Kaким будет наш вопрос догадаетесь?
Анонсирован выход версии 3.14.0. В ближайшее время файлы будут выложены на сайте программы.
Release change notes for Ver 3.14.0 as of....... 19 Oct 2008
1) Code added for the CW Machine (Software only) to support SO2R (of PTT and
CW keying) when using a shared serial port
with the radio. See new option on CW Machine Keyer Setup Window. The RTS
(PTT) and the DTR (CW) signals from the
software keyer simply switch over to the other radio comm port under the
control of CTL_T.
2) Corrected a couple of bugs when showing the Grayline and the home QTH in
the azimuthal displays in the Tracking Window.
3) If you now paste text to the CW Machine using the right mouse click
facility, all CR/LFs are removed from the text and
replaced with a space.
4) Changes made to speed up the code associated with the band maps.
5) If an Icom user (non IC-735) wants the SSB bandwidth to be other than the
default, modify the section(s) in the INI - [Icom
Filter 1] and/or [Icom Filter 2] to include the line SSB Filter=xx. Se the
Help file for further information
6) Added support for the FT-450 and FT-950.
7) Fixed a bug in the "Word Out" function in RTTY.
8) New messages have been added to the external interface.
A new message APP_DXSPOT_CLICKED has been added. This message is sent to
the external application when the user clicks on
a DX Spot (in the DX Spot Window, or any of the BandMap Windows) in
Logger32. Details of the message format are in the
external interface documentation.
Application -> Logger32 Message 19: If lParam is 0 then Logger32 Mode from
BandPlan option is turned off. If lParam is 1 then
Logger32 Mode from BandPlan is turned on. If lParam is 2 then Logger32 will
respond with a message 103 indicating the Mode
from BandPlan in the lParam. If your application uses message 19, remember
to set the value back to the original setting when
your application closes
Logger32 -> Application Message 103: This message is sent in response to
receipt of a message 19 with lParam of 2. The
message 103 will have an lParam of 0 if the Logger32 Mode from BandPlan
option is off and an lParam value of 1 if the Logger32
Mode from BandPlan is on.
9) Code changes to WPX calculations. AA6AA/7 is now AA7. Previously,
AA6AA/7 translated to W7. This has been done as a
result of changes to the WPX rules.
From enquiries made, there is no cut off date for this change... so previous
WPX determinations by Logger32 could now be
incorrect. The following procedure to update/correct users logs is
recommended:
a) Backup logbook.
b) Export logbook in ADIF format.
c) Delete logbook.
d) Import Logbook with the ignore PFX option selected.
e) Recalc stats.
f) Repeat for all logbooks.
10) For the visually challenged, a change has been made so that the
information labels (Zone, Continent, Country Name and
Sunrise/sunset) on the Logbook Entry Window automatically adjust to match
the field labels (with the exception of colour, which
remains black).
11) Corrected a bug in the display of information in the Previous QSO window
following a sort.
коллеги здравствуйте. закачал логгер 32 . в этом деле я новичок. собрал интерфейс на мах 232.может кто подскажет какая нужна программа для работы этого интерфейса.и если русский перевод для этой программы.тупо перевод я пытался понять - не вышло.влад.:russian_roulette:
Дополнительных программ не нужно, логгер работает с интерфейсом напрямую. Перевода хелпа нет, но интерфейс самой программы русифицировать можно
http://logger32.qrz.ru
Не хочет он работать эта связка! все настройки выполнены правильно, на других программах все работает, то есть интерфейс иправный. В окне дебаггера CAT интерфейса вижу, что идут неправильные команды. Как это исправить?
Спасибо
А можно ли прикрутить к логгеру список LoTW юзеров? чтобы при вводе позывного видеть, пользуется корреспондент LoTW или нет... список есть.
P.S. Синхронизацией LoTW пользуюсь. Интересует видеть эту информацию на том, кого еще нет в логе.
Можно. С помощью CheckCall, которая лежит на YahooGroups в группе Logger32 в разделе Files в папке Logger32 Utilities. И еще понадобится текстовый файл со списком пользователей, который можно взять здесь: http://www.hb9bza.net/lotw/
Всем доброго дня.
Где-то в теме упоминалось о возможности настроить в программе количество простых дипломов больше трех, кажется кто-то сделал около 20. Хотелось бы узнать об зтом по-подробнее.
Сообщение от RA3TT
RA3TT de RK3DSW
Просьба: выложите прогу CheckCall в этой ветке.
Заранее благодарю! 73!
Добавлено через 4 минуты
RA3TT de RK3DSW
Вложение 15634
Added User_1(2, 3) to transfer. Previously used file is stored. Bug fix. See version history in Help file.
Обновляемый список LoTW пользователей:
http://www.hb9bza.net/phpmv2/phpmyvi...FILE:lotw1.txt
