Страница 378 из 729 ПерваяПервая ... 278328368371372373374375376377378379380381382383384385388428478 ... ПоследняяПоследняя
Показано с 5,656 по 5,670 из 10934
Like Tree1273Спасибо
Тема: JT65-HF
  1. #5656
    22.04.2006
    г.Елизово а\я 143
    75
    369
    41
    6
  2. #5657
    Standart Power Аватар для RA0ZIJ
    03.12.2011
    Вилючинск, Камчатский край
    51
    187
    25
    80
    На любителя.
    Никогда не понимал установки версий программ для разработчика. Т.е. не только не stable, но даже еще и не beta. Если, конечно, сам не разработчик.
  3. #5658
    Very High Power Аватар для RC2SC
    12.08.2006
    Рязань
    2,629
    882
    290
    Цитата Сообщение от RA0ZIJ Посмотреть сообщение
    На любителя.
    Может впечатление изменится когда прочтёте переписку ниже, может у кого то тоже есть подобные проблемы с легкой руки Microsoft.
    After extensive testing, and with the aid of Julian, VK4CMV, who confirmed
    the existence of the exact same errors occurring with his WSJT-X
    operations, I come to the conclusion that changes to Microsoft Windows via
    periodic Windows updates, may be a major player in error activity.
    Testing was done on 3 different versions of WSJT-X (r3673, r4400, & r4633)
    in total isolation from the world, save "on-air" signal input. Almost
    every permutation of disabling software, option settings, etc. were
    employed in a very large number of tests. Each test was performed after a
    complete scrubbing of my laptop's hard drive, memory, and drivers. No
    positive effects were observed during the tests.
    I finally uninstalled every Windows update placed into service in Dec 2014,
    and re-tested. Results were most encouraging, with long runs of each
    WSJT-X version before a hiccup. Hiccups were cured by restarting WSJT-X
    (not the optimum resolution, but much better than others found to date).
    Final confirmation of WSJT-X - Windows interaction having some relationship
    to the errors observed came when each Windows update was individually re-
    installed. No change to the much improved operation of WSJT-X versions was
    observed until two different updates were installed. Each caused a slow-
    down of decoding, increased errors, and frequent Decode lock-ups.
    The "offending" Windows Updates are:
    KB3025390 - major "offender"
    KB2952664 - minor "offender"
    With these two Windows updates uninstalled, and everything but the kitchen
    sink attached to the laptop and every bit of software normally used in weak
    signal operations here running, the results of testing were impressive.
    Fast decoding (I use "Deepest" decoding), and a noteworthy improvement in
    mean time between errors. Best, only one decoder lock-up over 6+ hours of
    testing. If a KV error occurs, with or without the pop-up error window,
    normal operation continues. The pop-up error window can be closed when it
    appears - no observable deterioration in normal operations occur when that
    pop-up appears, nor when it is manually closed.
    Any thoughts about this line of testing and its results?
    Best 73,
    Paul DU2/WA8UGN
    Paul DU2/WA8UGN <keatipa@...> writes:
    > SUCCESS AT LAST!
    > 17+ hours of continuous running and decoding with WSJT-X v1.5.0-devel
    > r4848 have passed, and not one single error, temporary or complete
    > lock-up, pop-up error window, or any other complaint. My decoding,
    > between 2014-Dec-23 14:43 and 2014-Dec-24 07:18, has been flawless,
    > as recorded in my ALL.txt file.
    FOLLOW-UP:
    Decoding between 2014-Dec-24 14:43 and 2014-Dec-24 17:20 still flawless, as
    It certainly looks like my problem is solved.
    Best Christmas Present Ever!
    Merry Christmas to all from the Philippines.
    73 de Paul DU2/WA8UGN SK
  4. #5659
    07.04.2002
    г.Москва, г.Троицк
    48
    9,463
    2553
    7661
    А то я думаю, что-то у меня WSJT-X вылетает постоянно.
    Вечерком попробую.
  5. #5660
    24.03.2013
    Полевской
    49
    260
    151
    KB3025390
    KB2952664
    Как я понял если они присутствуют - их надо удалить ?
    Возможно данные патчи и на остальные программы для JT65 влияют ...
    Пора бы уже нормальную шапку в теме организовать ... А то по разным темам/сайтам приходилось выискивать инфу, а до чего то и самому доходить в свое время.
  6. #5661
    03.12.2011
    51
    187
    25
    80
    Прочитал переписку, но не понял, при чем здесь она и версия devel.
    Ведь тестировали одновременно несколько релизов
    , т.е. и стабильный 1.3, и релиз кандидат 1.4, и версию для разработчиков.
    Тем более что проблема была в обновлениях безопасности. Я веду речь о том, что devel - версия "необкатанная" и конечному пользователю не адресована. Даже RC будет стабильнее и беспроблемнее devel.
    Ну, это всё офф.
    От себя - удалил обновления безопасности, ничего не изменилось. Так же декодирует, stable-версия v1.3r3673 на Win7Ult_64 за всё время работы не вылетела ни разу, в соответствии с наименованием - stable.
  7. #5662
    07.04.2002
    г.Москва, г.Троицк
    48
    9,463
    2553
    7661
    Последнее время вылетает часто после обновы винды. Вечером буду смотреть и на выходных.
  8. #5663
    27.10.2010
    гПокров
    1,286
    162
    Почему перестало выскакивать окошко в JT65 после окончания QSO для записи связи в журнал EQF , раньше было .И как с этим делом в wsjt-x ?
  9. #5664
    03.12.2011
    51
    187
    25
    80
    Цитата Сообщение от UA3VFL Посмотреть сообщение
    .... как с этим делом в wsjt-x ?
    В версии 1.3 r3673 работает.
  10. #5665
    22.04.2006
    г.Елизово а\я 143
    75
    369
    41
    6
    В версии 1,5 тоже работает.
  11. #5666
    27.10.2010
    гПокров
    1,286
    162
Размер: 60.7 Кб чтонетакНазвание: Screenshot_7.jpg
Размер: 53.8 Кб Название: Screenshot_11.jpg
Размер: 28.6 Кб [ATTACH=CONFIG]131139Нажмите на изображение для увеличения.
ID:	131140 где что не так ? не пойму , то работает то нет
  12. #5667
    27.10.2010
    гПокров
    1,286
    162
    Не знаю что произошло, но при клике Enabl TX трансивер соскакивает с установки Date или перескакивает на другой диапазон , в общем прога перестала работать , и есть ли смысл ее запускать?
  13. #5668
    Very High Power Аватар для UA3AEE
    03.08.2011
    83
    1,754
    349
    320
    Загружай другую!73
  14. #5669
    27.10.2010
    гПокров
    1,286
    162
    Цитата Сообщение от UA3AEE Посмотреть сообщение
    Загружай другую!73
    Какую версию ,от куда ?
  15. #5670
    03.12.2011
    51
    187
    25
    80
    На официальном сайте доступны две версии: стабильная 1.3 r3673 и бета 1.4 RC2
    На SourceForge.net доступен для скачивания целый пакет программ, в составе версия для разработчиков - 1.5 devel.
  1. Новая мода JT65
Метки этой темы
