Юра, привет, с наступившим,
а какая версия у тебя? У меня это началось сегодна сразу после апдейта на 3.16. Может даунгрейд попробывать.
В описании на 16-ю версию четко указано, что начиная с этой версии online поиск на QRZ.COM убран.
IMPORTANT NOTES:
a) From this release forward, Logger32 will NOT provide Internet lookup
capability to QRZ.com Those wishing to access this service must use third
party (non Logger32) modules which are available.
Since inception, Logger32 has accessed QRZ.com through an external module
(not part of Logger32 but written by the same author) called QRZLookup.exe.
and the collected information has been forwarded to a routine within
Logger32 to display the results. Data was provided by QRZ.com in a high
throughput proprietary format that was free from advertising. The policies
of QRZ.com have changed and the direct data feed for Logger32 is no longer available.
The QRZLookup.exe module no longer works, and has been removed from the distribution
package. This file together with QRZ.txt are no longer used and can be deleted from
the Default Logger32 directory. However the display window remains as part of
Logger32 and can be filled with data from the external interface.
Sample source code of a non functional (it doesn't go anywhere or retrieve any data)
external InternetCallsignLookup module is (or will be) provided at the Logger32
website. Programmers can use this as a skeleton to access whatever database they choose.
[There will be no QRZSubscriberXMLLookup.exe or any other Internet callsign Lookup
modules provided as part of the distribution.]
Looking forward, beyond this release, the current Hamcall.net lookup capability will
be removed and those requiring access to this database will (like QRZ.com users) have
to rely on the good auspices of other programmers to write an appropriate module.
Здравствуйте.
Подскажите, пожалуйста, что нужно сделать, чтобы при печати наклеек утилитой Логгера из Worda, получался такой же формат даты, какой установлен в журнале? Сейчас формат даты печатается в соответствии с ADIF. Можно конечно править формат вручную для каждой наклейки, но это как-то несерьёзно. Обычно я печатаю наклейки в BV7, а тут подвернулось несколько листов "самоклейки", для которых замечательно подходят Логгеровские заготовки под Word.
Спасибо.
Юра, она внеслась из предыдущих наших связей.
Ну вот, два дня с этой "примочкой" от n2amg отработал.
Если окно проги держать в свёрнутом виде только в таск баре, то разница с прямым лукапом почти незаметна. Просто немного медленнее.
Я вообще пользуюсь RAC базой с подмонтированного образа, а если нет, то в инете...
Скачал и установил QRZHTTPLookup, фактически такой мини-браузер. Не совсем разобрался с описанием, как это дело "встроить" в Логгер ?
Может кто обьяснит на "великом-могучем" ? :))
Дело не в этом. Просто QRZ.COM дал дополнительно 30 дней, когда все будет по-старому.
Но этот период подходит к концу. В 3.16 с помощью внешних примочек можно работать в двух вариантах: прямой доступ (если есть подписка) и путем захода на бесплатную страницу и сбора данных в соответствующее окно Логгера (работает, естественно, медленнее, но терпимо)
to DL5XJ
Спасибо, Николай, все получилось, только при этом еще выскакивает окно QRZHTTPLookup с результатами поиска. У вас также ?
RU2FM: Да. Но если оконо это минимализировать/свернуть то в дальнейшем оно мешать не будет, будет видно только в полосе задач.
Кстати, пока писал, игрался лукапом. Последние минут 20 приходит отлуп от qrz.com и посылает к админу. Похоже, парни, недолго этой халяве жить...
Спасибо еще раз.
Попробовал, несколько позывных поискал, работает, никуда не "посылает" :))
(я зарегистрирован на сайте qrz.com)
После update версии 3.15.0 на версию 3.16.0 информацию с qrz.com не получаю.
Досадно,однако!
