Summary
The cure for common mode problems caused by less-than-perfect or smaller ground systems is inserting a good 1:1 choke balun in the system at the antenna feed point. The coax should also be kept away from the radials as it exits the area of the radials and the antenna. An antenna with a poor ground using few radials cannot have a support mast grounded to the radial common point (at least it shouldn't if designed properly). There is no exception to this! A radial system of 25 or more full-size radials would likely have minimal common mode on an unbalanced feeder, but current rapidly increases as the ground system becomes smaller.
