Update Software V0143 and V11.45 (1/31/09)
Появилась новая прошивка
FT-2000/D “PEP2000” Update Software V0143 and V11.45 (1/31/09)
http://yaesu.com/downloadFile.cfm?Fi...p%2Dcompressed
Ver. 0143 MAIN CPU implements improvements (also includes previous Ver. 0142 updates):
• Added values are now indicated on the VFD display for MIC, PROC and RF PWR. (Press the [ENT]
key to set the command to “Enable” or “Disable” MENU #015 LVL IND).
• Changed the position and the set point of the PROC knob. The 10 o’clock setting provides 5 to 10 db
compression. (*It is recommended that you utilize the monitor function and adjust the [PROC] knob
suitable audio, between 9:00 to 12:00 o’clock position).
Ver. 11.45 EDSP implements improvements (also includes previous Ver. 11.39 updates):
• The characteristic of the CONT LEVEL is changed.
• The characteristic of the MIC and PROC LEVEL is changed.
• Detection frequency precision of CW-DET.
*If you already have software Ver. 0143 and 11.45 it is not necessary to update the FT-2000/D again.
* The updated FT-2000/D Operating Manual will be posted on the website around mid February.
* After installation of Ver. 0142 or 143, you may find that computer operation with PCC-2000 may not be
possible for setting proper MENU items. We will release the updated PCC-2000 software when it becomes
available.
_________________
