Давно придумано VARYMSG, синтакс {VARYMSG1 &CQ * *&CQ CQ * *&3&}
Для пайлапов {VARYMSG1 &TU&TU *&3&}, каждое 3-е TU будет идти с позывным.
Я вот не сумел справиться с отключением очистки окна позывного при перемещении по частоте при работе сплитом, т.е. в режиме DX-a :) Вроде бы Alt-F11 отключает очистку, но у меня не работает почему-то.
Дык, как обычно :)
N1MM Logger Website | Macros
{VARYMSG2} These macros allow the user to control how often an alternate form of a function key message is sent instead of the primary form. Each can be used once in a given Function Key set. The form of the macro is {VARYMSGn&Primary Message&Alternate Message&How Often to Send Alternate&}. Substitute the form of the message you want to send most often for Primary Message. Substitute the message you want to send at intervals for Alternate Message. Finally, specify how often you want to send the Alternate message in "How Often to Send Alternate". A "0" in the "How Often to Send Alternate" field sends the Primary Message every time. A "1" in the "How Often to Send Alternate" field sends the Alternate Message every time. Placing a number, N, greater than 1, in the "How Often to Send Alternate" field sends the Alternate Message every Nth time. Examples: in the CQ Key definition (RUN F1), {VARYMSG1 &CQ * *&CQ CQ * *&3&} will send a slightly longer CQ every 3rd time. In the TU Key definition (RUN F3), {VARYMSG2 &TU&TU *&4&} will send TU alone after a completed QSO, and send TU followed by your call only every 4th time. Any function key text before or after the {VARYMSGn} macro string is preserved. So, RTTY users may place the {TX} {RX} macros before and after the {VARYMSGn} macro string. The primary and alternate {VARYMSGn} fields may contain other macros but the two {VARYMSGn} macros may not be nested.
Нет, Юрий, Вы не совсем правильно поняли мою логику.:) А может я не совсем корректно выразился. Моя логика в том, что со времен N6TR было удобно иметь две различные соседние клавиши для разных макросов подтверждения связи с занесением в лог. В N6TR (TR4W) - QSL и QUICK QSL. R8TX уже подсказал. Попробовал, все работает, но только через функциональную клавишу, а не соседнюю с Еnter. Привычка (мизинец правой руки) - дело достаточно серьезное. Но, повторюсь, это уже как бы придирки... Да и действительно - нужно более тщательно подходить к изучению мануала.
Если трудно расставаться с привычками, то самое простое - запустить любую общепользовательскую программу переназначения клавиш.
Но я бы посоветовал менять привычки. Гибкость в нашем деле - самое важное из всего, что только можно придумать... А то, многие, SSB работают также, как телеграфом: строго "по макросам", передавая в эфир много бессмысленной "шелухи", нервируя корреспондентов и отнимая время и у них и у себя. А потом удивляются, как это другие проводят SSB по 300 и более QSO в час...
До эры широкого распространения SO2R, отдельные личности гордились умением работать на клавиатуре "вслепую" - т.е. всеми 10 пальцами и не глядя на клавиатуру. Для SO2R эту привычку пришлось ломать радикально... Две различные клавиатуры - по одной руке на каждую. Вариант с 1 ком-пом и 1 кла-вой не рассматриваем - это вообще не вариант для серьезного участия.
Menu:Tools - Win-Test Wiki...
либо через определенное время
либо через определенное количество связей
либо в зависимости от Rate
