Like Tree17119Спасибо
  1. #1771
    Координатор темы
    01.07.2011
    Днепропетровск
    3,066
    3090
    245
    Цитата Сообщение от R0AEB Посмотреть сообщение
    я имел в виду что у меня вносится правильно только полученный
    Вы до конца видео досмотрели. Все рапорта и позывной вносятся в лог. Есть отличие от ранее опубликованных советов.
  2. #1772
    Пацифист Аватар для R0AEB
    25.07.2016
    Красноярск
    115
    35
    161
    Олег не ругайтесь, каюсь видео не смотрел, делал по текстовой инструкции.
    Сбросте пож ссылку на видео по стыковке UR5EQF.
  3. #1773
    Координатор темы
    01.07.2011
    Днепропетровск
    3,066
    3090
    245
    Посмотрите в ветке по UR5EQF пост #31582.
  4. #1774
    Координатор темы
    05.03.2015
    5,542
    7959
    806
    Цитата Сообщение от VK6KXW Посмотреть сообщение
    Glad I could help Igor with the info on the programing side of things,it's not my cup of tea it leaves me brain dead!
    You guys have been very chatty since the last time I came a visiting in here just came from UDO's its gone quiet
    in there since the EXE became finally legal!
    Not sure what's happening in the conversation (translation gods are screwing up again into english) perhaps you could clarify for me please.
    I take it theres moves a foot in the GUI Skins department; I see classics/u1 to u4 being mentioned by various parties.
    Which leads me into also asking (being a windows guy) could the exe's have the option on installation; or a drop down sub menu in Settings some where ,that the user can easy change skins, another idea is you load a skin up from a folder. Vola....
    73,Peter,VK6KXW
    Peter,
    Most important discussion is about v16.5 features and it should be completely new 'Worked before' indication.
    Vytas LY3BG kindly supplied us with the new solution to this long standing lack of user friendly indication for the 'worked B4' and I'am going to release v16.5rc (release candidate) version within next hour, so that HF community could assist us with testing and fault reporting.
    Stay tuned,
    73 Igor
  5. #1775
    Координатор темы
    05.03.2015
    5,542
    7959
    806
    JTDX v16.5 release candidate software available for download
    Цитата Сообщение от LY3BG Посмотреть сообщение
    1. В4 не только в CQ, но и в QSO
    2. В4 по моде и в JT9+JT65 режиме.
    3. При непомеченой LockTX=RX при клике на позывной меняется только RX. При клике с нажатой Ctrl меняется ТХ и RX. При помеченой меняются оба.
    4. @ можно вписать в вольные тексты, это позывной корреспондента.
    5. F7 открывает лог.
    Может ещё что-то, не помню.
    Отзывы приветствуются!
    This software is solely for test purpose, fault reports would be very appreciated.
    All functionality changes supplied by Vytas LY3BG.
    - worked before status in v16.5rc being indicated per band and per mode
    - worked before status now being indicated for non-CQ messages as 'B4'
    - F7 keyboard button shall open log
    - symbol @ can be used for free message (macros?) with meaning 'hiscall'
    - changed functionality of LockTX=RX: different behaviour for double click and for
    'CTRL + double click'
    Software can be downloaded from this link: https://cloud.mail.ru/public/Mw4G/rwEx3EX2J
    Тестовый софт доступен для скачивания - пожалуйста пробуйте и сообщайте если есть какие либо дефекты.
  6. #1776
    дед Валя Аватар для UA3DTK
    30.01.2007
    Наро-Фоминск
    76
    2,871
    2472
    1291
  7. #1777
    12.05.2010
    Новотроицкое
    1,860
    1481
    327
    Игорь, а сырцы не даете?
    Кстати, вот ссылочка на скомпилированную Linux версию (64-bit) v16.4. Кому интересно, попробуйте.
    Инструкция по установке простейшая - распаковать, исправить владельца файлов (если понадобится)
    и просто скопировать содержимое либо в /usr либо в /usr/local (принципиальной разницы нет, но если
    ранее уже был установлен wsjt-x, просто посмотрите, где именно он у вас лежит).
    https://cloud.mail.ru/public/JSd5/zWtvRLyHP
  8. #1778
    12.05.2010
    Новотроицкое
    1,860
    1481
    327
    Прошу прощения за склероз, сразу не предупредил!
