Shetland Islands: 14: 27: EU: 60.50: 1.50: 0.0: *GM/s:
=2M0BDR,=2M0BDT,=2M0CPN,=2M0GFC,=2M0SEG,=2M0SPX,=2M0VIK,=2M0ZET,=2M1AN T,=2M1ASQ,=2M1ODL,=G0FBJ,
=GB0BL,=GB0DAW,=GB100ZET,=GB1COR,=GB2AES,=GB2CAS,=GB2DAW,=GB2ELH,=GB2E LH/LH,=GB2HMC,=GB2IGS,
=GB2LHI,=GB2MUC,=GB2NBC,=GB2QM,=GB2SB,=GB2SLH,=GB2SR,=GB2SUM,=GB2WAM,= GB2WG,=GB3LER,=GB3LER/B,
=GB4LER,=GM0AVR,=GM0CXQ,=GM0CYJ,=GM0DJI,=GM0EKM,=GM0GFL,=GM0GFL/P,=GM0ILB,=GM0JDB,=GM0SGB/M,
=GM0VFA,=GM1BYL,=GM1CBQ,=GM1FGN,=GM1KKI,=GM1MXN,=GM1ZNR,=GM3KLA,=GM3KZ H,=GM3RFR,=GM3SJA,=GM3SKN,
=GM3TXF/P,=GM3WCH,=GM3WHT,=GM3ZET,=GM4AFF/P,=GM4AGX,=GM4CHX/P,=GM4ENK,=GM4FNE,=GM4GPN,=GM4GPP,
=GM4GQD,=GM4GQM,=GM4IPK,=GM4JPI,=GM4LBE,=GM4LER,=GM4PXG,=GM4S,=GM4SLV, =GM4SSA,=GM4WXQ,=GM4ZHL,
=GM6RQW,=GM6RTO,=GM6VZB,=GM6WVI,=GM6YQA,=GM7AFE,=GM7GWW,=GM7RKD,=GM8LN H,=GM8MMA,=GM8YEC,=GS0AAA,
=GS0GRC,=GS3BSQ,=GS3ZET,=GS7V,=GS8YL,=MA0XAU,=MA1FJM,=MA6PTE,=MM/DJ6OZ,=MM/DL5KUA,=MM/OK1HDU,
=MM/OK7U,=MM/PA9D,=MM/PF9DC,=MM/W5ZE/P,=MM0/DJ6AU,=MM0/PA8MO,=MM0ECG,=MM0KAL,=MM0LON,=MM0LON/M,
=MM0LSM,=MM0NQY,=MM0SHF/P,=MM0VIK,=MM0XAU,=MM0ZAL,=MM0ZCG,=MM0ZRC,=MM1FEO,=MM1FJM,=MM3VQO,=MM3ZET,
=MM5PSL,=MM5PSL/P,=MM5YLO,=MM5YLO/P,=MM6ACW,=MM6BDU,=MM6BZQ,=MM6IKB,=MM6IMB,=MM6MFA,=MM6PTE,
=MM6SJK,=MM6YLO,=MM6ZBG,=MM6ZDW,=MM8A,=MO5PSL,=MQ5PSL,=MR5PSL,=MS0OXE, =MS0ZCG,=MS0ZET;
