Страница 45 из 251 ПерваяПервая ... 353839404142434445464748495051525595145 ... ПоследняяПоследняя
Показано с 661 по 675 из 3753
Like Tree290Спасибо
Тема: Logger32
  1. #661
    13.10.2004
    Такой здесь больше не живёт.
    665
    117
    87
    Юра, привет, с наступившим,
    а какая версия у тебя? У меня это началось сегодна сразу после апдейта на 3.16. Может даунгрейд попробывать.
  2. #662
    Радиолюбитель
    17.12.2005
    nr Калининград
    59
    2,952
    1038
    912
    В описании на 16-ю версию четко указано, что начиная с этой версии online поиск на QRZ.COM убран.
    IMPORTANT NOTES:
    a) From this release forward, Logger32 will NOT provide Internet lookup
    capability to QRZ.com Those wishing to access this service must use third
    party (non Logger32) modules which are available.
    Since inception, Logger32 has accessed QRZ.com through an external module
    (not part of Logger32 but written by the same author) called QRZLookup.exe.
    and the collected information has been forwarded to a routine within
    Logger32 to display the results. Data was provided by QRZ.com in a high
    throughput proprietary format that was free from advertising. The policies
    of QRZ.com have changed and the direct data feed for Logger32 is no longer available.
    The QRZLookup.exe module no longer works, and has been removed from the distribution
    package. This file together with QRZ.txt are no longer used and can be deleted from
    the Default Logger32 directory. However the display window remains as part of
    Logger32 and can be filled with data from the external interface.
    Sample source code of a non functional (it doesn't go anywhere or retrieve any data)
    external InternetCallsignLookup module is (or will be) provided at the Logger32
    website. Programmers can use this as a skeleton to access whatever database they choose.
    [There will be no QRZSubscriberXMLLookup.exe or any other Internet callsign Lookup
    modules provided as part of the distribution.]
    Looking forward, beyond this release, the current Hamcall.net lookup capability will
    be removed and those requiring access to this database will (like QRZ.com users) have
    to rely on the good auspices of other programmers to write an appropriate module.
  3. #663
    Радиолюбитель Аватар для UA9KW
    18.02.2007
    Салехард
    59
    1,688
    471
    117
    3,14,0
    Так что это наверное редкий случай, когда старое лучше
  4. #664
    Радиолюбитель
    25.11.2008
    Заречный
    1,504
    1278
    824
    Здравствуйте.
    Подскажите, пожалуйста, что нужно сделать, чтобы при печати наклеек утилитой Логгера из Worda, получался такой же формат даты, какой установлен в журнале? Сейчас формат даты печатается в соответствии с ADIF. Можно конечно править формат вручную для каждой наклейки, но это как-то несерьёзно. Обычно я печатаю наклейки в BV7, а тут подвернулось несколько листов "самоклейки", для которых замечательно подходят Логгеровские заготовки под Word.
    Спасибо.
  5. #665
    11.03.2006
    Гродно
    2,146
    411
    41
    Юра, она внеслась из предыдущих наших связей.
  6. #666
    13.10.2004
    665
    117
    87
    Ну вот, два дня с этой "примочкой" от n2amg отработал.
    Если окно проги держать в свёрнутом виде только в таск баре, то разница с прямым лукапом почти незаметна. Просто немного медленнее.
  7. #667
    Standart Power Аватар для US6IQ
    15.09.2007
    Мариуполь
    55
    452
    14
    Я вообще пользуюсь RAC базой с подмонтированного образа, а если нет, то в инете...
  8. #668
    Радиолюбитель
    17.12.2005
    nr Калининград
    59
    2,952
    1038
    912
    Скачал и установил QRZHTTPLookup, фактически такой мини-браузер. Не совсем разобрался с описанием, как это дело "встроить" в Логгер ?
    Может кто обьяснит на "великом-могучем" ? )
  9. #669
    13.10.2004
    665
    117
    87
    В окошке QRZ-lookup/Toolbox/Setup/Setup external module to use укажите путь к QRZHTTPlookup.exe. После этого, если у Вас активирован авто-лукап, эта примочка начнёт сама обращаться в сеть за инфой котрая и с небольшой задержкой будет отображаться в окне лукапа логгера32.
  10. #670
    Very High Power Аватар для RA3TT
    16.03.2006
    Нижний Новгород NN 07/с. Безводное NN 45
    76
    2,609
    1858
    577
    Цитата Сообщение от UA9KW Посмотреть сообщение
    3,14,0
    Дело не в этом. Просто QRZ.COM дал дополнительно 30 дней, когда все будет по-старому.
    Но этот период подходит к концу. В 3.16 с помощью внешних примочек можно работать в двух вариантах: прямой доступ (если есть подписка) и путем захода на бесплатную страницу и сбора данных в соответствующее окно Логгера (работает, естественно, медленнее, но терпимо)
  11. #671
    Радиолюбитель
    17.12.2005
    nr Калининград
    59
    2,952
    1038
    912
    to DL5XJ
    Спасибо, Николай, все получилось, только при этом еще выскакивает окно QRZHTTPLookup с результатами поиска. У вас также ?
  12. #672
    13.10.2004
    665
    117
    87
    RU2FM: Да. Но если оконо это минимализировать/свернуть то в дальнейшем оно мешать не будет, будет видно только в полосе задач.
    Кстати, пока писал, игрался лукапом. Последние минут 20 приходит отлуп от qrz.com и посылает к админу. Похоже, парни, недолго этой халяве жить...
  13. #673
    Радиолюбитель
    17.12.2005
    nr Калининград
    59
    2,952
    1038
    912
    Спасибо еще раз.
    Попробовал, несколько позывных поискал, работает, никуда не "посылает" )
    (я зарегистрирован на сайте qrz.com)
  14. #674
    Silent Key Аватар для UT3IB
    24.02.2006
    Енакиево, Донецкая обл.
    77
    410
    33
    3,14,0
    3.15.0
    Информацию с qrz.com получаю. На сайте регестрирован.
  15. #675
    Low Power
    09.09.2006
    г.Чернигов
    80
    12
    После update версии 3.15.0 на версию 3.16.0 информацию с qrz.com не получаю.
    Досадно,однако!
  1. Как состыковать Logger32 с DX-Cluster(oм) OH2AQ ?
    от DL1KBX в разделе Аппаратные журналы
    Последнее сообщение: 08.03.2006, 10:59
