Сообщение от
R5AJ
Пессимист это хорошо информированный оптимист.
Привожу список ожидаемых доработок от 15.12.2022, опубкованный на англоязычном форуме FTdx101:
1. Provide the option for band scope averaging.
2. S meters seem insensitive compared to other rigs. Loud CW sigs barely nudge the needle.
3. PRESET overrides setting in other modes if it is active (CW and SSB LCUT and HCUT settings, etc.). If other modes are selected, PRESET should deselect.
4. CW ZIN (auto spot) works erratically. It will jump + 1.28kHz on occasion and then again on subsequent presses. Sometimes down instead.
5. SPOT should be a toggle. A long press of the Zin/Spot button should toggle the side tone on, and a short press to toggle it off. Now, you need to hold it to hear the side tone, so it takes two hands to zero beat a cw sig, one to hold the button and the other to tune.
6. Improve the purity of CW sidetone.
7. Improve QSK speed. Also, T/R relays are noisy, particularly when using ANT3 for RX with TX on 1 or 2.
8. Allow RX CLAR to function in the fixed preprogrammed 60m channels. (USA)
9. Show correct carrier frequency for U-SSB in the preprogrammed 60m channels rather than the channel center frequency. (USA)
10. CLAR - provide selectable MPVD tuning steps (1, 5, 10 Hz).
11. Provide PEP indicating power meter.
12. Provide linear bar meter option instead of faux needles, with bar indicating average and sticky dot indicating PEP. (e.g. FT1000MP radios)
13. Increase power adjusting rate. It takes too many turns of the multi knob (or MPVD ring if CS is set to power) to go from low to high and vice versa. Ideally it would be logarithmic or have acceleration.
14. Put a permanent display of TX power setting on the screen.
15. Add a settable TUNING POWER levels for tuning amps or ant tuners.
16. Store TX power per band so no need to change RF power setting on different bands with the same amplifier, or different amps.
17. Have separate ATU memories for ANT1, ANT2 and ANT3.
18. Have programmable filter pre-sets per mode for roofing filter, WIDTH, SHIFT.
19. Add a numeric indication of filter WIDTH in the Filter Function Display.
20. Reduce span of Filter Function Display for narrow CW filters (show passband wider on the display).
21. Add numerical S MENU LEVEL to the spectrum’s status bar.
22. Increase the time pop-ups stay displayed or make it selectable: changing meter function, power popup, monitor level popup, setting keyer speed, width and shift changes, APF width, etc....anything where holding a button or touching the screen pops up a setting.
23. When copying from MAIN or a memory into SUB, the WIDTH light doesn’t illuminate if the MAIN light wasn’t illuminated despite the SUB WIDTH being less than the SUB roofing filter width.
24. MAIN and SUB buttons should toggle each other. Pressing MAIN when illuminated should switch to SUB and vice versa. This is how the red TX buttons just above the MAIN and SUB buttons work.
25. Increase the size of the font for the frequency displayed along the bottom of the spectrum display, or make them user settable.
26. Add the ability to alter the AGC slope/threshold characteristics - the RX close in performance of the 101 is excellent, however the pile-up handling performance i.e. 'within the passband' performance needs improvement, especially on CW.
27. Have DC voltmeter work all the time instead of just during transmit.
28. Back button to step back from inadvertent or temporary changes.
29. Add mouse clickable FUNC button,
30. Add mouse clickable buttons for physical buttons across bottom of display.
31. Enable mouse scroll wheel to change menu values instead of needing to use the MULTI knob.
32. Enable tuning VFO with mouse scroll wheel or dragging, not just clicking in the spectrum display.
33. VFO LOCK locks only the main dial. Should lock changing frequency via touching the spectrum display and lock the MPVD when it is in its default 10X VFO mode.
34. SYNC should work for all methods of changing frequency, VFO, MPVD, touching spectrum. Now it only works for the main VFO dial.
35. On MP in RX, run the fan at constant slow speed rather than cycling on/off every 20 seconds.
36. Screen saver does not reliably come on.
37. SPLIT does not turn sub frequency display red unless SUB RX button is lit. There is no indication on the TFT display that you’re operating split except for the cursors in the spectrum display.
38. Moving manual notch is too slow. Provide acceleration for the knob.
39. Record QSOs to the SD card.
40. Include a voice memory/keyer with auto repeat and delay.
41. Add Monitor and CW side tone to USB/rear audio outputs for recording both sides of QSOs.
42. Include provision to turn the MIC bias voltage on/off on the mic audio line as needed.
43. Customizable spectrum display spans.
44. Customizable TX frequency limits.
45. Provide a speaker output such that when using two speakers like the FPS101 and SP101, MAIN and SUB can be separate or combined in both speakers. e.g. MAIN in L&R, SUB L&R, MAIN L and SUB R.
46. Provide a schematic for the FPS101. A block diagram and theory of operation would be very helpful additions.
47. Reduce spectrum scope gain during TX so display is representative of actual TX signal bandwidth.
48. Make headphone and speaker monitor levels separately adjustable. Or make the levels more comparable in SSB and also between CW and SSB.
49. Show the DNR level on the display when the button is pressed. Now, the button has to be held to get the level to display.
50. CAT connection can interfere with SD card operation and some other operation and functions.
51. Make CW decoder speed setting independent of CW keyer speed setting. Or better, remove need to set speed for decoder by making it auto detect speed.
52. Settable spectrum scope end points instead of only FIX with set SPAN choices.
53. Settable spectrum scope end points per band stack. Useful when using band stacks for different modes.
54. Be able to independently set RF GAIN and SQUELCH. Have them independent for both MAIN and SUB.
55. If SSB Break-In is enabled, then pressing PROC button does nothing. THE FIX: Key up and press PROC while and the light will toggle on/off each time. Just remember you have to transmit to change PROC.
