Æ'ÃÆ'¢âââ ;‚¬Å¡Ã‚¬Ã…¡Ã Æ'Æ'â€Å&# 194;¡ÃƒÆ'‚ƚ 73.
> > > > > > > Sent: Saturday, April 14, 2012 7:20:42 AM
> > > > > > > Subject: [hamlogger] Recalculating statistics doesn't resolve pop-up message
> > > > > > > ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'Ãƒâ€šÃ‚Â¢ÃƒÆ '¢â€ 5;…¡Ã‚¬ÃÆ'â €¦Ã‚¡ÃÆ'Æ 'Æ'ÃÆ'¢âââ ;‚¬Å¡Ã‚¬Ã…¡Ã Æ'Æ'â€Å&# 194;¡ÃƒÆ'‚ƚÂÂ
> > > > > > > I've recently restored logbooks and upgraded my program. Now when I enter the program, I get a message indicating the statistics do not match the logbook, and that I need to perform a recalculate of the statistics. The problem is that although I perform the recalculate, I still get the message each time I open the program. I am running version 3.38.16
> > > > > > > -Ben
Перешёл с WinXP на Win7. Подскажите,какие изменения нужно сделать в реестре,чтобы не было крокозябликов вместо
кирилицы?
Под # 1744 было сообщение, на которое никто не отреагировал.
Возникла необходимость и у меня.
Мои действия: Файл, Экспортировать журнал, в файл АДИФ
Вопрос : каким образом через ADIF перенести связи в другую программу за определенный период? Почему программа после нажатия START предлагает открыть файл?
Попробуй сначала прогнать "упорядочить номера", а потом пересчитать статистику
Добавлено через 59 минут
Просит открыть файл, куда вы хотите экспортировать. Но вы прописываете свое новое имя файла, прога "ругнется", мол такого файла нет, может создать :). Вы подтверждаете и вуаля, все готово.
Ну,что?!Неужели ни у кого не возникали проблемы с Win7?Так как же побороть кракозяблики?
Я думаю, проблема не в Win7, а в тех шрифтах, которые были с ней установлены. Много лет назад я сталкивался с подобной проблемой ещё на Logger16 и ранних версиях Logger32. Я перебрал шрифты и нашёл, такой, который отображался нормально. Это был AGHLV. Но потом эта проблема ушла.
Николай,спасибо!Всё получилось.А то уже думал-придётся возвращаться к XP.
Отображаемые столбцы в логе обязательно надо выбирать самому (очень уж их много) при первой инсталляции или же существует какая то базовая структура (не охота свой "велосипед" изобретать)?
Извиняюсь если баян, нашел страничку со скриншотами:
http://www.asahi-net.or.jp/~yy7a-ysd/ScreenShot.htm
Появилась версия 3.40.14
Добавлено через 32 минуты
Обновился, полёт нормальный.
Роман, у меня после обновления с версии 3.39 тоже выкинуло такое же окно. Я вручную удалил файлы LOGBOOK32.stats isd, isf, isl, ism, упорядочил номера связей, и после пересчёта статистики всё стало нормально.
У меня версия 3.4.0 В окне DX Spots при нажатии правой клавиши мыши выбираю Настройки/Фильтрация спотов, отмечаю нужные диапазоны и моды. Вроде бы все стандартно, но постоянно выскакивают споты диапазона 70 MHz, хотя места где можно было бы поставить галочку 70 MHz нет. В трансивере физически нет этого диапазона, ненужные споты раздражают и мешают. Что сделать?
Чтобы появилась возможность поставить галку, надо чтобы этот диапазон был в Вашем частотном плане. Там его нет, поэтому придётся внести строчку вручную. Точное частотное распределение на этом диапазоне в данном случае не важно, например я сделал так как на рисунке. А дальше ставим в нужном месте "Настройки/Фильтрация спотов" галку на появившемся диапазоне и всё. Споты надоедать не будут. :victory:
Не вдаваясь в конкретно Ваш случай, хочу напомнить о радикальном решении этой проблемы посредством фильтров в самом dx-кластере. Например если Вы конектитесь к dxspider, то командами reject и show можно ещё на самом начальном уровне отфильтровать всё что Вам не хочется видеть. Заодно и трафик разгрузится. Мануал и список команд : http://www.dxcluster.org/main/userma...2.html#ss12.90 .
Добавлено через 11 минут
Это как раз то что наиболее "эффкктивно" отпугивает новых юзеров от логгер32.
Этот (оптический) маразм был заложен в первой виндовсной версии лет эдак ..надцать назад и успешно дожил до сегодняшнегшо дня. Лично я начал привыкать. Последняя инсталяция на ноутбуке с уже традиционным конфигом всех полей заняла минут 15-20. :-)
