10.02.2017, 07:26 #331High Power
- 19.03.2012
- Новосибирск
- 953
- 1033
- 672
В меню Tools нужно выбрать Repeat Loop. Там и длинна паузы устанавливается.
Кстати вышла новая версия программы сегодня.
Hi all.
After a bit longer time than usual, version 2.3.10 is finally released.
There are a lot of fixes included in it as well as some new features.
Some of them are noted in release notes and also in this email.
New antenna server application is now supported, we work on compatibility
support for few
devices there (currently K1LZ and MOAS II by K1XM is supported). Need more
testing on this,
so this isn't shipped with this version yet.
The team is now more focused on new multiplatform edition v3, so hope to
start
beta testing very soon. But more on that in separate topic, when it will be
ready.
Enjoy.
73,
Chris - 9A5K
Ver 2.3.10
- When visible in log lines, operator name and frequency wasn't refreshed
until scrolling wasn't activated. Fixed. (TNX G4IRN, 9A3OS)
- Some fixes added when ESM mode is used in combination with SHIFT binding
to opposite radio and RST hidden. (TNX LZ5VK)
- New language available: Norwegian. (TNX LB3RE)
- IARU 2m contest added as new contest. (TNX M0CKE)
- EUHFC and SCC RTTY Contest - Cabrillo output adjusted according to the
current rules. (TNX S57AW)
- New contest supported: RSGB International DX contest. (TNX M0CKE, EI3JE)
- Alt + space - grabs last known callsign from digi decoder window if
exists. Otherwise, works as before, grabs call from partner window. (TNX
K3JO)
- $OTRSP=x macro implemented. Send custom commands to OTRSP device. (TNX
K3JO)
- ARI DX contest config changed to new rules. (TNX IK2NCJ)
- When contest with periods was active, radio 2 entry line period wasn't
updated correctly. Fixed.
- QSO editing, problem with qso editing, when dupe qso existing in the log
after edit qso. Multiplier wasn't updated correctly. Fixed. (TNX IU3AZC)
- UBA PSK63 config adjusted to new rules.
- NAQP/NASprint config changed for new rules. (TNX W9PA)73! Андрей RW9OW
10.02.2017, 09:03 #332
16.02.2017, 12:26 #333Very High Power
- 13.08.2010
- Томск
- 1,166
- 1310
- 561
из другой темы перетащил RN6L пишет :
Пока приходится прыгать. В основном это из-за того что не все программы говорят голосом набранный позывной, поэтому пока при необходимости пользую N1MM. Хотя недавно вышла новая версия, может там уже есть эта фишка, не проверял и аннонс внимательно не читал. Еще у меня возникла проблема с RTTY. Матюкался DXLog на что то, поэтому перед WPX зарядил тоже N1MM, но и там какая то засада с манипуляцией вышла, скорее всего из-за интерфейса. К тому же редуктор на новой антенне замерз, в общем все в кучу, поэтому вообще не стал участвовать, хотя очень хотелось антенну испытать. В общем, как говорил Фоменко на "Русском Радио" - "любовь это не просто так, ею надо заниматься"
Любая инфа, в т.ч. и по поводу "светофора" конечно полезна. Вованыч, я повторю (вдруг не заметил) свою просьбу постом выше про макрос. Макросы штука интересная, я ума не приложу как у меня на одном из компов получались в режиме SO2R контрольные номера в виде 000. Ты еще смеялся, но это реально было на рабочем компе. Потом когда на выходной приехал в деревню, такого эффекта не получилось.
По поводу говорящих файлов , это будет на другой мултиплатформе - версия 3 - так обещали
Василий , ты в каких контестах марафонах работаешь , тебе эта фича нужна как воздух ?? Чота с номером за 2-3-5 тыщи QSO замечен не был Все время вижу отмазки , то погода , то рыбалка )).. - .... шучу.
В DIGI - все работает супер ! 4 декодера поддерживает . Просим автора сделать , что бы в отдельно настраивать макросы для CW и DIGI но он пока этого не сделал.((( На что ругалась программа , если не описаны симптому- помочь не смогу.
По поводу работы места на поиск чтобы не резервировался номер а можно было вписать инфо в RCVD поле - сделать нужно так
В MSGS поиска ( РЕЖИМ ПОИСКА S/P активируется в Tools - в онкно часов становится желтым появляется S/P )
Зовем кнопкой F4
Макрос должен выглядеть так
$FOCUSRCVD $MYCALL - значит перевести курсов в поле "номера" и отправить свой позывной
отвечаем корреспонденту кнопкой F2
$RESERVENR ++$RST-- $SERIAL $CR - что значит - зарезервировать номер - передать rst - передать серийный номер - $CR - внести в лог
ПО поводу 000 номера
Ты включил USE NUMBER SERVER - что значит использовать номерной сервер
НО в в конфиге сети - Start number server ты его не активировал
Вот программа обратилась к серверу номеров , а сервера то и нету и выдала 000
Я и намекнул - кури хелп
, не понятно - спрашивай тут !
Насрать - ( читай с пробелом) т.е. много ))) - поможем !!!
73 !Последний раз редактировалось R9IR; 16.02.2017 в 12:33.
Вованыч R9IR
04.03.2017, 02:06 #334
Владимир опишите действия "парикмахера" при "причёсывании" через 5м-contest.
