Проблема решена.
Спасибо за ответ. Основной аппаратный журнал
другой. Обновился и проблема исчезла.
Проблема решена.
Hello Alexey,
please take a look to this problem.
Вложение 292293
Using QSLprintHX v 1.0 build 16
When in the log, the field "via" is empty, in my opinion,
we do not print this line, or by defaul, print "Via: bureau"
Is possible to have this function..??
THanks in advance.
73 de IK2XDE Andrea
OK....
I use tag [QSL_VIA:]
Вложение 292304
BUT...if in the log, tha "via" filed was empty, without manager,
like you see, will be print on the label Via: ............(in blank)
Вложение 292305
I think that if manager not exist, the line will be NOT printed,
or by default, will be printed BUREAU
Thanks.
73 de IK2XDE Andrea
Trying to design so I can print direct to my QSL card.
I have tried to print with 2 QSO's from the same station. I select both in the log(via space) and export to ADIF. The open the ADIF in QSLprintHX but it seems to produce 2 cards for each QSO repeated. How do I get the 2 QSO's on the same card?
ThanksВложение 293697Вложение 293697
I think you have to select amd mark needed QSO to print and check QSLPrint again
Not sure what you mean?
I select the QSO's to print - via space bar....then print QSO - "Selected QSO's" only. Then it opens PrintHX and has the 2 or 3 cards for the same callsign.
I think its my QSO date tags etc in my print file. Looking at the template qsl card files, they are all the group fields(ie 10 QSO_Dates) in one box. I cannot seem to edit the templates to space out the group fields to line up with my QSL card entry lines.
OK sorted it. I missed the set up "number of qsos per card" So once I fixed this and added some space it works. Now to actually see if I can get it to print on a card!Вложение 293698
