17.02.2014, 12:15 #1186
17.02.2014, 12:20 #1187
17.02.2014, 12:25 #1188Very High Power
- 20.04.2005
- Оренбург
- 3,405
- 622
- 127
Я вот не сумел справиться с отключением очистки окна позывного при перемещении по частоте при работе сплитом, т.е. в режиме DX-a
Вроде бы Alt-F11 отключает очистку, но у меня не работает почему-то.
R8TX
17.02.2014, 12:40 #1189Покинул форум
- 21.06.2009
- 55
- 3,676
- 2030
- 2226
17.02.2014, 12:52 #1190Very High Power
- 01.12.2010
- Челябинск
- 71
- 2,156
- 2544
- 1976
17.02.2014, 12:58 #1191Standart Power
- 12.09.2006
- Saratov
- 64
- 361
- 112
- 21
17.02.2014, 13:02 #1192Very High Power
- 20.04.2005
- Оренбург
- 3,405
- 622
- 127
Дык, как обычно
N1MM Logger Website | Macros
{VARYMSG2} These macros allow the user to control how often an alternate form of a function key message is sent instead of the primary form. Each can be used once in a given Function Key set. The form of the macro is {VARYMSGn&Primary Message&Alternate Message&How Often to Send Alternate&}. Substitute the form of the message you want to send most often for Primary Message. Substitute the message you want to send at intervals for Alternate Message. Finally, specify how often you want to send the Alternate message in "How Often to Send Alternate". A "0" in the "How Often to Send Alternate" field sends the Primary Message every time. A "1" in the "How Often to Send Alternate" field sends the Alternate Message every time. Placing a number, N, greater than 1, in the "How Often to Send Alternate" field sends the Alternate Message every Nth time. Examples: in the CQ Key definition (RUN F1), {VARYMSG1 &CQ * *&CQ CQ * *&3&} will send a slightly longer CQ every 3rd time. In the TU Key definition (RUN F3), {VARYMSG2 &TU&TU *&4&} will send TU alone after a completed QSO, and send TU followed by your call only every 4th time. Any function key text before or after the {VARYMSGn} macro string is preserved. So, RTTY users may place the {TX} {RX} macros before and after the {VARYMSGn} macro string. The primary and alternate {VARYMSGn} fields may contain other macros but the two {VARYMSGn} macros may not be nested.R8TX
17.02.2014, 13:09 #1193Покинул форум
- 21.06.2009
- 55
- 3,676
- 2030
- 2226
Нет, Юрий, Вы не совсем правильно поняли мою логику.
А может я не совсем корректно выразился. Моя логика в том, что со времен N6TR было удобно иметь две различные соседние клавиши для разных макросов подтверждения связи с занесением в лог. В N6TR (TR4W) - QSL и QUICK QSL. R8TX уже подсказал. Попробовал, все работает, но только через функциональную клавишу, а не соседнюю с Еnter. Привычка (мизинец правой руки) - дело достаточно серьезное. Но, повторюсь, это уже как бы придирки... Да и действительно - нужно более тщательно подходить к изучению мануала.
17.02.2014, 13:17 #1194Very High Power
- 05.05.2011
- Краснодар
- 3,873
- 2915
- 1314
17.02.2014, 13:44 #1195Very High Power
- 01.12.2010
- Челябинск
- 71
- 2,156
- 2544
- 1976
Если трудно расставаться с привычками, то самое простое - запустить любую общепользовательскую программу переназначения клавиш.
Но я бы посоветовал менять привычки. Гибкость в нашем деле - самое важное из всего, что только можно придумать... А то, многие, SSB работают также, как телеграфом: строго "по макросам", передавая в эфир много бессмысленной "шелухи", нервируя корреспондентов и отнимая время и у них и у себя. А потом удивляются, как это другие проводят SSB по 300 и более QSO в час...
До эры широкого распространения SO2R, отдельные личности гордились умением работать на клавиатуре "вслепую" - т.е. всеми 10 пальцами и не глядя на клавиатуру. Для SO2R эту привычку пришлось ломать радикально... Две различные клавиатуры - по одной руке на каждую. Вариант с 1 ком-пом и 1 кла-вой не рассматриваем - это вообще не вариант для серьезного участия.73 Юрий RG9A
17.02.2014, 13:46 #1196Very High Power
- 01.12.2010
- Челябинск
- 71
- 2,156
- 2544
- 1976
17.02.2014, 13:59 #1197Покинул форум
- 21.06.2009
- 55
- 3,676
- 2030
- 2226
17.02.2014, 14:03 #1198Very High Power
- 01.12.2010
- Челябинск
- 71
- 2,156
- 2544
- 1976
73 Юрий RG9A
17.02.2014, 14:13 #1199Very High Power
- 05.05.2011
- Краснодар
- 3,873
- 2915
- 1314
Menu:Tools - Win-Test Wiki...
либо через определенное время
либо через определенное количество связей
либо в зависимости от Rate
17.02.2014, 15:46 #1200
1773Спасибо
