Большое спасибо, но сайт предлагает версию v.2.3.1
Благодарю, Сергей.
Всё удачно!
Я так редко занимаюсь обновлениями, что порой приходится всё изучать по новой.
Напрямую из EQF уже и не будет. Чтобы не было проблем с обменом между UR5EQF_Log и LotW, используйте плагин Олега US-E-12 LoTWUpdate
Свежая информация от главного разработчика LoTW касательно проблем взаимодействия разных логгеров и LoTW.
Цитата на языке оригинала:
" Beginning with TQSL 2.5.2, ARRL is now checking consistency to improve the integrity of logging data collected in Logbook of The World. The information in ADIF format with which users submit logs is now being used for crosschecks that help prevent inaccurate or incomplete information from contaminating the Logbook database.
The Amateur Data Interchange Format (ADIF) exists precisely to help ensure the accuracy of “data interchange” among amateur radio applications. By checking that the station information entered for an overall log matches the ADIF data on an individual QSO, Logbook can reject entries where inconsistencies suggest that the data are faulty. Accurate entries help operators get all the confirmations that they deserve, and prevent useless entries that will never be matched.
The first Implementation of these crosschecks, in TQSL 2.5.2 onward, has revealed that many logging applications have not been following the rules laid out by the ADIF standard. The current version of the standard has been in place since May 2019 and is publicly available at The Independent ADIF Site. The field used for checking location has been in the ADIF standard since 2004. The standard is maintained and voted on by the ADIF group, including 22 voting members, of which ARRL is only one.
Some commentators have suggested that ARRL has not defined the ADIF fields appropriately. At least, this represents a misunderstanding of how the ADIF standard is developed and maintained, and at worst ignores the responsibility of logging applications to follow the standard if they provide files which they claim to be in ADIF format.
Operators have a right to insist that the logging applications they use conform to the standards agreed upon by the ADIF collective. Those who find their logger out of conformance should demand that it be updated, or, if the logger is unsupported or unwilling to update, should investigate switching to a logger that is a cooperative member of the universe of amateur radio logging applications.
73, Greg, K0GW, 2020 Logbook Committee Chair"
Здравствуйте Виктор !
TQSL 2.5.2 с моим логом LogHX3 при отправке QSO в LoTW ругается. Вернулся на 2.5.1. Грешу на то что в месте расположения станции в моем случае не указан QTH-локатор. Нужно ли теперь его обязательно указывать в новых версиях TQSL ? С версией 2.5.1 проблем нет.
LogHX3 build 541, TQSL v2.5.2 принимает и отправляет подтверждения без проблем:
Вложение 255868
Новую версию TQSL ставите поверх предыдущей, в установках TQSL ничего менять не нужно. Место расположения станции должно быть то, которое указывали при запросе сертификата.
Здравствуйте Борис !
Спасибо за ответ. У меня LogHX3 build 108. Новую версию TQSL ставил поверх предыдущей. В общих установках лога указаны широта и долгота и WW локатор, в моем случае KO84QW. Этот локатор есть в сформированных АДИФ файлах. В TQSL WW локатор не указывал, хотя в меню местоположение станции такая строка есть. В LogHX3 во вкладке LoTW Station Location стоит Home, также Home стоит в названии местоположения станции в TQSL.
Сергей, скорее всего у вас проблема в версии лога, довольно "древняя" версия LogHX3. В новой версии TQSL обращается внимание на формирование файла адиф средствами журналов (см. пост Виктора ниже):
Цитата:
Начиная с TQSL 2.5.2, ARRL теперь проверяет согласованность, чтобы улучшить целостность данных регистрации, собранных в Журнале Мира. Информация в формате ADIF, с помощью которой пользователи отправляют журналы, теперь используется для перекрестных проверок, которые помогают предотвратить попадание неточной или неполной информации в базу данных журнала.
