r6462mod15.2 service pack being tested, should be released soon
mod15.2 is focused on the hinted decoding:
- 'DX Call' 'DX Grid' windows data based additional hinted decoder implemented as partial workaround for CALL3 based hinted decoding SNR degradation. This decoder is not activated if 'DX Call' window is empty.
- hinted decodes will be marked by asterisk to let user distinguish them from the BM/FTRSD decodes. This functionality is not supported in the left window if 'show DXCC and worked B4' activated.
В mod15.2 в качестве частичной компенсации снижения SNR при использовании CALL3 файла применил дополнительный декодер с подсказкой использующий данные из окошек "DX Call" "DX Grid". При пустом окошке "DX Call" дополнительный декодер с подсказкой не включается.
Чтобы позволить пользователю отличить декодирование-подсказку от BM/FTRSD декодирования маркировал первое звездочкой. Этот функционал не поддерживается в левом окне при активации индикации страны DXCC и статуса повторов.
mod15.2 сейчас проходит интенсивное тестирование перед выпуском.
possible ways of further WSJT-X development for JT65/JT9 modes, HF usage
Цитата:
Сообщение от
VK6KXW
Hi Igor,
Hi Peter,
In fact I can see slightly more than 5 dB SNR improvement for hinted decoding (mentioned in your message as a deep search).
But for large CALL3 database size this improvement being decreased to 3 dB, suspecting there could be bug in the initial hinted decoder code.
I have already asked Joe and Steve for early decoding, but now I have changed my opinion and thinking about JT65 multithreading as the best approach where 3 and more CPU cores could be utilised.
At the moment WSJT-X in JT65+JT9 mode using only two CPU cores simultaneously.
With JT65 multithreading one can implement more than 6 decoding passes, that would be required probably in an year, when JT65 HF band utilisation will exceed 40 signals per interval.
mod15 can easily decode 30 JT65 signals per interval, while more decoding passes would be required to maintain high JT65 decoding efficiency if number of the signals exceeding 40.
About expansion of the signal reporting range down to -35..-40dB SNR: it is very easy but it is not a good idea and there are two reason to avoid this modification:
1. WSJT-X can not measure JT65 SNR properly if it is below -27dB, I am observing up to 3 dB error for -31dB SNR signals.
2. Such modification would cause large expansion of the hinted decoding CALL3 processing and calculations, would increase hinted decoding time and could affect decoded SNR degradation.
For my test I do use simulated files (jt65sim utility), I can put files in the cloud upon request. 1000 files for -31dB SNR signals have approximately 1GB size if archived.
Will put this message in the forum as questions you raised have the public interest.
73 Igor
r6462mod15.2 source code released for public access
Source code, patch file, release notes, test results and various UI options are published there:
Исходный код, патч файл, Release notes, результаты тестирования и исходники разных вариантов интерфейса опубликованы здесь:
https://cloud.mail.ru/public/ByCY/xK8iG2AYL
r6462mod15.2 рекомендации по использованию
Если в окошке 'DX Call' присутствует позывной то при декодировании автоматически активируется дополнительный декодер с подсказкой с фильтрацией сообщений с этим позывным.
Позывной в это окошко можно внести дважды кликнув мышкой на строку декодированного сигнала или внести вручную.
Для декодирования с подсказкой сообщения содержащего грид локатор при ручном внесении позывного в окно 'DX Call'
необходимо еще в окне 'DX Grid' иметь грид локатор этой станции, который можно получить из базы CALL3.TXT нажав клавишу lookup.
Если на конкретном проходе декодирования(всего до четырех проходов) отработал декодер по критерию 'DX Call' то декодер по полной базе CALL3.TXT на этом проходе уже не используется.
Логика и последовательность применения декодеров, для каждого из проходов декодирования:
1.BM hard decision decoder
IF FAILED THEN
2.FTRSD soft decision decoder
IF FAILED THEN
3.'DX Call' based hinted decoder
IF FAILED THEN
4. CALL3.TXT based hinted decoder
mod15.2 WSJTX.ini файл полностью совместим с r6462mod15.1.
Вложений: 1
r6462mod15.2 результаты тестирования
r6462mod15.2 test results:
- approximately 26...39% -31dB SNR signal hinted decoding probability for 'DX Call' 'DX Grid' data
- approximately 28...42% -29dB SNR signal hinted decoding probability for CALL3.TXT data
Exact tests and values can be found in the test_results file.
При срабатывании декодирования подсказки по критерию DX Call вероятность декодирования составляет примерно 26...39% для сигналов с -31dB SNR.
При срабатывании декодирования подсказки по базе данных CALL3.TXT вероятность декодирования составляет примерно 28...42% для сигналов с -29dB SNR.
Вероятность декодирования зависит от сообщения: более защищено от помех и лучше всего 'декодируется' сообщение начинающееся с CQ, по этой причине на это сообщение я в исходном коде mod15.2 понизил пороги срабатывания декодера с подсказкой.
индикация SNR сигналов JT65 при декодировании с подсказкой
Использующийся в WSJT-X алгоритм вычисления SNR JT65 сигналов имеет большую погрешность для сигналов с SNR -31dB, это хорошо видно на результатах тестов, где SNR определяется как -28...-30dB.
И если -30dB это ограничение индикации прописанное в исходном коде, то -28dB уже ошибка вычисления равная 3dB.
Поэтому если в декодировании с подсказкой показывается значение SNR менее -26dB велика вероятность того что оно в реальности может быть на несколько dB ниже.
hinted decoding vs QSB and QRM
Первые впечатления - очень помогает при замираниях сигнала и помехах. Часто бывает что в QSO с DX станцией из-за QSB уходит под шум сигнал на части интервала и FTRSD декодер не декодирует сигнал, при этом выручает декодер с подсказкой.
