05.08.2016, 16:13 #1726
- 13.04.2016
- Westdale
- 75
- 30
- 18
- 49
Many thanks to Igor!
TO IGOR,
I and many others in the global community give thanks to you & others
in helping to push this gift of JTDX to the Ham Radio community.
We have finally reached another milestone in its current development with the soon to be released
wsjt-x 1.7.0 which will open up closed barriers as exists at present for its future progress.
Have taken the liberty Igor of copying your post across to Facebook JTDX for the members which will be
something for them to chew on tomorrow. I am sure that there will be a collective big heave of relief in regards to getting EXE'S
in the days to come !!!
To cap off me and Roger( VK3FZ) think v16.4 is the bee's knees mate.
"Live Long & Prosper" as Mr Spock would say on Star Trek!
Cheers
Peter, VK6KXW
05.08.2016, 17:18 #1727
- 31.05.2012
- Железногорск
- 71
- 729
- 353
- 18
Новые моды уже доступны для всех! Пора переходить на QRA64! Сам лично декодировал несколько раз уровни -32 дб!
R5WM
05.08.2016, 18:04 #1728
- 13.04.2016
- Westdale
- 75
- 30
- 18
- 49
[wsjt-devel] WSJT-X v1.7 Alpha Release
Hi all,
I have posted a Windows installation package for an Alpha Release of
WSJT-X Version 1.7 r7005 here:
http://physics.princeton.edu/pulsar/...ha-1-win32.exe
You can read about new features in v1.7 (relative to v1.6) here:
http://physics.princeton.edu/pulsar/...7_Features.txt
Installation packages for OS X and Linux should be available within a
few days.
Please heed the message displayed at program startup, and send us
reports that will help to improve WSJT-X.
-- 73, Joe, K1JT, for the WSJT Development Team
Enjoy
Peter,VK6KXW
05.08.2016, 19:48 #1729
- 05.03.2015
- 5,570
- 7959
- 807
JTDX v16.4 software open for public access - софт JTDX доступен для скачивания
Пришлось удерживать JTDX почти полгода в состоянии исходного кода в ожидании выпуска WSJT-X v1.7, и этот момент настал!
Теперь можно скачать установочный exe файл JTDX v16.4 для операционки MS Windows здесь: https://cloud.mail.ru/public/3HUT/QuTShGikn
Файл WSJTX.INI, содержащий настройки, отличается и несовместим между JTDX и WSJT-X, при переходе с одного софта на другой необходимо либо при запуске использовать в ярлыке ключ --rig-name=
либо удалять файл с настройками и конфигурировать софт заново.Последний раз редактировалось UA3DJY; 05.08.2016 в 20:02.
05.08.2016, 21:18 #1730
- 05.03.2015
- 5,570
- 7959
- 807
06.08.2016, 18:28 #1731
- 24.08.2006
- Славяни
- 298
- 203
В4 по диапазонам
73 Vytas LZ2VQ ex LY3BG
06.08.2016, 19:03 #1732
- 05.03.2015
- 5,570
- 7959
- 807
06.08.2016, 19:25 #1733
- 18.01.2015
- новосибирск
- 73
- 1,686
- 128
- 55
06.08.2016, 20:52 #1734
- 05.03.2015
- 5,570
- 7959
- 807
Joe K1JT предполагает использование QRA64 в основном для связи через Луну, возможно есть какие то проблемы с устойчивостью декодирования при большом количестве сигналов на диапазоне:
' As mentioned in the docs, QRA64 was designed
primarily for EME, where signals are always marginal.
-- 73, Joe, K1JT'
06.08.2016, 22:11 #1735
06.08.2016, 22:41 #1736
- 01.07.2011
- Днепропетровск
- 2,997
- 2951
- 220
В4 по диапазонам
Снял галку Show DXCC... и все новые позывные засветились цветом B4.Последний раз редактировалось US-E-12; 06.08.2016 в 22:58. Причина: Добавление
07.08.2016, 05:09 #1737
- 13.04.2016
- Westdale
- 75
- 30
- 18
- 49
Future Utilisation Of QRA64 and Sub Modes at HF in JTDX.
