14.11.2024, 20:18 #916
- 03.02.2006
- 18,898
- 9101
- 4832
Ant.: UW4HW, Pwr.: ~500 Wtts
15.11.2024, 12:31 #917
- 16.04.2020
I can do that but can you have 2 windows? one showing this month and one showing all time - both showing at the same time??
15.11.2024, 13:47 #918
- 03.02.2006
- 18,898
- 9101
- 4832
Now - not. Only one window. But I need to think about it. Maybe is good idea - to make a separate window for each statistic.
16.11.2024, 19:40 #919
- 26.07.2023
- 35
- 4
Hi Alexei,
Couple of things now I've fixed my login problems on here.
I posted in the past about the fonts in the Awards window doubling in size after restarting the program, when using a theme or skin for the main program.
i have found that it actually happens if the Awards window is actually closed and re-opened, and not just when the program is closed down and restarted.
I was also thinking as a suggestion, that the configuration of the Awards window could be loaded/saved in a similar manner to that of the Band Review windows.
Finally (for now!) I am finding the sound output selection on the DX spots alarm (Setup.. General Setup.. Color setup for Country Status) is changed if another sound device is connected or reconnected. For example, I plug in a Midi device I use to control my SDR software, and LogHX changes the output device to the Midi device I just plugged in (undesired behaviour)
Any way of making the selected sound output device "stick" ?
16.11.2024, 19:58 #920
- 03.02.2006
- 18,898
- 9101
- 4832
17.11.2024, 17:40 #921
- 26.07.2023
- 35
- 4
18.11.2024, 17:31 #922
- 16.04.2020
Any idea what httpgeterror - error code 87, error message : The parameter is incorrect. its from the spotmachineserver.exe
18.11.2024, 20:12 #923
- 03.02.2006
- 18,898
- 9101
- 4832
Log version?
18.11.2024, 23:51 #924
- 16.04.2020
768
19.11.2024, 20:35 #925
- 03.02.2006
- 18,898
- 9101
- 4832
Try this test version -
http://rx4hx.qrz.ru/files/loghx/test..._build_770.exe73 de RX4HX, Alexei, http://rx4hx.qrz.ru
28.11.2024, 15:20 #926
- 16.04.2020
sorry been away with work, says 404 error on the download
28.11.2024, 15:55 #927
- 03.02.2006
- 18,898
- 9101
- 4832
Now download last release 770 -
http://rx4hx.qrz.ru/files/loghx/LogH..._build_770.exe73 de RX4HX, Alexei, http://rx4hx.qrz.ru
28.11.2024, 21:18 #928
- 21.11.2024
Problem when loading new logHX3 version.
29.11.2024, 06:43 #929
- 26.10.2019
- 46
- 17
- 9
29.11.2024, 08:25 #930
- 03.02.2006
- 18,898
- 9101
- 4832