04.03.2017, 06:49 #335
10.03.2017, 19:12 #336Very High Power
- 13.08.2010
- Томск
- 1,166
- 1310
- 561
По просьбам и требованиям трудящихся в Чемпионате РФ :
Исправил ошибки в модуле SSB
Добавлен модуль под Чемпионат CW
В оба два модуля добавлен Крым и Севастополь
Разрешены переходы для MOST
Сделан модуль RUCH_rgx - автоматически подставляет зону в номер , определяет станции РФ , в БМ фильтрует "иностранцев" , они будут показаны как "ненужные", их можно по желанию скрыть. ( ранее все станции не сработанные и тех кто не был в базе - на БМ обозначались как DUPE)
Туры переключаются врукопашную Ctrl+F10
Более ничего не осилил
т.к.
The beer was over (((
RUCH.txt и RUCH_CW.txt - положить в папку Contest
Модуль RUCH_rgx - положить в папку Database
injoy!
73 !Последний раз редактировалось R9IR; 10.03.2017 в 19:20.
Вованыч R9IR
21.04.2017, 10:17 #337Very High Power
- 13.08.2010
- Томск
- 1,166
- 1310
- 561
Кто будет работать в Кубке Урала Multi Single замените модуль в папке Contest
Было Включено правило 10 минут для смены диапазона - подправил , теперь можно безпредельничать !
сингл-ОППЫ могут не волноваться , у них все чотко
Вованыч R9IR
23.04.2017, 11:39 #338Big Gun
- 22.01.2003
- пос. Керчикский, Россия
- 13,829
- 5849
- 265
Вованыч, подскажи пожалуйста как настроить отправку клепежа на стадион. Что то у меня крайний раз не получилось...
73! Василий.
23.04.2017, 19:31 #339Very High Power
- 13.08.2010
- Томск
- 1,166
- 1310
- 561
Так это не только я могу подсказать ))
Commands-Live score- поставить птицу Enable auto posting
там же в Setup можно настроить если работаешь на каком-то определенном диапазоне , а так же переодичность отправки и возможно скрыть раскладку по диапазонам - отправлять только очки - , для этого убрать птицу - Send qso/mult breakdown
Что бы проверить - нажми Post now ( отправить сейчас)
Внизу info строке увидишь - нарисуется текст , что данные отправлены на сервер .
В каком контесте отправлял и не получилось ?Последний раз редактировалось R9IR; 23.04.2017 в 19:40.
Вованыч R9IR
24.04.2017, 20:10 #340Big Gun
- 22.01.2003
- 13,829
- 5849
- 265
Да ни в каком пока не получилось... Спросил перед UA1DZ... Я же изучаю на ходу, СТ-шку то давно пользовал, да и не было в ней многого. Просто не нашел меню откуда это управляется... В N1MM многое по другому. Многое проще и оно на виду для ламеров, но поэтому он и "тяжелее" в плане ресурсов.
Спасибо, попробую не забыть до следующего теста.73! Василий.
28.04.2017, 19:44 #341Standart Power
- 04.02.2015
- 285
- 708
- 933
Владимир, этот чудо лог может показывать азимут на корреспондента? Ну не могу найти где должна быть "галка"!
Сергей, 73! RZ9UN
28.04.2017, 22:16 #342Very High Power
- 13.08.2010
- Томск
- 1,166
- 1310
- 561
Да, показывает ,в трех местах можно посмотреть .
В окне Chtck mult - там по умолчанию.
В окнах BMap и cluster ann можно настроить по желанию
В BM закладка list - еще позволяет сделать фильтрацию по направлению
На мультовом/подборном месте стоит AD335 с редуктором RAK он работает по протоколу PSTRotator
Эта программка нормально вяжется с логом, я назначил на одну их клавиш сочетание Ctrl+F12 и клацаю в случае необходимости - ант автоматически поворачивается на корреспондента .
73 !Последний раз редактировалось R9IR; 28.04.2017 в 22:35.
Вованыч R9IR
29.04.2017, 03:56 #343Standart Power
- 04.02.2015
- 285
- 708
- 933
Спасибо! Запустил, работает. Только почему то когда РФ позывные ввожу, и всегда показывает азимут 287 гр или 284 гр.
Сергей, 73! RZ9UN
29.04.2017, 14:03 #344
Скачал Дх лог версия 2. 3. 12. с офиц сайта. Установил, запустил. Система пишет "Лог не зарегистрирован" и ниже цифры 1-2-3. Предлагается нажать на 1. Нажимаю-открывается интерфейс лога.
Нажимаю на 2.
И далее сразу табличка , "сейчас лог будет закрыт" . И все закрывается...
... Появился платный вариант? Чем он отличается от бесплатной версии? Подскажите, плс...
Ранее стояла версия 2.1. 8. Она денег не требовала...
Последний раз редактировалось RX1AG; 29.04.2017 в 14:10.
Валентин, RX1AG :: Посетите мои страницы -- https://rx1ag.narod.ru/audio-muz/song-radio.html -- песни о радио
30.04.2017, 07:17 #345Very High Power
- 13.08.2010
- Томск
- 1,166
- 1310
- 561
Широка страна моя родная ))
Да все верно . У нас по DXCC - три страны Европейская Россия, Азиацкая Россия и Калининград .
Определены три точки QTH локатора . По ним идет определение азимута относительно локатора который ты вводишь при конфигурации .
Поменяй свой QTH локатор - изменится азимут.
Правильный расчет азимута должен быть в некоторых УКВ тестах ( очки по расстоянию) , где данные локатора по DXCC отключены.Вованыч R9IR
299Спасибо