Hello to the forum membership I have been following for some time
the expressions of interest of QRA64 at HF on this forum and the DEVL
Group. It has a bright future contrary to what some are saying below,I can
remember the NO clique telling Igor DON'T what ever you do any more work on
JT65 for HF that the sky would fall in... yada yada! History has proved these
gurus totally wrong! At a current existing -32db sensitivity
I strongly contend that we cannot turn our backs on the window of opportunity
afforded with exploring it in JTDX at HF. As has happened with JT65 it will get better
and better if the group helps Igor and Co go down this path.
What say you?
Hi all,
It's OK to play with and test QRA64 at HF, if you wish. Some of our
earliest tests of the mode were done on the 20m and 30m bands.
But Greg is right: the mode is intended for EME, where every dB of
sensitivity matters a lot. We do not recommend any large-scale shift
from JT65 to QRA64 for HF use -- not least because at present we have
included no "multi-decode" capability for the QRA64 decoder. It's made
to decode just one signal in the pass band.
These things (and many other subtleties of usage) will be explained in
forthcoming additions to the User Guide. In the meantime, alpha testers
will need to figure things out for themselves.
-- 73, Joe, K1JT
Re: [wsjt-devel] QRV QRA64
I'm confused on this thread. Joe has stated multiple times, the QRA
mode(s) are designed for EME use. Why are we tested this on HF?
Is there a plan to tweak the mode(s) for general HF use also? It seems
to me, if the current code is set up up for EME, testing on HF would only
confuse matters, but, I may be missing something here.
73's
Greg, KI7MT
El 06/08/16 a las 18:12, Pino Zollo escribió:
> I am QRV at 14.076 TX3000 in QRA64 mode beaming Europe
Which sub mode QRA64A or QRA64B?
By TX3000 do you mean you're transmitting at 14.076 + 3000Hz?
I guess we should propose some common frequencies and modes to test QRA
in HF. 14.076 is already crowded with JT65 signals.
73,
Dani EA4GPZ.
Pino ZP4KFX
Peter,VK6KXW
07.08.2016, 08:25 #1738
- 05.03.2015
- 5,570
- 7959
- 807
Hi Peter,
On first sight QRA64 working similar(but not the same) to the matched filter (hinted decoding) for second and other subsequent signal decoding.
Main benefit of QRA64 is 3.2 dB advantage for first time signal decoding versus JT65 FTRSD, that means approximately -29dB SNR sensitivity, while CALL3 database is not needed for QRA64 mode.
Sure, I will be looking at QRA64 source code for next several weeks, but I guess we need in some time to get QRA64 accepted by the community for HF tests and QRA64 HF frequency bands defined.
73 IgorПоследний раз редактировалось UA3DJY; 07.08.2016 в 08:47.
07.08.2016, 08:44 #1739
- 05.03.2015
- 5,570
- 7959
- 807
Еще одну кнопку можно добавить, но при возможности желательно избегать добавления кнопок - потому что изменится формат файла WSJTX.INI и новый софт придется конфигурить с нуля.
В любом случае еще есть над чем подумать и поработать до выпуска этого функционала в общий доступ.
Отдельная тема индикация повтора с учетом JT65/JT9.
07.08.2016, 12:19 #1740
- 05.03.2015
- 5,570
- 7959
- 807
планы по улушению декодирования JT65 в JTDX
Примененные в filbig.f90 и fil6521.f90 ФНЧ фильтры Кайзера-Бесселя с конечным импульсным откликом имеют фазо-частотную характеристику, каждый свою, и вносят фазовые искажения в сигнал.
Если для фильтрации во временной области fli6521.f90, так так фильтры симметричны относительно центрального отсчета, возможно фазовый сдвиг нулевой, то для фильтра в filbig.f90 c фильтрацией в частотной области фазовый сдвиг скорее всего линейный.
Если удастся разобраться с фазо-частотной характеристикой примененных фильтров и способом ее компенсации в исходном коде то возможно дальнейшее повышение эффективности декодирования JT65 сигналов в JTDX.
