31.12.2023, 20:59 #736
- 03.01.2021
- 165
- 18
Wonderful,
with v.3.0 buid 744 dated 31/12/2023 20.31
the database manager seems to work fine.
All insert and update functions seem to work.
I will do more tests in the next few days.
Thanks Alex.
Happy New Year to all users
and Good DX
73 de IK2XDE AndreaIK2XDE Andrea - WWLoc. JN45MQ
https://www.xdenews.net/ik2xde/logonline/
RADIO Setup (update 20/02/2019)
ICOM IC-7600 - (HF - 50MHz.)
SunSDR2DX - (HF - 50MHz. - 144 Mhz.)
OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
OB11-3 (11 element - 3 band - 10m-15m-20m)
OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
SkyWire Loop (40-60-80-160 m.)
03.01.2024, 20:04 #737
- 03.01.2021
- 165
- 18
I warmly thank Alex for his efforts in the development of LogHX.
Finally, the management of the offline manager database work fine and allows various import solutions by users.
Personally, I have kept my database updated for years, and I thought I would make it available to all LogHX users.
I normally update it a couple of times a month.
You can find the file at the following address: http://www.xdenews.net/managers
There are also complete instructions to update your log.
The database can certainly be improved,
so if anyone would like to send me updates or corrections they are welcome.
Thanks for the attention.
04.01.2024, 21:28 #738
- 03.01.2021
- 165
- 18
ALARMED SPOT GRID ...problem....I think.....!!
When i select some call for alarms spot,
and in "country status for selected call" i chose Highlight color,
backgroud spot was colored also if I just work the call on same band and mode.
It does not take into account whether the station has already been worked.
I think correct solution will be
BACKGROUND COLOR only if station will be new one on the same band and mode.
If station just worked....NOT BACKGROUND COLOR....spot grid background will be white.
73 de IK2XDE Andrea.IK2XDE Andrea - WWLoc. JN45MQ
05.01.2024, 00:05 #739
- 03.02.2006
- 51
- 17,278
- 8085
- 4235
Ant.: UW4HW, Pwr.: ~500 Wtts
05.01.2024, 01:10 #740
- 03.01.2021
- 165
- 18
06.01.2024, 19:53 #741
- 19.11.2019
- Nyirabrany
- 11
- 43
07.01.2024, 13:14 #742
- 19.11.2019
- Nyirabrany
- 11
- 43
I mean "red frame", not "red bracket"
07.01.2024, 14:40 #743
- 19.11.2019
- Nyirabrany
- 11
- 43
Two other question:
- How can I select a QSO in the log window in the new version of LogHX (b748). The SPACE button does not work.
- What is the function of the "Call" (underlined) in Radio1 window.
Thank you for help!
73 Egon
07.01.2024, 20:49 #744
- 04.01.2019
- 83
- 31
- 21
Hi Egon
SPACE works for me
If Call is not underlined and you have entered other data (QTH, Name, Loc...) and then you change the letter in the call, this data will be lost.
If Call is underlined and you have entered other data (QTH, Name, Loc...) and then you change the letter in the call, this data will not be lost.
Vlado OM3BY
07.01.2024, 21:01 #745
- 03.02.2006
- 51
- 17,278
- 8085
- 4235
08.01.2024, 14:41 #746
- 19.11.2019
- Nyirabrany
- 11
- 43
Hello Alexei,
Thank you for the help!
- Yes, CAT is OK in Radio1 window.
- Help / Hot keys / is OK, SPACE 111
I reloaded an older View, now SPACE is OK but the red frame is not showing in the Cluster window!
In MY newest View if I click in the log window anywhere, the log is goes to EDIT mode in the clicked row, so in EDIT mode the SPACE is not functioning as Select/Unselect because the cursor is blinking in the row.
So I investigate ... But I think, it is time to reinstall the beloved LogHX from the begining.
I wait a few days, maybe somebody has better idea before I reinstall all again.
Thank you again!
73 Egon
- - - Updated - - -
Thank you Vlado!!
Yes I had problem with the disappearing datas in Radio1 window but thank you for you, it will be just bad memories!
73 Egon
08.01.2024, 18:58 #747
- 04.01.2019
- 83
- 31
- 21
13.01.2024, 01:35 #748
- 05.01.2024
- 39
Hi Alexei.
How to config the CAT-Interface to use the RIG-2 of Omni-Rig
13.01.2024, 10:02 #749
- 03.02.2006
- 51
- 17,278
- 8085
- 4235
15.01.2024, 07:43 #750
- 05.01.2024
- 39
