Like Tree1829Спасибо
Тема: N1MM Logger
  1. #3691
    High Power Аватар для UA9LAO
    16.11.2005
    Tyumen (TN-03)
    537
    744
    362
    Никто не любит читать документацию, а там много про что рассказано:
    TOUR command - A very few contests allow for multiple sessions in which you
    can work the same station in every session for QSO credit. You can enter TOUR
    into the Entry window in place of a call sign to reset dupe checking at any time
    before or during the contest. This command has 2 required parameters that are
    entered into the Sent RST field, separated by a forward slash "/". The first
    parameter is the time when the current session begins (GMT) and the second
    parameter is the duration of the session. The format for both parameters is
    hhmm. For example, 1200/30 means the session starts at 1200Z and has a
    duration of 30 minutes. The minimum value for the duration parameter is 10 (10
    minutes). If the TOUR command is entered without any parameters, the current
    values of the start time and duration will be displayed. The default values are
    0000/00.
    o At the beginning of each session the start time and duration will be
    displayed in the status field at the bottom of the Entry Window. After the
    first QSO has been logged during the new session you should see the
    Multiplier window reset and dupes will be reset for this new session as
    well.
    o Most of the contests supported by the Logger do not need this command
    but some (mostly Russian and Ukrainian) have it built into the contest
    module and do not require it entered manually.
    o If you are planning on using TOUR command with other contests, keep in
    mind that settings for it will be lost when the Logger is restarted. If the Snt
    (sent RST) field is not displayed in the Entry window, you will not be able
    to use this command.
  2. #3692
    01.12.2010
    Челябинск
    2,164
    2566
    1990
    Цитата Сообщение от UG3G Посмотреть сообщение
    Тогда попробуйте скачать с сайта авторов N1MM+
    https://n1mmwp.hamdocs.com/mmfiles/pop_ythcup-udc/
    В предыдущем сообщении я погорячился
    Это в N1MM Classic файл не работает, а в N1MM+ работает!
  3. #3693
    Покинул форум
    21.06.2009
    55
    3,676
    2030
    2226
    Доброе утро!
    Юрий! Игорь UG3G подсказал совершенно правильно - приведенный в ссылке UDC как раз написан для молодежного первенства им. Попова.
    Евгений! Возможно я Вас не совсем понял, но в логе LZ Open команда TOUR работать не будет. Ee ввести будет невозможно - там в окне нет поля RST Sent, есть только Sent Exchange.
    If the Snt (sent RST) field is not displayed in the Entry window, you will not be able
  4. #3694
    01.12.2010
    Челябинск
    2,164
    2566
    1990
    Евгений,
    вопрос был в том, где оперативно взять готовый UDC файл конкретных соревнований, а не писать с "нуля", не имея в этом никакого опыта...
  5. #3695
    Радиолюбитель Аватар для UG3G
    24.10.2005
    Липецк
    3,055
    2353
    10423
    Юрий, в этом UDC много строк (команд), которые старый добрый Classic просто не понимает.
    И ещё один момент - при приёме (и введении) номеров в логгер желательно добавлять вручную "leading zeroes" при номерах меньше 100, иначе "Гаврила" кривая получается...
    Последний раз редактировалось UG3G; 10.10.2019 в 10:46.
    73! Игорь. RA5G & RT5G team.
    RCC#267, RCC HoF#20, SRR#480064.
  6. #3696
    Standart Power Аватар для R4KO
    24.02.2017
    с. Жигули
    132
    113
    136
    Игорь, этот UDC называется правильно, но он вообще не работает... QSO в ЛОГ не вводятся, ЛОГ требует повторить All Again...
    приветствую, сейчас попробовал этот udc, на n1mm+ все работает. принятые номера надо вводить полностью с нулями, правда передавать надо номер из подсказки внизу окна ввода позывного, они мелкие немного не удобно. и в сработанных qso второй части переданного номера не видно, но в отчете все есть, номера переданных и принятых номеров верные. туры по 60 мин.
  7. #3697
    03.02.2006
    20,698
    10207
    5468
    Подскажите, что в N1MM+ нужно включить, чтобы при нажатии на Ентер в окне ввода QSO курсор не просто перескакивал в поле "номер", но и в CW передавал позывной или корреспондента, или свой в зависимости от CQ/SP?
    Или такого нет в N1MM?
  8. #3698
    Покинул форум
    21.06.2009
    55
    3,676
    2030
    2226
    Откровенно говоря не совсем понял что Вы имеете в виду. Но прежде всего попробуйте активировать ESM mode.
    Config > Enter Sends Мassage. И Config > Configure Ports, Mode Control, Winkey, etc... > Function key > ESM ...
  9. #3699
    03.02.2006
    20,698
    10207
    5468
    Спасибо за ответ! Собственно я так и думал (в свое время на N1MM работал в контестах). Но что то не работает...
    ...Разобрался - работает! Еще раз спасибо за подсказку!
  10. #3700
    High Power Аватар для RA9AP
    22.09.2009
    Южноуральск
    864
    1032
    424
    Мужики!
    Может не совсем по теме, но у меня проблема с кластером в N1MM+ работает только RBN (автоматом соединяется) а остальные кластеры не подключаются. Я привык работать с VE7CC, но он что-то ни в N1MM ни в N1MM+ не работает пишет Connection to VE7CC.NET failed где собака порылась?
  11. #3701
    23.01.2009
    Харьков
    1,689
    1077
    582
    Сейчас проверил, сервер VE7CC работает, споты рассылает.
  12. #3702
    05.01.2012
    51
    396
    144
    38
    Посмотрите корректно ли прописан адрес dxc.ve7cc.net port 23
  13. #3703
    22.09.2009
    Южноуральск
    864
    1032
    424
    Разобрался не верный адрес был прописан, сделал VE7CC-1 VE7CC.NET:7373 все заработало
  14. #3704
    29.11.2013
    Уральск
    46
    12
    Здравствуйте. Как отключить функцию что-бы на передачу не передавался не полностью внесенный позывной?
  15. #3705
    High Power Аватар для RA9JM
    16.11.2006
    Нижневартовск, Россия
    800
    254
    12
  1. Программа N1MM
    от RV3AA в разделе Соревнования
    Ответов: 9
    Последнее сообщение: 17.04.2025, 05:45
  2. N1MM в минитестах
    от adani в разделе Соревнования
    Ответов: 21
    Последнее сообщение: 22.10.2021, 19:25
  3. N1MM & PACC
    от RL3AF в разделе Соревнования
    Последнее сообщение: 16.02.2007, 13:21
  4. Logger 32
    от UA9KAZ в разделе Аппаратные журналы
    Последнее сообщение: 16.01.2007, 11:27
  5. Программа N1MM
    от R3AA в разделе Аппаратные журналы
    Последнее сообщение: 23.03.2006, 19:10
