Как ранее сообщалось, время DT через VAC увеличивается отсюда и последствия,
SDR-1000, VAC только на передачу использую.
интересное письмо в адрес группы Facebook админ которой забанил разработчика (Bill G4WJS) когда последний попросил снять с публикации скомпилированный релиз 6278.
Если кратко - Bill G4WJS объясняет что публикация в общий доступ самостоятельно скомпилированной версии кода без разрешения правообладателя является нарушением закона.
REVISION 6278 IS TEST CODE, NOT INTENDED FOR ON-THE-AIR USE. PLEASE
> RESPECT THIS REQUEST AND DO NOT USE IT FOR NORMAL OPERATION.
> -- 73, Joe, K1JT
Further to this:
to the members and owner of the Facebook group that has been flagrantly
disregarding Joe's copyright and licence on WSJT-X by continuing to
publish binary packages of WSJT-X built from the development sources.
You allowed me to join your closed group and even to point out that you
should not be doing what you are, in the past. But now when I politely
request that you take down the latest build because of the above
request, you ban me. This is childish, I had no malicious intent, we are
fellows in the Amateur Radio community - or are we not?
To those taking advantage of the apparently freely available stream of
development binary packages of WSJT-X from the above source and others,
be aware that the GPLv3 Open Source Licence that WSJT-X is released
under does not allow binary distribution of the product without the
permission of the copyright holder. There is no ambiguity, doing this is
not just taking advantage, it is almost certainly breaking laws.
We, the development team, understand that you all want to get access to
the latest changes. This is possible if you build the application
yourself but with that comes a responsibility, you must take note of
what the latest changes are and the developers opinion of stability and
fitness for purpose. We collaborate on our development work on a public
source code repository, we have nothing to hide, we do not exclude
anyone. With that openness comes an opportunity for free loaders to take
advantage, that is the price that Free Open Source developers pay for
doing their work in public. Please respect our requests, they are for a
good reason.
You would be a fool to break into your favourite car manufacturers R&D
facility and borrow the latest prototype to drive your children to
school every day. If you want to be part of what Joe K1JT is giving to
the Amateur Radio community then respect his requests.
Bill
G4WJS
Откровенно не понимаю как физически соединить SDR-1000+Edirol-66 с программой WSJT, если эти программы крутятся на одном компе и соединяются программой виртуальными коннекторами.
Обновился до последней версии, стал видеть много, но отвечают...да никто не отвечает, из 10 попыток, 2 QSO, что интересно, отвечаю на частоте вызывающей станции, но рапорт получаю на 3-7гц ниже. Почему? Это вчера на 80-ке.
Зато JT-65+IC760PRO станций 1-2 и отвечают.
Так вопрос про ААлог, никто этот лог с WSJT не пытался подружить? Вариант копирования через ADIF работает, но хотелось бы в ногу со временем.
Ещё раз привожу картинку 09-24 через карту Delta 66
Вложение 154145
Версия 7.0.11.19 Xonar U7 Driver for Win7 32/64-bits(A-Volute UI version: 1.0.13)
Windows 7 64bit
https://www.asus.com/ru/Sound-Cards/...Desk_Download/
Как и говорил ранее ,вернулся к r6229(ранее не стояла у меня,как то пропустил)АРУ включено,SYNC вкл,8/8.Трансивер Kenwood,диапазон 20м,понравилось прием(декодирование).Буду поактивнее.....Вложение 154146
Пропустил вопрос ,извиняюсь.Так что получилось:на данный момент у меня работает WSJT-X v1.7 r6229 совместно с UR5EQF_Log(привык знаете ли и доволен работой Лога,а привычка вторая натура,как вы знаете).Единственно ,не раз уже говорили,приходится вручную рапорта поправлять в Логе,по умолчанию -10.А так и карта мира и азимут для вращения антенны ,все как обычно.Времени более чем и уж два действия(исправить с -10 на -......) я выполню за время ведения связи.А так все как и в других модах.На eQSL уходит автоматом,так что.От добра добра не ищут.......Вот и все!
[QUOTE=RA9XQ;1188153]Калибровку звуковой карты делали?
Вопрос интересный. В миксе когда-то делал. Но это другой комп, другая политика, даже физически не связана с SDR и Edirol-66. В эдироле никогда. Даже инструкций и информации на эту тему не встречал. Подскажите что да как - буду благодарен.
