Вот здесь: все есть :p-up: JTSDK - Browse /win32/2.0.0/wsjt-suite at SourceForge.net
На любителя.
Никогда не понимал установки версий программ для разработчика. Т.е. не только не stable, но даже еще и не beta. Если, конечно, сам не разработчик.:s10:
Может впечатление изменится когда прочтёте переписку ниже, может у кого то тоже есть подобные проблемы с легкой руки Microsoft.
After extensive testing, and with the aid of Julian, VK4CMV, who confirmed
the existence of the exact same errors occurring with his WSJT-X
operations, I come to the conclusion that changes to Microsoft Windows via
periodic Windows updates, may be a major player in error activity.
Testing was done on 3 different versions of WSJT-X (r3673, r4400, & r4633)
in total isolation from the world, save "on-air" signal input. Almost
every permutation of disabling software, option settings, etc. were
employed in a very large number of tests. Each test was performed after a
complete scrubbing of my laptop's hard drive, memory, and drivers. No
positive effects were observed during the tests.
I finally uninstalled every Windows update placed into service in Dec 2014,
and re-tested. Results were most encouraging, with long runs of each
WSJT-X version before a hiccup. Hiccups were cured by restarting WSJT-X
(not the optimum resolution, but much better than others found to date).
Final confirmation of WSJT-X - Windows interaction having some relationship
to the errors observed came when each Windows update was individually re-
installed. No change to the much improved operation of WSJT-X versions was
observed until two different updates were installed. Each caused a slow-
down of decoding, increased errors, and frequent Decode lock-ups.
The "offending" Windows Updates are:
KB3025390 - major "offender"
KB2952664 - minor "offender"
With these two Windows updates uninstalled, and everything but the kitchen
sink attached to the laptop and every bit of software normally used in weak
signal operations here running, the results of testing were impressive.
Fast decoding (I use "Deepest" decoding), and a noteworthy improvement in
mean time between errors. Best, only one decoder lock-up over 6+ hours of
testing. If a KV error occurs, with or without the pop-up error window,
normal operation continues. The pop-up error window can be closed when it
appears - no observable deterioration in normal operations occur when that
pop-up appears, nor when it is manually closed.
Any thoughts about this line of testing and its results?
Best 73,
Paul DU2/WA8UGN
Paul DU2/WA8UGN <keatipa@...> writes:
> SUCCESS AT LAST!
> 17+ hours of continuous running and decoding with WSJT-X v1.5.0-devel
> r4848 have passed, and not one single error, temporary or complete
> lock-up, pop-up error window, or any other complaint. My decoding,
> between 2014-Dec-23 14:43 and 2014-Dec-24 07:18, has been flawless,
> as recorded in my ALL.txt file.
FOLLOW-UP:
Decoding between 2014-Dec-24 14:43 and 2014-Dec-24 17:20 still flawless, as
It certainly looks like my problem is solved.
Best Christmas Present Ever!
Merry Christmas to all from the Philippines.
73 de Paul DU2/WA8UGN SK
Как я понял если они присутствуют - их надо удалить ?
Возможно данные патчи и на остальные программы для JT65 влияют ...
Пора бы уже нормальную шапку в теме организовать ... А то по разным темам/сайтам приходилось выискивать инфу, а до чего то и самому доходить в свое время.
Прочитал переписку, но не понял, при чем здесь она и версия devel.
Ведь тестировали одновременно несколько релизов, т.е. и стабильный 1.3, и релиз кандидат 1.4, и версию для разработчиков.Цитата:
Тем более что проблема была в обновлениях безопасности. Я веду речь о том, что devel - версия "необкатанная" и конечному пользователю не адресована. Даже RC будет стабильнее и беспроблемнее devel.
Ну, это всё офф. :)
От себя - удалил обновления безопасности, ничего не изменилось. Так же декодирует, stable-версия v1.3r3673 на Win7Ult_64 за всё время работы не вылетела ни разу, в соответствии с наименованием - stable. :)
Почему перестало выскакивать окошко в JT65 после окончания QSO для записи связи в журнал EQF , раньше было .И как с этим делом в wsjt-x ?
В версии 1,5 тоже работает.
Вложение 131136 чтонетакВложение 131137 Вложение 131138 [ATTACH=CONFIG]131139Вложение 131140 где что не так ? не пойму , то работает то нет
Не знаю что произошло, но при клике Enabl TX трансивер соскакивает с установки Date или перескакивает на другой диапазон , в общем прога перестала работать , и есть ли смысл ее запускать?
На официальном сайте доступны две версии: стабильная 1.3 r3673 и бета 1.4 RC2
На SourceForge.net доступен для скачивания целый пакет программ, в составе версия для разработчиков - 1.5 devel.