    В архиве ТОЛЬКО файлы wsjt-x, в смысле подразумевается, что hamlib3 уже установлен!
  9. #1779
    Координатор темы
    05.03.2015
    5,542
    7959
    806
    Исходники тоже будут опубликованы, просто пока еще не разобрался что менялось в интерфейсе mainwindow.ui чтобы сделать соответствующее изменение в классическом интерфейсе.
    Еще в планах доработать немного 16.5rc перед выпуском 16.5.
    Линк на исходники 16.5rc сейчас отправлю в личку.
  10. #1780
    Координатор темы
    05.03.2015
    5,542
    7959
    806
    Игорь, точное название операционной системы под которой собран софт, пожалуйста.
  11. #1781
    12.05.2010
    Новотроицкое
    1,860
    1481
    327
    Да, не подумал. Ubuntu-16.04LTS (64Bit). Впрочем, это наверняка не столь принципиально.
    Главное, что 64-Битная система (прошу прощения, 32-Битной нет, так что не могу ничем помочь если кому надо). В остальном при наличии необходимых для функционирования программы пакетов и библиотек вроде бы проблем быть не должно.
    За исходники спасибо, постараюсь сегодня собрать v16.5, линк выложу.
  12. #1782
    12.05.2010
    Новотроицкое
    1,860
    1481
    327
    Собственно, вот. Готово. Инструкция та же - просто распаковать в /usr или /usr/local (по вкусу).
    https://cloud.mail.ru/public/poHC/nW3CyDs21
  13. #1783
    12.05.2010
    Новотроицкое
    1,860
    1481
    327
    Игорь, а по интерфейсу можно задавать вопросы? Или не по адресу?
    Я про кнопочки - есть минимум 2 лишние. Ну согласитесь - "Monitor" и "Stop" - это эе 2 кнопки на одну и ту же функцию! Аналогично - "Enable TX" и "Halt TX" ! Мне кажется, если их "триггерными" сделать, будет гораздо удобнее! Оставить только "Monitor" и "Enable TX" и подсвечивать их цветом, если активны.
    Или не по адресу все-таки?
  14. #1784
    Координатор темы
    05.03.2015
    5,542
    7959
    806
    Кнопку "Enable TX" объединить с кнопкой "Halt TX" вряд ли выйдет, разный функционал:
    сейчас кнопка "Enable TX" разрешает передачу на следующем выбранном(чет-нечет) интервале либо на текущем интервале если он совпадает с выбором чет-нечет. Если во время передачи эту кнопку отключить то передача будет продолжаться до конца текущего интервала и многие этим активно пользуются например если в конце QSO надо отойти от компьютера - отключают кнопку "Enable TX" и уходят а передача сообщения RRR или 73 продолжается пока не закончится текущий интервал. Я даже отключаю кнопку "Enable TX" во время моего первоначального вызова корреспондента - если мне ответят то JTAlert звуковым сигналом сообщает об этом и тогда я возвращаюсь к компьютеру, и часто отключаю "Enable TX" в начале передачи сообщения 73 когда работаю в поиске чтобы сетап не пошел на передачу с последним сообщением после окончания QSO.
    Кнопка Halt TX моментально обрывает передачу сообщения.
    С кнопками Monitor-Stop проще и возможно удастся доработать - когда будет необходимость добавить еще одну кнопку в интерфейс попробую ужать функционал Monitor-Stop в одну кнопку.
  15. #1785
    18.01.2015
    новосибирск
    75
    1,686
    128
    55
    зачем мудрить, все нормально сделано, а B4 и всякие мутные изменения ни к чему, главное чтобы декодировалось все в лучшем виде.
    Ответов: 65
  2. Как начать работать с CW?
    от Z80X в разделе Телеграф
  3. Новая мода JT65
    от RX3AOE в разделе Win-XP/7
