Интересное дело, похоже мы все единомышленники в данном вопросе- всем нравится именно 5КГц на оборот валкодера а не 10 как с завода! Очень мне не нравилась невозможность перехода на 5 КГц в 850-м, а вот в 950-м и в 450-м это делается прямо из меню!
На счёт моды KM1H , вот что он написал и дал лаб. иследования до моды и после
На счёт конкретного номинала PIN диода я не знаю
Читал , что некоторые ставят HP5082-3081....
To all those on Topband who asked...here is the results of the TS-940
tests.
73 Carl KM1H
--------- Begin forwarded message ----------
To: wsvhf@qth.net
Subject: [WSVHF] TS-940 Specs
To: <topband@contesting.com>
Date: Tue, 09 Sep 1997 22:35:15 EDT
Message-ID: <19970909.214104.9687.15.km1h@juno.com>
As an addition to the Sherwood receiver info, here are some specs on a
TS-940.
All tests were run on 28MHz during the past few days on a customers unit.
TS -940 late serial # with factory phase noise updates:
MDS SSB -135 dBm
MDS CW cascaded 500Hz filters -137 dBm
Sensitivity 10dB S+N/N .12uv
Phase Noise -131dBc at 10 KHz
Filter rejection CW >90 dB
2 tone dynamic range Wide 95 dB @ 20 KHz
2 tone dynamic range Narrow ( CW Filters) 77 dB @ 2 KHz
3rd Order IP +1dBm at 20 KHz
Wide Band transmitted noise -75 dB below full carrier
The same TS-940 but with PIN diode mods to RF and IF boards:
MDS SSB -137dBm
MDS CW -142 dBm
Sensitivity ~ .1uv
Phase noise -131 dBc @ 10 KHz
Filter rejection ( CW ) >90 dB
2 tone Dynamic Range Wide 102 dB @ 20 KHz
2 tone Dynamic range Narrow ( CW Filters) 83 dB @ 2 KHz
3rd Order IP +5 dBM @ 20 KHz
Wide band transmitted noise -90 dB below full carrier
A few notes and comments:
Although the PIN diode improvement is evident in the numbers the audible
difference is much greater. First of all the receiver is noticeably
quieter. The IMD performance shows an "apparent" improvement of about
10-12 dB under crowded band conditions. This follows along with
conversations I had with Dr. Ulrich Rhode several years ago when I first
started using PIN diodes. The cumulative effect of multiple strong
signals degraded IMD performance in a stock receiver a lot more than a
simple 2 tone test would indicate. The receiver is a pleasure to use in
lowband pileups now.
The improvement in wideband TX noise is due to, I believe, the use of
PIN's in those paths that were common to TX and RX on the IF board. The
stock diodes either generated noise or allowed RX path noise into the TX
path. The same appears to hold true in the opposite scenario. This TX
noise is something I was recently made aware of by a local on 6M and
bears closer examination and possible additional improvements. The noise
does not change dB levels when going from full power to the 20-30mw from
the transverter port so it can not be blamed on thermal noise in the
subsequent linear amp stages.
Интересно, для чего нужна кнопка FSK в трансиверах TS-450...950 ? Работать digi mode в этом режиме неудобно. Кто - нибудь использует кнопку FSK ?
FSK- это только для телетайпа. Формирование сигнала на передачу идёт прямо в трансивере, т.е. двухчастотная манипуляция с фиксированным разносом. Сейчас многие работают в режиме AFSK, т.е. подают на микрофонный вход трансивера сигнал со звуковой карты компьютера, это удобно, т.к. появляется возможность работы АПЧ, но с точки зрения энергетики, FSK конечно лучше.Цитата:
Сообщение от DVK
В драйвере TS930 поставил 2SC1969, при замене транзисторов рекомендуют произвести регулировку в плате Signal Unit для получения 100 ватт на нагрузке 50 ом. Регулировать резисторами P out и ALC.
Подскажите номера резисторов.
А почему не отдается вся мощность. На все диапазонах чуть больше 50 Ватт, по прибору??...
2 AlexS.
В режиме настройки мощность не может быть более 55 Ватт. В CW в нажатии до 125 Ватт. А у меня получается при регулировке ( увеличении) мощности в CW доходит до 50 Ватт и далее падает. КСВ=1 на R=50 ом ( 100 Ватт кирпич ), очевидно надо регулировать ALC и R Outpoot возможно R 7?, R11-очевидно защита по току - не более 11 Ампер, а какой R для ALC - ??????????????
Максимальная выходная мошность VR8,ограничение потребляемого тока 11а-VR10.Некоторые аппараты были с 50 ваттной выходной мощностью в них стоит другой тарнс.
To: RA3MB.
Извиняюсь может быть за глупый вопрос, что значит 55 и 125 Ватт, у меня оно именно так и есть, но вот только не при одной настройке, а всегда. По крайней мере в SSB к 100 Вт и близко не подходит ни как???....
А в CW. У меня после 50 стрелка идет не вверх, а вниз. Это при вращении вправо регулятора мощности при нажатом ключе. А доходить должна до 125. Почему мощьность падает ???. Я это вижу и на шкале В7-15 на эквиваленте=50ом.100Ватт.
Для всех.
В начале всех ваших упражнений найдите на Signai Unit КТ с надписью ALC J113 потом потенцом VR 13 выставляем на нем +2.5в при ТХ(все ручки влево).После этого можно крутить все остальное.
Да, спасибо, Хом.
А эти вольты в каком режиме, SSB or CW, или без разницы?.
to: RA3MB, нет в CW доходит до 125, как вы и говорите, с этим проблем нет, а вот в SSB как бы и маловато,?..
Вольты в какой моде-все равно.Если мала мошность а все крутилки уже юзали,делаем так:(минимум CAR мода CW)жмем сенд и на КТ RB SU выставляем +2.15в потенцом VR25,далее из DRV вынаем хвост,в этот разьем щуп,ручки в среднее положение,жмем сенд,в моде CW крутим L115,в моде SSB крутим L99 L111 L112.При всех вывертах,железка нагружена на 50 ом,все что Вы делаете с ней-это Ваш личный риск.Притензии ко мне что что-то не так объяснил не принимаются.
Похоже на то, что транзисторы 2SC1969 мне попались "левые". На НЧ они еще работают, при включении в ТХ мощность около 100 Ватт, а затем потихоньку сползает к 50-55. На ВЧ ( 21-29 мГц) вначале 60-50, а затем 40-30 Ватт. Хочу попробовать снова поставить старые добрые КТ921А 1987 года выпуска. Они и до этого у меня в аппарате стояли, но лабораторных работ по измерению мощности я тогда не производил т.к. все время работаю на УМ 2хГИ7И и раскачки хватало. Стрелка на приборе 930 была в секторе до 50 Ватт.
То Хом, спасибо за инфо, обязательно приму к сведению Ваши замечания.
То AlexS В SSB и должно быть чуть меньше чем в CW.
Сегодня вечером заменю транзисторы, результат сообщю.
Алексей.
Скажите все, а что Кенвуды с номером модели заканчивающимся на х50, чем то друг с другом связаны???
