Сообщение от
EY8MM
Yaesu FT-1000 (FT 1000 FT1000) Out of band TX mod FT-1000
Remove power and ant.
Open case like explained in your "operating manual".
Locate four screws attaching frount panel and remove the top screws. loosen the bottom screws.
Tilt frount panel forward.
On the left side of the radio, remove the plug from power supply to the frount panel. (gray and
white wires.)
Locate the jumper position 3 on control board.
Change the jumper status in position 3.
Reassemble radio.
Reset CPU (see your OPERATING MANUAL).
